Question about Kenmore Dishwashers
Kenmore Dishwasher We have a Kenmore Dishwasher Model #  66516819990 the delay light is blinking and won't go off.  We tried hitting cancel and that won't work.  Any Advice . . . THANKS!!!
SOURCE: Kenmore 66516032400 Dishwasher
On another website, we found a reset code that works for our Kenmore, which I think is the same as yours. Hit Heated Dry, Normal Wash, Heated Dry, Normal Wash (one at a time, within six seconds).
Posted on Jun 03, 2007
SOURCE: Kenmore Ultra Wash Dishwasher - Blinking Quick Rinse Light
My guess is that the foil that the buttons are mounted to is defective.  The control module "reads" the buttons that are pushed by the fact that the resistance between two pins on the circuitboard becomes zero ie. your pushing the button shorts out two pins.  the foil could have moistire damage or the resiistance of the tracks could be too high.  Solution for both would be to replace the control panel button foil.
Posted on Oct 17, 2007
SOURCE: Kenmore dishwasher blinking light
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } I have model number 587.1525 or 587.1625. I purchased it March of 2007. It gave us problems from the beginning. My dishwasher will halt in the middle of a wash cycle and the bottom two lights will blink next to the start/cancel button. In the past, I would continue to put it on wash several times before it completed a cycle. I've had 2 Sears repairmen out. First guy said he didn' t know what was wrong but keep a record. Second guy said it was b/c water didn't get hot quick enough. I resolved that problem. Now, my dishwasher completely stopped working altogether. It never completed the last cycle, and there is water in the bottom.
Posted on May 16, 2008
  • 639 Answers
SOURCE: i have the kitchenaid dishwasher
Dear friend,
ngfam at you service! happy to assist!
It's an electronic problem!
The lights are called codes and need to be diagnoed by a factory service person!!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Posted on Aug 29, 2008
  • 750 Answers
SOURCE: Cancel Light Flashing on Kitchen Aid Dishwasher
Hi 1cassie1,
Did you try to turn the power off at the breaker box?
This resets the whole system usually!
Let me know how it goes? Write me back!
Other wise you need a hands on tech.
please give me a rating before you sign off!
Posted on Sep 11, 2008
SOURCE: Kenmore Ultrawash Quiet Guard 4 dishwasher - clean light blinking
I have the same problem. I called the repair guy and he told me how to do a diagnostic check on it to clear the problem out and let it run a cycle to see if it fixes itself. That cleared my problem with the light but unfortunately didn't fix my problem. Press the heated dry button, then press the normal wash button. Press the heated dry button again and press the normal wash button again. Then let it do its thing. If all the lights go out and it does not run a complete cycle, then press normal wash and start to see if it will run the cycle. To speed up the test cycle, he said you can press Start several times slowly to get it to go to the next cycle one at a time. You will see the red lights change from sensing to washing to drying and so on until it goes to clean. Then try to wash some dishes and see if it works. If that didn't solve the problem, he said it could be that there is food or other items stuck in the bottom and needs to be cleaned out. Just remove the spray arm on the back and top of the dishwasher by the 2 screws and take it out of the dishwasher. Then remove the screws at the bottom and take the screen out to get to the tray at the bottom to see if there is food stuck in there. Pay attention to how you took it apart though, so you can put it back properly. Also check the spray arm and run water through it to remove anything that might be stuck in it. If that doesn't solve it, he said it could be the heater or your motor or possibly wires burned out. I am looking at trying to remove my motor now to see if I can replace it and check that before I pay any money unnecessarily. My repair guy is so busy that he tries to help me over the phone before he comes out. Great Guy. He said that if it is the motor, the charge to replace it is not worth fixing, but if the repair is only 100 to 200, that is definitely cheaper than the cost a the same kind of dishwasher I am planning on purchasing to replace it. They say that because the do not want to work on it. A lot of times they do charge more than it's worth though, so you have to get an estimate concerning your worst possible problem before hand so you can make up your own mind. Hope this helped you. Now I will see if anyone can help me figure out how to remove the motor from my Kenmore Quietguard 4 Dishwasher. Have a great day.
Posted on Sep 28, 2009
0 characters
1 Points
Here again is my model and serial it stops in the middle of the cleaning cycle Kenmore 665.16773402 serial # ft0302854 Here is how I have been resetting the dishwasher. I hit the following sequence of...
Door latch.
Open and close the door to make sure the door latch is securely fastened
Hi-Temp Wash, Hi-Temp Rinse, or Sanitize options.
Some models have options that may require a water heating delay, such as Hi-Temp Wash, Hi-Temp Rinse, or Sanitize. Additional time may be required to heat the water to the proper temperature. The dishwasher will continue to circulate water during this heating delay but the timer will not advance until the proper temperature is reached
Oct 06, 2010 | Dishwashers
My kenmore built-in dishwasher "clean" indicator light is blinking instead of a steady light. Now nothing will work on the dishwasher. I've tried to cancel, along with other possibilities and nothing seems...
press heated dry and hi temp back and forth till all the lights light up then hit cancel. You have a bad heater if the clean light is blinking
Jun 15, 2009 | Dishwashers
Clean light blinks constantly
press heated dry
press normal wash
press heated dry again
press normal wash again..........
.....wait a few seconds
all the lights should come on
press cancel (should hear pump)
hit cancel again
Hope this helps, it worked for me, but it may depend on your model.
Feb 05, 2009 | Kenmore Dishwashers
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Lock Light Blinking
silly question but did you try holding the control lock button(perhaps its the heated dry button) in for 3 secs???? sonds as if the CONTROL LOCK has benn activated( child lockout)
Jan 14, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
The start button will not stop blinking.
I hit start and then it started operating in test mode and ran through some tests. I now seems to work fine.
Jan 10, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Dec 05, 2006 | Kenmore 24 in. 16032 Built-in Dishwasher
Dishwashers Logo
Top Kenmore Dishwashers Experts
Fred Sops
D. E. Hev
Raisin Brann
Level 1 Expert
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
