Question about Soleus MW-55
No cold/hot water
For the first couple of days, the unit working fine, after that it stopped working. There are no hot/cold water. Any idea?
2 Suggested Answers
  • 263 Answers
SOURCE: Cold water freeze
you have to lower the termostat because is freezing the the cold water duct that happens when is cold or winter
Posted on Jan 01, 2008
Hot water in kitchen only froze
good idea to let the cold water to run a bit to stop freezing up . Pity that you didn't do the same with the hot water. There is only hot water in the tank but the water in the hot water pipes will freeze as the heat goes out of the pipes. (Always to have to wait for the hot water to come through when you use the shower or bath.) The water will freeze up right back to the hot water tank
Jan 29, 2014 | Cars & Trucks
Mira 88 not supplying hot water
may have a screwed up washer seal on the hot side..it will stop the flow to a degree and allow more cold water in..calls for dismantling the entire control or replacing it..
Jan 26, 2014 | Water Heaters
Have water leaking out of bottom, clear water. Will brew coffee but liquid is reduced by amount coming out of bottom of the unit. Have decalcified and use only RO water. Any ideas?
Is the water hot or cold? If cold you need to check all pipes and their couplings from the water tank to the boiler. If the water is hot, then check all pipes and couplings from boiler to brew unit and steam wand.
Aug 09, 2011 | Gaggia Titanium Espresso Machine
I have a newly installed Bosch hot water heater. After installing, it seemed to be working fine. It is in a small weekly rental unit. If anything, the unit is over-sized for the demand. Now that it is...
these units need lots of flow to start and run. Set the temp on the unit lower and the people in the shower will have to use more hot and less cold which will make the unit more stable.
Jun 01, 2010 | Bosch & Tankless LP Hot Water Heater
None of the hot faucets are working but the cold water works fine. the pilot is on & we can hear it heating up but still no water. the heater is only a couple of years old. also it bangs very loudly....
IS THE HOT WATER VALVE OPEN AT THE WATER HEATER? OPEN THE PRESSURE RELIEF VALVE AND PURGE ANY AIR OUT OF THE TANK. BE CAREFUL NOT TO BURN URSELF.
Dec 12, 2009 | Water Heaters
Hi there I have a Zanussi zdf121 dishwasher which is only doing a cold wash, not heating at all. Not sure if its hot fill but the hot water is fine elsewhere. Any ideas please Pete
Do you have it hooked up to hot or cold water supply? Most residential dishwashers don't come equipped with a booster heater. If it's connected to the cold side, you'll have to replace the angle stop with a single outlet stop and replace the hot angle stop with a double outlet stop. This should help out, if not, make sure you have hot water in the faucet before starting the dishwasher. Most dishwashers need at least 120 degree hot water supply.
Mar 02, 2009 | Zanussi 18 in. DA4342 Free-standing...
Hamilton Beach 87330 water dispenser: no auto shut off
Glen,
We purchaced this water dispencer about 2 years ago, everything was working normal, water heater works fine and the cooler would come on and go off normally,until you dispenced cold water and then the coller would cool down and shut of like it's supposed to.
Afetr a couple of years , one day it started cooling continuously and wouldn't stop, I've just shut the cooler switch off on the back of the unit until i can figure the problem out,unit #(87330).
I believe the problem is in the circuit control board, but with out further testing i can't be sure .
Sep 01, 2008 | Refrigerators
WASHER WON`T FILL FULLY WITHOUT RE OPENING TOPLID SEVERAL TIMES?
water valve should be a single unit consisting of a hot and cold solinoid assembly. This whole valve assembly should be replaced.
Jul 20, 2008 | Washing Machines
Soleus MW-55 Logo
Top Soleus Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Soleus Refrigerator Expert? Answer questions, earn points and help others
