Question about Ovens
The lower oven in my CMT 21 Thermatronic II oven will not heat properly. I set the temp. at 350 and it will only heat at 250 as an example.
  • 867 Answers
If it is not turning red, the element needs replacing. if it is turning red, thermostat or control panel issue
Posted on Jul 22, 2009
Require instruction manual for Thermatronic II double oven.
Here is a contact number for sears. (800) 252-1698 Maybe they can help you find one. Good luck
Oct 31, 2013 | Thermador C302U Electric Double Oven
My oven is not heating properly and when I check it with an oven thermometer it is about 25-50 degrees lowere than set
this is usually a problem with the temp probe,other ocassions the main control board if equipped is bad or the temp control switch is bad
Mar 08, 2010 | Ovens
I have a frigidaire stove that heats to 50 degrees hotter than the know setting. Can it be adjusted to read correctly?
There is a calibration method to adjust the oven thermostat plus/minus 35 degrees if it is a digital display. The method varies depending on the model range. This calibration method is used to adjust the thermostat if it is not keeping proper tempature. For example if you are setting the oven to 350 and the actual temp it is keeping is 325 then you could use the calibration method to adjust it plus 25 degrees to correct the temp. Just so you know electric ovens will keep a pretty even temp but gas ovens will vary by 40 or more degrees to keep an "average" temp. For example the burner will come on when the oven is 330 degrees and turn off at 370. 330+370 then divide by 2=350. So a oven thermometer may not show you the temp you set it at in a gas oven but does not mean the oven temp is off.
Jan 14, 2010 | Ovens
Reassembling thermador Thermatronic II lower oven door cmt21
you can use some of the glass of the old oven just need the size of the glass if you order from the manufacturing it very exp
Jan 03, 2010 | Thermador SMW272 Electric Double Oven
Thermador Thermatronic II Latch Release issue
If you look at the top row of controls, you'll see one that says "Latch" with a switch to toggle between Locked and Release. Push on the "Release" switch setting and try the latch. It should release.
Oct 22, 2009 | Ovens
Amana oven doesn't heat
IS it gas or electric? If it's gas, you may need to have a technician regulate the air and gas. If it's electric your t-stat may need to be replaced. Hope this helps! :>)!
Aug 14, 2009 | Ovens
Electric oven not heating to temp
the oven temp. sensor is bad here is the part #WB21X5301 this should take care of your problem
Jan 21, 2009 | GE Ovens
Ovens Logo
181 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
