Question about Sharp Office Equipment & Supplies
I have a Sharp AR-337 copier with a sorter attached. I am getting an ''Call for Servies: Code: F1-11'' error at start up. I have made sure that everything is plugged in properly and that there is no paper or pieces of paper obstructing anything. Please help. Thanks
    President:
  • Sharp Master
  • 990 Answers
Hello sir; The error code you display F1-11 it means pusher motor problem in finisher , replace it.
Posted on Jul 23, 2009
Diagram Sharp SIM14?
Type # - interrupt - C - interrupt and clear the code with simulation 14 and then hit CA to exit. If the code comes back there is a problem with your fuser (dirty thermistors cloged with toner, or one of the lamps are out)
Apr 06, 2014 | Sharp AR-M237 Copier
Code F2-04 solution
http://www.retrevo.com/support/Sharp-AR-M162-Multifunction-Printers-manual/id/600ag113/t/2/
Above is your user manual below is your service manual.
http://www.eserviceinfo.com/index.php?what=search2&searchstring=AR-162,+AR-163,+AR-201,+AR-206,+AR-207,+AR-F201
http://www.eserviceinfo.com/fulltext.php?search_ft=DPX-7010MD
You have a sensor error. I have included your user and service manuals so you can attend to the error.
F1-04 Bin limit position sensor error in sorter
Aug 12, 2010 | Sharp AR-M162 All-In-One Laser Printer
Sharp copier model SF2530 F1 flasing and copier
Hello sir; F-1 is sorter problem, did you connect sorter with machine, turn power off and check th connecter .
May 15, 2009 | Sharp AR-5316 Advanced Digital Imager...
CH Error
CH - open cover in the paper feed area.OR - Sorter not installed properly
CH blinking - Dev unit is not properlyinstalled.
EE-EU - Low toner density in thedeveloper.
Check/ replace toner cart. Check/ reset Dev. unit. Check covers and doors to make sure all are closed properly. If you have sorter -- make sure sorter is seated properly.
Mar 02, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-405 error code F1-15
Hello sir; this error code means " elevator motor "problem inside the finisher,check it out is something stuck the motor. or you have to replace one.
Feb 16, 2009 | Sharp AR-M205 Copier
Error Code F1-00: How to clear on Sharp AR-C250
go into service mode (program interrupt clear interrupt)
enter simulation 26 sub 1 (option setup)
change to no finisher
CA to exit, and you're all set
Dec 11, 2008 | Office Equipment & Supplies
Sharp Copier AR-5132
Generally F codes have to do with the finisher(used to be called a sorter). with the machine off, diconnect the finisher cord from the copier and power back on. This should allow you to test the copier. I'm not sure on this model how exactly the finisher cord comes out. but it should be self explanitory when you see it.
Oct 29, 2008 | Sharp AR-5316 Advanced Digital Imager...
Error code.
CH error has to do with your sorter. Check to make sure it is connected properly and see if there is anything jamming inside of it.
Aug 15, 2008 | Sharp AR-207 Copier
Sharp Copier Service Code
You had 5 jams in the fuser the hotarea on the left side of your machine.
Feb 15, 2008 | Sharp AR-M237 Copier
294 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
