Question about Kitchen Ranges
Fef369cgsd frigidaire oven
Oven does not heat properly. Upper oven element works on broil but does not cycle during baking, causing too low temp.
Obviously it is not the element. I figured the cause was the clock/timer, so I bought & installed one, but the problem persisted. I am taking it back but am stuck with a 30% restock fee, probably over $45. :-((
I looked at the schematics and tried to figure out what else might cause it.
Ideas?
  • 248 Answers
What do you mean by, "properly"?
Is it heating or not at all?
Is it not hot enough, or too hot?
Upper element is for broil. It may come on briefly during bake, but usually at half power. It doesn't glow red.
Does the bottom element glow red? If not, inspect lower element, which is the bake element, for pits and rough spots. These may be signs of failure.
UNPLUG STOVE!! Remove bake element and check for continuity. If it shows open, replace. You can probably take to parts store and they can test it for you.
Posted on Nov 21, 2007
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
My Kenmore Elite oven will take over an hour to preheat to 350 degrees and never does get done preheating.
There's a few things that can cause this.
1. Check to see if the both that Bake and Broil elements (burners) are heating up. Check the Broil element in Broil mode.
- during pre-heat the Broil element gets cycled on and off for short time durations to speed up the heating. If the Bake element is not working, then the oven will heat, but very slowly and never reach high temperature.
2. If the elements are both working, then it's possible that you have a bad temperature sensor.
- this is a temperature dependent resistance device that should measure 1080 ohms at 70 deg F (room temp).
3. If #1 and #2 are ok, then the problem is with your oven clock/control unit. We rebuild these at fixyourboard.com.
Aug 14, 2010 | Kenmore Ovens
Kenmore electric range - oven temp low and takes forever to heat
if lower element tests open with continuity meter then it for sure is bad. i would also check the wire ends that connect to the element and/or the control board, they could have loosened allowing a bad connection and low voltage to elementor burnt off.. most ovens do not use the broil element at all during the bake cycle, only during the broil cycle.. some however do utilize the broil element during baking, but at a lower wattage or something..
best of luck,
ttfn
Oct 25, 2009 | Kenmore 30169 Electric Single Oven
I have a frigidaire oven model # PLEB30S8CCB won't get above 290
The coils should glow red when working. If the lower (bake) element does not glow it may be burnt out. Some ovens cycle the bake and broil elements during preheat and that mey be why you are getting some heat.
Aug 27, 2009 | Ovens
Whrilpool GR450LXHB2- The stovetop works, but the
It won't bake or broilIf neither the bake nor the broiler heating elements heat, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)", push the knob in and try the baking and broiling elements again. If it still does not operate properly, you probably have a defect in the thermostat, selector switch, or common wiring.
If the oven does not have a separate bake/broil/etc. selector switch, the problem may be with the thermostat. But it's not easy to check the selector switch or thermostat for proper operation. If you suspect a problem in this area, call a qualified appliance repair technician.
  • When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
  • You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
    If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
  • When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
  • If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
    Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
    Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
    If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
It won't broil Usually, when an oven won't broil, it's because the broiler element is burned out. The broiler element in an electric oven is the black, pencil-thick tube at the top of the oven. When the broiler is on, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 25, 2009 | Ovens
KitchenAid Oven Temp.- Bottomside of Pizza or Cake stays uncooked
I have a 2yo Kitchenaid oven, and my advice is first, don't use convection for cakes or pizza. Use the thermal oven. For pizza preheat to 500 degrees, then put the pizza on the lowest rack, and bake for 7-8 minutes.This way the bottom browns, and the top doesn't get broiled from the top element coming on during the bake cycle.
As for cakes, again place them on the low rack so that they get bottom heat. I keep my eye on the oven and when the broil element comes on I stick a piece of foil over the cake until it goes off. Otherwise it will set the top and the cake won't rise as much. Even doing that cakes don't rise as much as they did in my old oven, and they brown too much on top.
The convection oven does a good job of cookies, and the broil mode is okay.
I wish I hadn't bought this oven, but I didn't know about the upper (broil) element coming on during the bake cycle until I'd had it for awhile, and it was too late to return it.
If anyone's shopping for an oven, ask questions, and don't get one that maintains the oven temperature by activating the broil element when baking.
Jun 24, 2009 | KitchenAid Architect ® II KEBS208S...
Wont heat past 200 degres
May 27, 2009 | Ovens
Kenmore oven lower element sporadically heating.
After temp is set bottom oven will not heat up to desired temp
you probably have a burnt out or shorted out lower bake element in you r lower oven. it sometimes will actually break apart or look like it sparked thru the black tubular section. it is common and will cause no heat during the bake cycle.
you could try to do a broil and see if it gets hot and that would let you know the control is ok and just needs the lower bake element.
Jan 28, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Kitchen Ranges Logo
434 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
