Question about Sewing Machines
My 385.15516000 Kenmore sewing machine is skipping stitches. I've re-thread both the needle thread and the bobbin, cleaned and oiled, checked to see if needle was good and in correctly. What else should I check?
  • 111 Answers
Have you tried a new needle? needle in correctly? threaded correctly?
Posted on Jul 23, 2009
Skipped stitches
lower your needle. If up to high can't catch the bobbin thread.
Aug 31, 2017 | PfaFF Tiptronic 2040
My New Home skips stitches. I have cleaned it, changed needles, adjusted the tension and tried different bobbins .
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
it's also possible that the machine could be slightly out of time
Aug 29, 2012 | Sewing Machines
I think the timing is out on my janome 2039 sewing machine
It is very possible that the timing is off, which often occurs with broken needles. A common symptom is that the needle will not pick up the bobbin thread. Missed stitches aren't necessarily timing related--be sure to install brand needles often and use the correct needle for the fabric & thread you are using. Using the wrong needle will often cause skipped stitches.
What to Do If Your Sewing Machine Is Skipping Stitches
10 reasons for skipped stitches
Here What to Do if Your Sewing Machine is Skipping Stitches
Basic Maintenance Tension Skipped Stitches
You can search for sewing machine timing or take it for service.
Apr 12, 2017 | Janome Harmony 2039 Mechanical Sewing...
My Husqvarna diamond top thread keeps breaking while doing loop embroidery. It sews a couple of stitches and then you can hear when the thread breaks. Ive tried changing the needle and bobbin, and cleaning...
Hello
Primary causes of upper thread breakage:
-- misthreading: pull all the thread off and thread again, using the manual, step by step. Read each step aloud before you do it. (sounds dumb, but helps.) (And make sure you thread the takeup lever!)
-- thread has wrapped itself around a thread guide or spool pin from one of the breaks. Take the spool off the machine before rethreading.
-- bad or damaged needle. Replace with the right size for the fabric, turned correctly (backwards needles skip stitches)
-- dirty machine, especially in the bobbin case area: review cleaning instructions and do it, using brush and vacuum only
-- bad/cheap thread: should not be slubby or break easy. Try another spool.
-- top thread tension too tight. 4 is normal for most fabrics, most stitches.
Tips;
1) do a light cleaning (brush and vacuum) every day you sit down to sew.
2) replace the needle if you hear it hit metal, if you've got a really bad thread jam, if you see it deflect as you sew (for instance, sewing over the side seam on jeans when hemming). Replace every 3-8 hours of actual stitching time anyhow.
3) buy good quality thread
4) when your machine isn't sewing right, stop; take all the thread off of/out of the machine (bobbin out of bobbin case, spool off spool pin) and give it a quick cleaning. Rethread from scratch, carefully. If that doesn't fix it, do it again, then replace needle and rethread one more time, manual in hand (yah, even if you've threaded it 8 million times before). #4 is curative about 98% of the time. The other 2% often requires professional attention.
Jul 11, 2011 | Husqvarna Designer I
My singer curvy 8780 has a timing issue the needle is scraping on the bobbin casement and will not sew,cleaned and oiled, changed needle turned off and on. any suggestions?
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 06, 2011 | Singer Curvy 8770 Electronic Sewing...
Keeps skipping stitches and knots thread
Good day!
Good day!
Jun 06, 2011 | White Sewing 2037 Mechanical Sewing...
Hi why does the machine skip stitch ,or Cather at the bottom ,the problem occur while am sewing.
check to see if your needle is bent-roll on flat surface to see if it roll good
if the needle make a popping sound when going thru fabric it is blunt
the needle is incorrectly inserted in needle clamp holder
needle & thread not compatable with project
check for warped bobbin
rethread machine
check bobbin area for lint or loose threads
check to make sure thread is not caught on any thing-such as spool pin-notch in spool of thread
Aug 22, 2010 | Kenmore Drop-In Bobbin 505S-21BH...
Sewing machine not stitching
Sounds like you need to retime the machine, if you email me I can attach instructions drivewithken@blueyonder.co.uk
Jun 26, 2010 | Kenmore 15212 Mechanical Sewing Machine
Kenmore Sewing Machine: stitch not forming bobbin thread problem
sounds like it needs a service call. if you do not have a sewing repair man you use regularly to clean machine the local fabric store should know who you could call.
Jul 20, 2017 | Kenmore Sewing Machines
Stitches are skipping, bobbin problem?
Here are a few things to try. One of these should fix your problem.
* Re-thread your needle
It may be threaded incorrectly (backwards).
* Change your needle
Your needle may be blunt, bent, or otherwise damaged.
* Your fabric may require a different needle. Generally, heavier fabrics require larger needles and
thinner fabrics, smaller needles. You may also need a larger needle if
you’re sewing through many layers of fabric. And make sure to use a ballpoint needle for knit
fabrics and a sharp needle for wovens (or a universal needle for either).
And make sure your needle is appropriate for the type of thread you’re using.
* Adjust the pressure of your pressure foot
It may be too light for your fabric.
* Change your thread
If your upper thread and bobbin threads are different types, try using the same thread for
both. And use a good quality, brand name thread.
* Adjust your thread tension
It may be too tight or too loose.
* Re-thread your machine
It may be threaded incorrectly.
* Change your needle plate
Try switching to a needle plate with a smaller hole (a straight stitch needle plate).
* Reinsert your needle
Make sure it goes all the way into the holder and that it’s positioned correctly – usually with the
flat side away from the bobbin, but consult your machine’s manual to be sure. I know you said you checked this already but it might not hurt to double check it.
Important Note:
After changing your needle plate, check to make sure your needle aligns perfectly with
this smaller hole before starting to sew. A misaligned needle could hit the plate and break, which
could be dangerous. And make sure to change your needle plate back for zigzag and other wide
stitches.
Hope this helps.
Sep 15, 2009 | Kenmore Sewing Machines
Sewing Machines Logo
201 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
