Question about Canon imageRUNNER C3200 Copier
Canon Imagerunner C3200 Service menu
What is the button sequence to access the hidden service menu. I need to change the print server setting to windows printing.
  • 11 Answers
Try *28* but remember to press 28 a the same time. * is that button next to the screen with little ring(head) and star in it.
Posted on Jul 24, 2009
How can I open the service menu?
Press the helpful button and check link below for various models
First power off your TV using the remote, then press following buttons quickly on your TV remote:
Display (or i+) + 5 + Volume Up + Power
It'll show the hidden service menu on your TV screen.
Once you enter into service menu, you can press Menu (or Options) button again on your remote to switch between various service modes such as Digital, Chassis and VPC.
To navigate between available options press 1 or 4 buttons. To change or modify their values press 3 or 6 buttons.
To save your changes, just press Mute + 0 (or Enter) buttons on the remote.
To restore settings to factory defaults, press 8 + 0 (or Enter) buttons.
PS: For some new models the above mentioned method might not work. You can try following key sequence to access service menu in those new models:
While TV is on, press Left + Right + Mute + Center button + Mute + Menu buttons.
Hidden Secret Service Menu Codes for Sony Samsung LG and Philips TV
TV Service Menus Hidden features you didn know about
Jan 31, 2016 | Televison & Video
Problem with the Canon imageRUNNER C3200 Copier In printing colors are 1 mm apart from each to other
You need to clean the rollers in the "Internal transfer belt". I'd suggest you contact Canon service, because you could easily break the thin Transfer belt if you do it wrong. Temporary solution is to turn the machine off and then on, following a FULL color calibration.
Feb 03, 2011 | Canon imageRUNNER C3200 Copier
Environment: Windows Server 2008 as Print Server. Canon Copiers iR3570/iR4570. The Canon Driver Information Assist Service is installed on the server. This allows the server to communicate to the...
I believe you have to identify the accesories that are on the copier. I think you go to the printers section of the control panel on Windows. Right click the copier, select properties, then device settings. Look to see if you can change any of the options. If not you may have to reinstall the print drivers. Hope this helps.
Jan 27, 2011 | Canon imageRUNNER C3200 Copier
Canon ImageRunner 3200
there are several steps before reaching the laser i-- clear dc con then take machine off remove plug from outlet then power up machine 2--clean the itb assembly thoroughly 3---change the transfer belt 4 --- change the itb assy. if nothing works then we will go to the laser
Jan 06, 2009 | Canon imageRUNNER C3200 Copier
Canon imageRunner 3200n printing problem in color
ok you are in the right area are you taking the belt off to clean those rollers???? if not do that 1st. then you may have to clear the dc controller but 1st do a DPRINT under the service function menu. after the dccon clear you will need to put those #s back in
Dec 24, 2008 | Canon imageRUNNER C3200 Copier
Canon ImageRunner Missing Menu Functions
Fiery..
you would need to acess the fiery network controls from the touch panel. on the copier, reset up the ip address etc. reboot the fiery.
Fiery are a bit different from the standard acess to a nic card on a machine. Again I really am not familiar with Cannon. Thou I would recomenend searching for a Fiery set up manual,
Dec 12, 2008 | Canon imageRUNNER C3200 Copier
Canon C3200 imagerunner
go to service mode By pressing * 28 * and you will see a menu COPIER then MISC
Dec 09, 2008 | Canon imageRUNNER C3200 Copier
Canon Color ImageRunner - Tab Instructions
To be able to print using tab paper from the driver
Since the tab paper can only be fed from Stack Bypass, single reverse tab paper cannot be
used. The tab paper must be single forward.
1. Go to the printer and put some tab paper in Stack Bypass
2. Press Letter on C3200 LCD panel and press Next
3. Select Tab paper and press Done
4. Go to Windows Start menu and choose Settings
5. Open Printers folder
6. Select Canon iR C3200 PS3’s Properties
7. Click on Device Settings tab
8. Click on Form to Tray Assignment button
9. Making sure that Stack Bypass is highlighted and Paper Size is Letter, select
Tab Paper by scrolling down the Paper Type list
Page 2
Hint:
In order to print to Tab paper, it is necessary to select Tab Paper in the Form to Tray
Assignment dialog box before using this option. Otherwise, the option of printing to Tab paper
is not available from the print driver.
10. Click OK to close Form to Tray Assignment
11. Click OK to close Properties window
12. Open Word document called “tabs.doc”
13. Go to File menu and select “Print…”, and change the current printer to Canon
iR C3200 PS3.
14. Click on Properties
15. Click on Paper Source tab.
16. Select Paper Type option
17. Choose Tab Paper from Paper Type list. As soon as you select “Tab Paper”,
Conflict Information dialog will appear. Click on OK.
Page 3
Hint:
In order to change the tab position, click on Tab Position button. Clicking this button opens a
dialog box for specifying the width for shifting the image data to be printed on the tab part of
the paper.
Hint:
The conflict information displayed pertains to the finishing of the document. Tab paper must
be grouped, not collated. Since the default value for finishing is Collate, the driver
automatically adjusted the finishing option to resolve the conflict.
18. Click on OK to close the Properties window.
19. Click on OK to print the tab paper.
20. Go retrieve your output.
Note:
Please note that this procedure for printing on tab paper is not the same for all drivers. CCD
drivers would be similar to this procedure, but depending on the OS Platform, exact buttons
and steps would vary. However, from such drivers as imagePASS-C1 PS and Macintosh drivers
would work completely different from this procedure. Although we will not cover each
procedure step by step, we encourage you to take time to make yourself familiar with the
procedures.
Sep 30, 2008 | Canon imageRUNNER C3200 Color Printer
Canon imagerunner c3200 stuck in processing data
If you don't print via a server,you can turn the iRC3200 off...then back on and that will clear the print jobs.
If after doing this it STILL has a traffic jam in the print que when trying to print the same document then stop sending THAT particular document as the document has a formatting issue and NOT the printer.
If you DO use a print server then you(or your I.T Professional) need to go to the server and clear the print jobs from the server.
Aug 06, 2008 | Canon imageRUNNER C3200 Copier
Canon imageRUNNER C3200 Copier Logo
476 people viewed this question
old marine
old marine
