Question about Kenmore Oasis HE 27082 Top Load Washer
Generates an F1 error
The technician said that the polarity on my electrical outlet ir 180 out of phase, the white and black wires to the outlet need to be swapped.
The ETC board may need to be replaced.
    Problem Solver:
  • 16 Answers
F1 is the machine control call kenmore there is a dervice flash and a recall on it u can get it fixed for free
Posted on Jul 22, 2009
F28 error code on Maytag front loading washer
The communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) has failed.
Possible Causes
- Reversed polarity or mis-wire along with open ground switch(es).
- Communication cable from CCU (MI3) to MCU is damaged.
Procedure for reversed polarity or mis-wire
1. Clear error code.
2. Unplug washer or disconnect power.
3. Check the white wire on the RFI filter to ensure correct polarity.White wire needs to be toward front of washer.
4. Check outlet for correct polarity. To check within washer for polarity at the RFI, white to cabinet ground must be 0 volts.
5. Check that the ground switches of the toe panel and rear panel are correctly closed.
If switches are good ,replace the CCU.
Oct 14, 2016 | Maytag Washing Machines
Hobart three phase mixer is spinning the wrong way
Sounds like the polarity. Easily corrected by swapping the red and black position of the wires inside the plug. Make sure there are no other power sources feeding the unit before removing the plug.(the white and green wires should not be moved. Easy way to remember wiring a three phase plug. Most are labeled on the inside of the plug with GXYZ. G is always the green ground wire. X-red (Indians were here first), Y- white ( then came the white man) Z- black ( then the black man)
Sep 04, 2013 | Hobart Food Mixers
Coleman evcon wrong polarity or twinning error what does this code mean
It will probably means you have your hot and neutral wires crossed. The furnace has 120 volts coming in to it from your house. If the hot and neutral wire are wired to the furnace wrong, it will show this error. Take the electrical box loose where you can see the power cord coming in to the furnace. (turn off the circuit breaker to the furnace) Take the white and black wire loose , connect the black where the white wire was and the white where the black was. All you are doing is reversing polarity. I hope this works for you.
Apr 18, 2011 | Coleman Heating & Cooling
Whirlpool 665-13442K901 dishwasher electrical plug in shorts out
You reversed the black and white wires on what? Don't ever do that. One is the line and one is common. They are polarized for a reason.
Immediately stop using that outlet before you burn your house down. Switch the breaker off to that power circuit, then have a qualified electrician check it out.
Jan 28, 2018 | Whirlpool 24 in. Built-In Dishwasher w/...
AEM407WZ Electric Dryer - 4-wire cord installation
red and black are the 2 power phase wires and go on L1 and L2 terminals or on an inline power block the 2 outer terminals(polarity)doesn't matter,then white is the center or N-neutral terminal, then green or green/yellow stripe is chassis safety ground and is connected to the metal frame of the unit
Mar 04, 2010 | Dryers
How do u change a frigidaire 3 prong wire to a 4 prong when the three wire in the connected in the dryer red,green and black and ground green.and my new 4prong wire has a added white one so what should i...
red&green-black are the 2 hot power phases and they hook to L1 & L2 either way polarity not an issue...then the white is the neutral terminal and goes to the center terminal or N terminal....then green is still your metal case safety ground wire
Mar 03, 2010 | Frigidaire GLER331A Electric Dryer
How to install a 208v outlet for a stove
if its a single phase panel you will only have 120/240 v.a.c. you can wire it for 240 volts and it will heat faster anyway the only way you could have 208 volts would be if you had 3 phase delta or open delta 3 phase or buy a special "dry-type" transformer for 240 volt to 208 volt step-down,otherwise it will be red-& black will be your 2 hot phases of 120 volts each/white-neutral/and green or green-yellow will be the case safety ground
Nov 14, 2009 | General Electric Profile PP945 30 in....
Wiring a single phase outlet
test wires, white u need supposed to be ground, and usually two of the other wires is hot mostlikely red green attach only 2 hot wires if 3rd is hot cap it, home depot also sells basic wiring book that will guide you through this issue
Jul 07, 2009 | Welding Tools
3 wire cook top to a 4 wire outlet
Older 3 wire connectors where Wht=Neutral Ground Return, Red=One Phase Hot, Blk=Second Phase Hot, of 220VAC stove connections.
Newer Electrical code standard has a forth wire that is bare copper for a separate safety ground return.
I suggest you but a 4 wire pig tail cable for your stove top, available at Depot or Lowes, and connect 3 wires of this 4 wire cable just like the 3 wires are now connected. The 4th bare copper safety is attached to any metal part of the stove. Find a screw you can loosen to wrap it around and tighten.
Mar 02, 2009 | Jenn-Air JED8230 Electric Cooktop
Kenmore Oasis HE 27082 Top Load Washer Logo
192 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
