Question about Aiwa NSX-DS55 CD Shelf System
NO SOUND ON CX-NMT320
NO SOUND CX-NMT320
    President:
  • 2,777 Answers
Does this occur on every input? If you try the radio, the CD, everything? If so, does the screen display that it is playing properly? When you adjust the volume does the screen show the fact that it should be changing? If so then it sounds like either the speakers have been disconnected, or that the amplifier that actually powers the speakers has failed. Double check the speaker connection to the back / side of the player and if it is connected then shut down the player, then unplug it from the wall for a good 2 minutes. Plug it back in and try again. If it still doesn't work then the amplifier as failed and you will want to look into a warranty replacement if you think it's still under warranty, or probably replacing the unit.
Of course also make sure MUTE is turned off
Thanks
Tim
Posted on Jul 22, 2009
In Sokkia CX 101 Total Station Error E097 comes ....What is it means and how to solve that ???
CX series
www.sokkia.com.tw/download/??/CX_series_E-copy.pdf
Jan 1, 2012 - CX-105. CX-107. Compact X-ellence Station. CLASS 2 Laser Product ... Except where stated, "CX" means CX-101/102/103/105/107. • The CX ..... Ignoring this indication and making an operation error .... Make sure that moisture or dust particles do not come in contact with the inside .... detergent solution.
Mar 21, 2017 | Computers & Internet
I have a cx-366ce cb cannot hear talking what is wrong
Is squelch turned too high that it is blocking too many signals?
Otherwise, it could be a faulty cable on the mic as the PTT button disconnects the speaker on the CB and a broken wire can cause the speaker to be disconnected.
Jun 28, 2014 | Connex Cx-366ce Night Runner 40ch Cb...
My Mazda CX-9 window will not go up
You will most likely need to replace a part called the window regulator, it is the mechanism that moves the window. As it is a fairly complicated job to replace the regulator have my guess confirmed by a trusted repair shop or the dealer.
Apr 01, 2014 | 2009 Mazda CX-9
Aiwa compact disc stereo cx-nmt320
Check the speaker wires for shorts.
May 05, 2012 | Aiwa Audio Players & Recorders
My printer just makes a sound that wont turn on just makes a grinding sound emplpoyee thouhgt maybe it over heated can u help m fujui cs 550
DId you find a solution to it ? I have a same issue.. Cx-550..Makes turning on noice, fan starts but there are no lights.
Thank you for your help.
Ash -
Aug 25, 2010 | Fuji Printpix CX-550 Thermal Photo Printer
1980 Honda CX 500 won't start but makes clicking sounds
relay is bad or connection is--chec battery cable titeness or starter button--if u hav a kik starter buy a batt eliminator capacitor n hook in place of battery and bike will run like the old days
Apr 10, 2010 | 1982 Honda CX 500 B
I NEED A MANUAL FOR AN AIWA STEREO BOOKSHELF SURROUND SOUND SYSTEM CX_NHMA86
Click Sony-Aiwa Support to download instruction manual of NSX-HMA86 (CX-NHMA86) stereo system.
Apr 28, 2009 | Audio Players & Recorders
Help! no bass sound, low volume
You might want to try using a different size of the earpieces that come with it, and make sure they're inserted fully into your ear. They come with three different size earpieces because people's ears are shaped differently, and having the right size can make a HUGE difference in the sound. If it's done right, it should basically feel like you've just inserted an earplug into your ear.
If that doesn't help, and you've tried another pair of headphones to verify that it's not a problem with your sound source, I would guess you were unlucky enough to get a defective pair.
Mar 17, 2009 | Sennheiser CX 300 Consumer Headphones
Can't get any sound
No, it doesn't need infrared headphones, but it does need to have all audio connection made properly. There is a controller that this was designed to use, model number CY-VM1500. That controller has speaker outputs on it, and the CX-DV1500 must have the RCA audio output jack (red and white rca jacks) connected to the RCA audio input jacks of the CX-DV1500
if you have found this to be helpful, a good rating would be appreciated. Let me know if you require any further help.
You can find the instruction manual at this url:
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/Mobile-Video/DVD/model.CX-DV1500
Jun 22, 2008 | Panasonic CX-DV1500 Car Video Player
Aiwa NSX-DS55 CD Shelf System Logo
194 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
