Question about Video Cameras
Whenever the Sony Z1 encounters high vibration it appears to briefly zoom and/or rack focus. I have the focus on manual, zoom wide open and set to ring and f-stop at 2.4. At the point it does this zoom/focus you can hear the servo in the camera. Is there another way to turn these functions off?
    President:
  • 2,777 Answers
It has built in accelerometers that automatically adjust things even when you try to turn all automatic features off.
Make sure you turn the Auto Gain off. It does not matter what the gain switch is set to if the camera is in auto gain mode. It will ignore your switch setting.
If you have your lcd set to display camera information (zoom, iris, shutter speed, gain, timecode or user bits, etc.) and you do not see "0db" displayed on the screen, then the camera is in auto gain mode.
This could be causing the issue.
Posted on Jul 22, 2009
When the camera is turned on, the lens vibrates briefly for 4 sec.It doesnt matter if its in Auto or manual focus. It happens while turning off the camera as well. I have sent the camera to the Sony...
It is likely to be an issue with the auto focus in the lens. You will get the grinding noise even if you switch the camera on in manual focus, but not if you take pictures in manual focus.
Oct 02, 2009 | Sony Alpha DSLR-A200K Digital Camera
Internal Zoom Malfunction
Hi
Do you mean the 'digital zoom' when you zoom in as far as possible on something or do you mean even with the camera zoomed all the way OUT it still does it?
Yes you should always avoid the 'digital zoom', but if it still doesn't work when zoomed all the way out you need to have the lens cleaned, repaired, or replaced.
We are a digital camera repair business with AFFORDABLE prices. If we can help with your repair then please let us know. Google: darntoothysam
Good luck from Darntoothysam com
Thomas
May 23, 2008 | Sony Cyber-Shot DSC-W7 Digital Camera
Fuji Finepix Z1 Zoom Error
I saw another post in this forum were someone suggest banging it on a table a couple times, not to hard that you'd dent it but a good enough bang. Worked like a charm! I tried the trigger and slide method but while the error message went away the zoom wouldn't focus. Try banging it, it sounds bad but it worked wonders!
Mar 06, 2008 | Fuji FinePix Z1 Digital Camera
Sony Cyber-shot DSC-W55... Problem: "vibration warning" what is this?
My husband just discovered that it has to do with the flash setting. When the auto-flash and flash-on modes are on, it doesn't do it. When the "SL" mode is on - I get the Vibration Warning.
Nov 19, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Losing focus
Usually this is a back focus problem; also called a flange back adjustment.  If the back focus adjustment is possible on this camera, zoom out wide - open iris all the way - and adjust focus and lock position.
Nov 06, 2007 | Sony Handycam DCR-VX2100 Mini DV Digital...
Manual Focus
1) Press and Hold the FOCUS button until to you "MF" appear in the lower left corner of the LCD Display on the back of the camera. Then you can release the Focus button. 2) Press and Hold the DISP/i button to see the Manual Focus Range. 3) While holding the DISP/i button, use the Tele/Wide Zoom Key to set the desired Manual Focus. You can see the focus change as you toggle the zoom key. 4) When you are ready, release the DISP/i button and Press the Shutter Button to take your picture. *Press the Focus Button to return to Auto Focus / Macro options
Sep 15, 2005 | Toshiba PDR-M71 Digital Camera
Manual focus
Sep 15, 2005 | Toshiba PDR-M81 Digital Camera
Focusing the 770
Tom, It's best to do the zoom first, then focus (if you are using the autofocus).
Sep 11, 2005 | Sony Cyber-Shot DSC-D770 Digital Camera
IESP auto focus
iESP is the default auto focus setting for the C-8080 Wide Zoom camera. It uses a contrast detecting system to analyze the entire image by comparing the subject against the background to achieve focus. When the shutter button is pressed half way on the C-8080 Wide Zoom, the AF target mark automatically moves to an area of the image where it finds the optimal contrast.
Sep 04, 2005 | Olympus Camedia C-8080 Wide Zoom Digital...
IESP auto focus
iESP is the default auto focus setting for the C-5060 Wide Zoom camera. It uses a contrast detecting system, to analyze the entire image by comparing the subject against the background to achieve focus. When the shutter button is pressed half way on the C-5060 Wide Zoom, the AF target zone automatically moves the to an area of the image where it finds the optimal contrast.
Sep 04, 2005 | Olympus Camedia C-5060 Wide Zoom Digital...
Video Cameras Logo
22 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
