Question about Freezers
Cannot control internal temp plus clicking relay on control panel.
The digital temperature display started flashing and a relay was vibrating in tha background. The only way to silence the relay was to activate the fast freeze button, also the main acoustic alarm was indicating that there was a fault with the freezer. There is no control of the internal temperature, we defrosted the freezer and put the freezer back on for 24hrs but the internal temperature stayed at +6 degrees Centigrade.
  • mdpd Dec 15, 2007
    On new but out of date guarantee ZUD 9100 F Zanussi freezer acoustic alarm keeps ringing. Won't turn off when suggested button is pressed and doesn't turn off when freezer has been on for a day. Help!
Where is the fast defrost button on Kenmore chest freezers?
Posted on Jun 27, 2008
Defy 350lt upright freezer red alarm light flashing the light start flashing and the food started defrosting
Check for proper door closure or internal light function first
Next, check temp. control settings. If all checks ok, call a tech. to fix it
Sep 21, 2017 | Freezers
With deluxe Electronic Temperature Control Freezer control panel shows "OF" and I can't restart the freezer
Search Results
    Freezer electronic temperature control manual... ' Sears ... > Ask an Expert
    Jul 5, 2012 - I have a Kenmore elite freezer with electronic temperature control. freezer was delivered yesterday, the control panel is stuck on of, ... an electronic control on front. the display is showing hi temp and door ajar. also an l in ...
    Control Panel is not working right - Samsung
    Samsung ElectronicsSep 3, 2015 - In case of wrong temperature display, possibly door opens so inside ... If the control panel is still not lit up after you plug the refrigerator back in, it may ... When initial installation, Temperature will show current temperature for a ... When the refrigerator/ freezer reach the set temperature, the blinking will stop.
    Adjusting Side-bySide Refrigerator Temp Controls - Actual ...
    ? 3:50
    Jun 27, 2010 - Uploaded by GE Appliances
    CAN I TURN OFF THE DIGITAL CONTROL ON FREEZER AREA ONLY. ... I need to know How to reset this kind of refigirator, same front panel ... When you try to set the actual temperature, does your control show your new ...
    Electronic Temperature Controls - ManualsLib
Feb 03, 2016 | Freezers
Moved, freezer wont run properly, food thawed out, digital readout display flashes E and then flashes #9 alternately. what do I do?
E9 is a defective Temperature Control
  • You will need to replace Part # 297216004 It should be mounted on the evaporator behind the panel in the inside of the freezer.
  • I am including a picture and a link, it should be #21 on the diagram.
  • You have to unscrew the Knob and the 3 screws holding the temperature control Cover and the one holding the probe/sensor (#24 on diagram)
Best of Luck,
http www searspartsdirect com model part FFU14K0DW0 1428 0142000 R0405108...
Jul 08, 2015 | Frigidaire 14.1 cu. ft. Upright Freezer...
Www frigidaire com MY FFHS2313LM6 the temperature is sky high and won't cool down.
Thank you for your post, friend!
I see your Frigidaire refrigerator is not cooling and you have performed a reset on your appliance by unplugging it. You could be experiencing an issue within your control panel or sealed system. I would recommend seeking assistance from a professional to come and diagnose your appliance for the proper repair. Hopefully this is helpful. -Matt
Aug 25, 2014 | Frigidaire FFHS2313LM 22.6 cu. ft. Side By...
Why wont my refrigerator run. Constantly beeps.
The beeping is typically a code. Is there an addition of a led flashing anywhere you can see?
Jun 15, 2014 | Frigidaire FFHS2313LM 22.6 cu. ft. Side By...
Hello Michael - Sounds like the temperature control was accidently turned OFF. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try activating the freezer by pressing the UP arrow until display shows "4" or desired setting. Allow 24 hours for temperature to stabilize. For future reference you can lock the control to keep from accidently changing the temperature setting. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you.
Jul 01, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Hotpoint Whirlpool upright freezer. The lights all work but the temperature is slowly dropping - now only -7 C and the freezer is silent. Before this the temp lights kept flashing and vibrating (quite...
Problem has sorted itself out. We removed and gave away quite a lot of food from the freezer and cleared away some ice that had accumulated on the temperature sensor. When we checked this morning the temperature had returned to -24 C so we don't need to go in search of a new freezer today, thank goodness!
Dec 27, 2009 | Whirlpool Freezers
Whirlpool AFG 7080 Freezer - Relay noises
It sure sounds like you have a problem with the board. It may just be a dry joint or a faulty component. Normally one would replace the board.
Nov 01, 2007 | Freezers
Freezers Logo
305 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
