Question about LG WM1812C Front Load Washer
LG Front loader
How do I replace the gasket?
Water leaking from door of front loader
Jan 19, 2014 | LG WM-2277HW Front Load Washer
I have an LG front loader washing maching, model# WM2277H* I have changed both the hot/cold water value and the washer is still leaking.
Common causes
door gasket damaged(torn)
Dispenser fault
Lint filter door not fully closed
It sounds like you might have a damaged outer bowl, broken by a foreign object(coin, wire,screw)
Mar 25, 2011 | LG WM-2277HW Front Load Washer
My front loader gasket is permanently stained with mildew. Can I get a replacement gasket?
Washing machine door gaskets are available for any make of washer.
Contact the manufactures direct, or look on the internet.
Try E-Bay as well, you should not have any trouble obtaining one.
Dec 15, 2010 | LG Washing Machines
LG front loading washing machine. SEVERE water leak from front door. Gasket has been checked and is OK. Seems there is quite a bit of 'play' (i.e. slack or free movement) in the front door since if you...
This is a very common problem with the LG front loaders, and some other front loaders for that manner. There was a few recalls on them and some parts that were supposed to fix the issue. Even if the gasket looks ok i would replace it, as they have updated the design of the gaskets to fix issues on models that were having issues leaking. Most of the time its just a bad gasket and you cant really do anything other then replace it. Front load washers are about the worst appliance made today in my opinion, the repair shops around here are always full of broken and leaking front loaders. I have fixed quite a few myself, some work ok after the repair, some fail again in a matter of months, its a real duck shoot on them. The biggest failure rate though is the gaskets! And most of the time they look ok but still leak like a screen door.
May 04, 2017 | LG WM-2077H Front Load Washer
Front door leaks
The door gasket is bad this page will help
I know the page says GE front loader but replacing the door gasket is the same.
Oct 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Leaking water
If your LG washer is a front loading machine, the bellow or gasket may need to be replaced. this is a common problem with front loaders as the bellow can be pierced by anything that may be in or even on your clothes. I would visually inspect every inch of the front bellow to see if there is a TEAR or PIN HOLE. this can be hard to detect sometimes but can save you alot of grief. hope this helps
Oct 11, 2009 | LG Washing Machines
How do I put a door seal gasket back on my LG front loader?
If it is apparently just too tight to go back on, then a good place to start is petroleum jelly (vaseline) on the drum where you are trying to fit the gasket to help ease it on. The other possible solition is to remove the gasket completely, soak ot in very hot water for a few minutes and then try to fit the difficul part of the gasket you are struggling with first, then fiot the other end
Aug 29, 2009 | LG WM2496H Front Load
LG WM1812C Front Load Washer Logo
103 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
