SOURCE: I.P Brake light is staying on.. what does this mean
Offhand, the brake light warning on most dashboards would indicate that the hand/emergency brake is engaged. If even when the hand/emergency brake is disengaged or is in normal position and the light is still lit, it could indicate that:
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
SOURCE: getting access to the radiator cap on the 2000 mercury sable?
there may be a shield in the way it is just retainers on take out retainers then you should be able to get to cap
SOURCE: 1996 Mercury Sable LS. Problem: Dome light and
have you checked to make sure the dimmer switch isn't turned all the way up? if the dimmer is turned all the way up it will keep the lights inside the car on. check the dimmer switch
SOURCE: 2000 mercury sable drive belt
For VIN 2 FLEX Fuel:
For VIN U and S....with A/C:
PLEASE DON'T FORGET TO RATE!!!!
SOURCE: dashboard lights
Transaxle issue according to the manual. I have the same car. After I had to have the tranny rebuilt at 126K it started to blink. When I had a mechanic check into this deeper it turned out to be a bad transmisson tempature sensor. About a $400 fix.
