Loading applications & start up problem
I keep getting the application failed to intialize properly (0xcoooooo6). As well as Visual C# command line compiler has stopped working correctly. I have tryied restore but it does show a go back date & will not let me put one in.
  • 1,555 Answers
Nice virus I've seen it many times, try to repair your operating system if, it allows. Otherwise you will have to format. no other solutions. Even the latest updated antiviruses can't clean it.
Posted on Jul 22, 2009
My Drive C has 0 MB free disk space and have been advised to remove programs.Can I remove any Microsoft Visual C++ Redistributable?There are 6 in all.Do I need them all?
A Microsoft Visual C++ 2005 redistributable cannot be replaced by a Microsoft Visual C++ 2008 one. The binding would fail and any program that depends on the Microsoft Visual C++ 2005 redistributable will report "This application has failed to start because the application configuration is incorrect. So I think it would be best to leave them.
Apr 16, 2017 | Microsoft Computers & Internet
Error 0xc000007b
fix 0xc00007b error "the application was unable to start correctly"
there may be multiple reasons as to why you might receive 0xc00007b error when trying to run an application on a windows machine. 0xc000007b error usually comes from mixing up 32bit environment with 64bit one. For example 32bit application loads a 64bit dll causing 0xc000007b error.
Solution 1
In most cases it's .NET framework causing issues. This can easily fixed by re-installing latest .NET framework from [link]
Solution 2
Re-install the application that you are trying to run. It sounds simple but the application data files could be corrupt or missing. This could be caused by a installation that did not complete successfully or by a virus.
Solution 3
Running the application as an administrator could fix this error. Right click on the program shortcut or program .exe file, then click on Properties, and on the Compatibility tab. Check the Run this program as an administrator box, and click on OK
Solution 4
Restart your computer as some applications require restart after installation to function properly.
Solution 5
Run Windows update as it can provide application fixes and updates. Furthermore it installs missing drivers and updates the outdated ones like graphic card drivers. Windows 7 / 8 / 8.1 users need to search for "windows update". select all important and optional updates and click on the "install updates" button. If you use Windows XP navigate navigate to Windows Update by choosing Start > All Programs > Windows Update. When the scan is complete,Click the Review and Install Updates link. Finally press the "install now" button.
Windows 7 / 8 / 8.1
Windows XP
Solution 6
manually update the application if possible.
Solution 7
re-install Microsoft Visual C++ from [x32 link] or [x64 link]
Solution 8
re-install DirectX [link]
Solution 9
Many times hard disk problems can be repaired using the chkdsk command. If you are using windows 7 press the start button in bottom left corner of your screen. If you are using windows 8 / 8.1 press the windows key .Search for "cmd" and Right click it and select "Run as administrator". Windows XP users Click on start > run. In the Run box, type in "cmd" in the box.
Windows 7:
Windows 8 / 8.1
Windows XP
A CMD window should appear. In that window you can just type it as you see "chkdsk c: /f /r". If you have more then one drive or partition, you will need to tell it the disk (chkdsk d: /f /r).
If it is the primary windows disk c: it will ask you to schedule it for next boot. When you restart, it will do a chkdsk for you before even getting to the login screen.
Solution 10
This solution only works for a 64-bit system. It requires replacing files is system32 directory so be careful. Only attempt this solution if you are confident and if other solutions have failed. When Microsoft Visual C++ Redistributable Package is not properly configured it may cause 0xc00007b error. Firstly download the zip file [link] and decompress it. Reboot in safe mode and go to C:\Windows\System32. copy all files included in the zip package (mfc100.dll, mfc100u.dll, msvcr100.dll, msvcp100.dll and msvcr100_clr0400.dll) to C:\Windows\System32 replacing the current ones. After that reboot in normal mode.
If all the solutions above haven't worked i would consider backing up data and performing a clean install of windows.
Jan 11, 2016 | Dell Inspiron Computers & Internet
Bcmwltry.exe-application error The application failed to intialize properly(0xc0000034). click on OK to terminate the application.
Read the article in the link below. It's a process that you can get rid of.
http://www.ehow.com/how_5157007_rid-bcmwltryexe.html
Apr 21, 2012 | Dell Computers & Internet
The application failed intialize properly (0xc00001350)click on OK to terminate the application.
This program will help you fixing the problem. The oxooooo error code is occurring when there is some hardware conflict or when the system file is missing.
May 12, 2011 | Video Game Consoles & Games
"The application failed to initialize
Visual c++ runtime is required by most of the applications developed with visual c++.
Download and install:
http://download.microsoft.com/download/vc60pro/update/1/w9xnt4/en-us/vc6redistsetup_enu.exe
Then reboot computer, 3ds max should start without problem.
If it still persists, please contact me.
May 08, 2011 | Computers & Internet
My computer windows station is sutting down repeatly and before shutdown show a massege, that is the application failed to intialize because the window station is shutting down
Shutting Down is powering off your computer, That message is just telling you that windows is turning off your computer and closing all programs. If an application fails to initialize it just means it can not start as windows is shutting down
Oct 07, 2010 | Computers & Internet
I am getting "The application failed to initialize properly"
you will need to reinstall the yahoo messanger application.the application has gone corrupt
Nov 29, 2009 | Yahoo Messenger
Computers & Internet Logo
162 people viewed this question
David Payne
David Payne
