Question about Lanier Office Equipment & Supplies
I have a Lanier LD445c how do I scan a document that is 4"X11" it keeps telling me it can't find the original size?
  • Lanier Expert
  • 398 Answers
Try thru the doc feed, or if off the glass special original might help. -Carl
Posted on Jul 22, 2009
How do I Remove the hard drive from Lanier printer model number LD445C
It is located behind the panel where your Ethernet cable plugs in. The easiest way is to remove the rear panel. Then remove the metal panel. From there you should be alright on your own.
Oct 14, 2014 | Ricoh Lanier Ld445c Ld435c Ld430c Magenta...
How to print enevelopes without them jamming in a lanier ld425c
in bypass put envelopes in short edge first, push the # button, select size of envelopes and OK it, (needs to be told of size)-Carl
Aug 28, 2014 | Lanier Ld445c Ld435c Ld430c Ld425c Ld420c...
How do I receive a scan to email
You have to set up the settings in user tools on the operation panel.
Apr 25, 2014 | Lanier Ld445c Ld435c Ld430c Ld425c Ld420c...
I need to remove email contacts under the scanner option on a lanier ld445c
Hi lance lebian
I have the manual for this printer if you would like to download follow the link cheers nikki
http://www.lanier.com/downloads/manuals/Color_MFP/lc435opguide.pdf
Cheers nikki
Jan 20, 2011 | Office Equipment & Supplies
Where is the toner waste on the Lanier LD445C?
The only reference to "waste" is the punch waste. I could not find the "Toner waste" in the manual:
Open the Finisher front cover.
Pull out the Punch waste box carefully.
http://www.lanier.com/downloads/manualFrame.aspx?path=http://support.ricoh.com/bb_v1oi/html/oi/lan_u/model/mp35/mp35en.htm
Nov 30, 2010 | Lanier Office Equipment & Supplies
Tray 1 is not set correctly, yet everything is set right. Help
81/2 x 11 is not a custom paper size. Set tray 1 to 81/2 x11 plain paper and set your print driver the same way. the descriptions have to match or it will not print.
Jan 05, 2010 | Lanier UNKNOWN
Lexmarkx125 will scan larger pictures but smaller ones.
Here are some instructions from the Lexmark X63 which was similar to the X125.
The Lexmark X63 uses a sheet fed scanner, intended to scan 8 1/2 x11 inch paper.
  • To scan a document between 5 1/2 inches and 8 3/4 inches wide, center the document between the paper feed guides leading into the scanner and make sure the document is held straight,. Do not bend the document as it is fed into the scanner.
  • To scan photos or pictures that are 5 1/2 inches wide or smaller, you will need to use a flatbed scanner, or "mat" the image into a regular letter-size paper and scan the entire page. When the scan process is complete, crop out the picture using the AUTO CROP option in the Scan and Copy Control program or the photo-editing software.
Feb 27, 2009 | Lexmark Pro X125 All-In-One InkJet Printer
How to convert this copier from inch to metric system??
SELECTING THE ORIGINAL SIZE
If you loaded a non-standard size* original or the original size was not correctly detected, set the original size manually.
Perform the following steps after placing the document in the document feeder tray or on the document glass.
1 Press the [SPECIAL FUNCTION] key.
The special function
screen will appear.
2 Select "ORIG. SIZE ENTER" from the
menu with the [ ] or [ ] key.
3 Press the [OK] key.
The original size selection
screen will appear.
4 Select the original size with the [ ] or
[ ] key.
The selected original size
is highlighted.
• To select an AB original size, press the [ ] key and
go to step 6.
• If you selected "SIZE INPUT", follow steps 4 through 6
of the procedure in "USING THE BYPASS TRAY TO
COPY A SPECIAL SIZE ORIGINAL" (page 51) to set
the horizontal and vertical dimensions of the original.
5 Press the [OK] key.
You will return to the base
screen and the selected original
size will appear in the original
size display.
Selecting an AB original size
6 Select the original size with the [ ] or
[ ] key.
To return to selection of inch original sizes, press the
[ ] key to return to step 4.
7 Press the [OK] key.
size display.
* Standard sizes:
The following sizes can be detected correctly: 11" x 17", 8-1/2" x 14", 8-1/2" x 11", 8-1/2" x 11"R, 5-1/2" x 8-1/2"
(A3, B4, A4, A4R, A5). If a non-standard size original is placed (including special sizes), the closest standard
size may be displayed, or the original size may not appear.
Note
DUPLEX
SPECIAL FUNCTION
ACC.
DUPLEX SCAN
DUPLEX SCAN
SPECIAL FUNCTION
SPECIAL MODES
ORIG. SIZE ENTER
PAPER SIZE SET
DISPLAY CONTRAST
GH
PQR
DUPLEX
SPECIAL FUNCTION
DUPLEX SCAN
SPECIAL FUNCTION
SPECIAL MODES
ORIG. SIZE ENTER
PAPER SIZE SET
DISPLAY CONTRAST
GHI
BACK OK
ORIG. SIZE ENTER
11x17
8 x14
81 x11
INCH
ORIG. SIZE ENTER
11x17
8 x14
8 x11
INCH
To cancel an original size selection, press
the [CA] key.
OK
ORIG. SIZE ENTER
A3
B4
A4
AB
OK
Note
Oct 02, 2008 | Sharp AR-207 Copier
Lanier LD 325 Printing labels
4 x 6 might be too short for that copier to run on. The bypass tray might take it if you load it so that the 6" side is the longest end that the copier is feeding throught the machine.
If you have it interfaced as a printer, goto avery.com and download their label making software and find the template that matches your label stock. The software works with Microsoft Office files as well.
Jul 18, 2008 | Office Equipment & Supplies
141 people viewed this question
Top Lanier Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
Anthony Karuku
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
