Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
My girlfriend has a 1/2 hp Craftsman garage door opener (model 139.5398511) which operates fine when cool but after several uses or later in the day the opener only partly opens the door (the height varies from a few inches to a couple of feet), the light blinks once and the motor stops. The door itself opens easily when disengaged from the chain. She accidentally installed high watage light bulbs at the opener which created enough heat to melt the plastic light covers. Could the logic board have been damaged by these light bulbs?
    President:
  • 3,197 Answers
Remove the cover and take a good look at the drive gear. It is white nylon and is just in front of the motor. Make sure it is alright. It will be obvious if it is starting to strip. If it is o.k. the look for the up force control on the rear of the motor unit near all those white wires. Increase it a quarter turn.
Posted on Jul 22, 2009
  • 42 Answers
there is little chance for the board to be affected by the melting of plastic covers of light. if the circuitry is damaged by the heat, you'd notice the problems immediately, if it is working fine now, then there is no chance for this incident to affect the working in future.
cheers
Don't know Mod. No. lost installation manual, approx. 5 yrs. old Need installation manual.
About 496,000 results (0.43 seconds) Search Results
    [PDF]GARAGE DOOR OPENER Model 3265 1/2 HP ... - LiftMaster
    www.liftmaster.com/.../en.../tucmanuals/114a3044.pdf Chamberlain GroupFasten the manual near the garage door after installation. .... This garage door openerhas been designed and tested to offer safe service provided it is installed, ...
    Manuals Download Craftsman Garage Door Opener Model ...
    www.craftsman.com/search=manuals%20download%20crafts...
    CraftsmanCraftsman has the best selection of Garage Door Openers in stock. Get the Garage Door Openers you want from the brands you love today at Craftsman.
    Craftsman 1/2 HP Chain Drive Garage Door Opener - Sears
    www.craftsman.com > ... > Garage Door Openers
    Craftsman1/2 hp Chain Drive Garage Door Opener Opens by Remote, Inside and from Car Enjoy a great end to every day by ... Owners manual - English (Warranty).
    Free Craftsman Garage Door Opener User Manuals ...
Feb 03, 2016 | Building Materials
How do I update software
Feb 03, 2016 | Kenwood DNX-690HD eXcelon DVD Receiver...
I have an old craftsman 1/2 hp door opener. It
You may have a bad wall control. Try disconnecting it from the opener and try. Otherwise it is time for a new model.
Apr 26, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2 HP garage opener opens only 6 inches
Remove the cover and check the drive gear. It is white nylon and is just in front of the motor. It may be stripped. Take a close look at those door springs. They can sometime appear to be okay when one is broken.
Oct 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garage door 1/2 hp opens. Keeps open for no apparent reason. In the middle of the night and sometimes during the day, How can I fix
Most commonly this is caused by a bad wall control or the wiring going to it. The wall control goes bad from constant use and the problem with the wiring is caused by the staples most installers use. The staples cut through the insulation and cause intermittent shorts. I would remove the wall control and check it for a few days and if it happens again you can remove the wire going to terminal #1 on your motor unit. That will eliminate the wiring. Be sure to remember where the wires go on the back of the wall control as they are color coded. One is solid white and the other is white with a red stripe.
Aug 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
1/2 HP Craftsman Garage Door Opener works but lights don't
I think you are saying that normal incandescent bulbs do not work. If that is correct you should unplug the unit and using a small screwdriver reach into the socket and pull out slightly on the center contact.
Aug 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Main light on will not come on when door is opened/closed
For some reason, the bulbs I tested that worked somehow didn't work correctly when inserted into the door opener. We opened another set of bulbs we purchased and what do you know, the light now works. I don't fully understand as the other bulbs did work just not in the garage door opener.
Apr 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opened, won't close
If you can press and hold the wall button and the door will go down, you have a photo eye issue. Check the photo eyes at the bottom of the door.
Jan 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
210 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
