Question about HP PSC 2410 All-In-One InkJet Printer
I have a HP 2410v printer just chanced both inks now its printing like in X-ray thats what the oprints look like,what do I need to do to fix this issue?
  • 72 Answers
After changing the cartridges you have to allign cartridges. Remove the cartridges the place it again in the printer. Once you do that it will print alignment pages automatically. If it doesnt print that turn printer off and then turn it on again.
Posted on Jul 22, 2009
Stopped printing yellow
Out of yellow ink?
If your ink is full, then you most likely have a dried up yellow ink path or the sponge at the bottom of the printer is full and preventing ink to pass through to the paper. Chances are, you are plugged up and need a new printer - HP is water based and if not used on a constant bases, the ink will dry and cause clogging.
Aug 05, 2014 | HP C6280 All-in-One Printer
Our printer is a hp 7200 ,refil ink cartridges, and because we didn't use hp ink all printing is shut down, can you help? Thank you ****
Unfortunately there is no work around for this.
All HP printers requires genuine HP ink cartridges,also refills are not allowed.
HP ink cartridges has a mechanism only compatible with HP printers that sends a signal to the machine when a non HP ink cartridge is used. I highly suggest you use a genuine HP ink cartridge, there is also a high chance if that your printhead or printing mechanism might be damaged.
Check for ink leaks right away, also make sure to clean the printhead with lint free cloth and use bottled water only. Make sure not to touch the electrical contacts found on the bottom of the print head.
Jun 25, 2011 | Office Equipment & Supplies
How to refill the cortrideg hp deskjet f4288.
Hi
the most important is to remove all
the air from the cartridge that has
left inside durring refilling that is why
professionals are using special machines
that refill in 0 air πρεσυρε using vaccum pump
you can check here a video on how to refill
with out any special equipment
Hope I had help you
Dec 08, 2010 | HP DeskJet F380 All-In-One Printer
Ink system has failed. Unable to print. Refer to printer documentation Error: 0xc18a0201
I have a HP photosmart C5180 all in one. It has an error message that says....Ink system failed unable to print refer to printer documentation error OXCa0501. By chance would you know what to do to fix it? Thanks
May 25, 2010 | HP Photosmart C5180 All-In-One InkJet...
How do i tell if i just need new ink cartridges or there is a problem with the printer. Printer hasn't been used in a few months and printing is stripey and faded.
If you take out the inks and blot them a few times on a damp paper towel, folded so ink doesn't get on your table, it should clean the ink nozzles. Chances are that if that doesn't work, you only need new inks, printer sounds fine.
Jul 21, 2009 | HP DeskJet F380 All-In-One Printer
How to wirelessly print to HP 2410v Photosmart printer
This is the official how-to for network setup from HP:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00781863&lc=en&dlc=&cc=us&product=303759&lang=
Introduction Print the network configuration page and obtain the IP address, subnet mask, and default gateway address for the printer. Printing the network configuration page
  1. Press the Setup button.
  2. Press the arrow buttons to select Network and then press OK .
  3. Press the arrow buttons to select Print Network Configuration Page and then press OK . The Network Configuration Page prints.
Obtaining the IP address, subnet mask, and default gateway address The IP address, subnet mask, and default gateway address are printed on the Network Configuration Page
The manual link is here:
http://h10032.www1.hp.com/ctg/Manual/bpu70241.pdf
Hope this helps:
WizardRepair
Jul 18, 2009 | HP Office Equipment & Supplies
HP Photosmart C7280 still prints in color
Why don't you try changing the Setup for your printing to Black & White or Grayscale in your computer's software: File/Print/go to the printer's settings and disable anything color. As for the cartridge, it's probably the cartridge. If you have an extra, why not swap it out? I believe the brains in the cartridge contacts might not be working properly OR your heads need to be cleaned OR you better stick with HP original cartridge to make sure it's not the printer. I used to use "odd" ink and even refilled ones and shortly thereafter my old printers would die. Not taking a chance on this HP. I love how it prints when it isn't jamming the paper! Need help on that problem pronto.
Jan 06, 2009 | HP Photosmart C7280 Laser Printer
HP Photosmart C7280 Ink System Failure
Contact HP for Care at 1-800-585-2494 Toll Free
Oct 08, 2008 | HP Photosmart C6180 All-In-One InkJet...
Ink light is on and it will not print. HP 335
Hi
Chances are you need to replace the ink, it may be defective or out of ink. try taking it out if its brand new and reinstall it, if all fails call HP for replacement of the ink cart.
Hope this helps
Sep 04, 2008 | HP Office Equipment & Supplies
Black and white printing not working
sounds like its a expired ink issue. on alot of the hp photosmart printers the ink has a expirey date on the carts the best solution would be to contact hp and chances are they will send you free carts if your ink has been expired. when a black ink is almost out most of the time it trys to draw ink from the color carts mixing to make the appropriate color.
but you can also try the following.
See the instructions for
calibrating a print cartridge in
the Care and Maintenance
section of the HP Photosmart
Printer Help.
Aug 11, 2008 | HP PhotoSmart 7960 InkJet Printer
HP PSC 2410 All-In-One InkJet Printer Logo
63 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
