Question about Briggs & Stratton Garden
Changing motors Hi I am changing my old 11hp side valve Briggs & Stratton for a new 12/1/5hp ohv and there is a set of wires from the carby !!BUT i cannot figer out where they should go ? Please help Regards Denis
  • 54 Answers
Just supply the grey wire with ignition power ie key on power. then the fuel shut off will work fine. if no ignition on mower place a toggle switch in the dash and a fused link to the possitive side of your battery to power up the solenoid. if now power available, unscrew the solenoid and remove the pintal then screw back in, it will not shut off fuel then.
Posted on Jan 17, 2013
  • 202 Answers
I think what you are describing is the fuel shut off solenoid. i am not sure how it wires up but the workaround i have used is to replace the carb with an older model,same approx engine. they dont retool the blocks. find an older model 12 1/2 horse without them you should be fine.the wires if i remember right is gray and black from the solenoid
Posted on Jul 22, 2009
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 18 Answers
On the newer engines there is a electric shut off valve on them that's what the wires are for. when you turn key on this will allow the needle pin to open for the fuel to flow into bowl. you need to wire it up to your switch and have juice going to it when the switch is in the on position. good luck!!
Posted on Mar 25, 2013
Runs good-but has no power under load
reset the valve clearance to .010 and .012 as they will holding open when hot and upsetting the carby flow
May 27, 2013 | Briggs & Stratton Briggs Stratton Vanguard...
Need valve clearance for 24 ohv engine,4457770168e1
You should be able to get the settings from the Briggs & Stratton Website
Aug 24, 2010 | Briggs & Stratton Briggs Stratton Intek V...
16hp B&S ohv runs for 30min under load then stops 5min cool off starts runs 30 min new coil plug gas is venting adj valves
could be fuel vaporising.... re rout the fuel line away from heat sources this may help or the fuel is not getting to the carby fast enough....check fuel filter and lines for cleanness .
Jul 22, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Jd tractor 11hp briggs engine has no stark
I would check the stator which is located on the top or side of the motor, this is what produced spark and if there is rust on it it will lose spark. so basically remove the fan housing the top of the motor and you should see it either on top or directly on the side i believe it has one wire going to it green in color and is held down by two bolts. good like look out for the rust
Apr 17, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and stratton platinum 5.5 hp ohv i/c engine
The carby probably has a block either in the idle, jet or float valve. These are both internal to the carby. To fix this, you will need to pull the carby off the engine and get it serviced by a tradesman. If you feel keen, split the carby apart, then run a very small drill bit (.38-.7mm) through the Jets by hand. Also spray carby cleaner in there and blow out with air blower.
Mar 14, 2010 | Mtd Troy-Bilt Bronco OHV Tiller
18 HP V tech B&S single is smoking only 4 years old
18HP vertical Briggs & Stratton vtech twin ohv; can't find oil leak; motor runs great; is leaking onto housing where motor is bolted to; any suggestions where leak may be coming from????????
Jul 01, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
216 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
