Question about HP PhotoSmart C4480 All-in-One Printer InkJet
Exactly the same helpppppppppppppppp
Have an HP Photosmart C4440 all in one printer, scanner, copier and for some reason every time I scan or copy a document, picture, etc. it comes out solid black. It worked fine when I got it and all of a sudden it started doing this.
I also printed an alignment page. When it told me to scan the alignment page, I tried that too, but it did not recognize it. Printer always gives me a display that says ''turn off and back on again''
Printing is also sometimes a task. It will often tell me to turn on and back off again when trying to print a document.
I'm ready to throw it out the window! Please help if anyone has a solution. Thank you!
  • 1,555 Answers
I'd suggest you to take the printer to some other pc alongwith its driver CD install it on that PC and check for the results. Its the easiest way to find out whether the pc is the prob or printer. if the pc is the trouble which i think it is, the printer is all ok. then just repair the operating system.
Posted on Jul 22, 2009
    Brigadier General:
  • 10,406 Answers
When it was working correctly, did you see any lamp lighting-up the surface that is being scanned?
Now, do you see that lamp working as before?
If so, then getting an "all-black" scan means that the scanner is not detecting any "light" parts on the document being scanned.
Yes, it's time to take the printer to a recycling-station;
advertise the ink-cartridges and power-cord and power-adapter online, e.g., 'www.CraigsList.org' or a local "FreeCycle" mailing-list.
Why won't my HP Photosmart 5510 copy?
first you confirm scanning is working or not if it is working fine there is no issue with printer, if it is not working problem found with scanner assay you need to contact hp service center....
May 04, 2014 | HP Photosmart 5510 Wireless e-All-in-One...
How can i scan i picture with my Hp photosmart
You need to go into the software settings and allocate where the files are saved to. All scanning software has this option.
Mar 23, 2010 | HP Photosmart C3150 Printer
HP Photosmart C4440 Printer sounds like a machine gun
i have the same printer and the same problem--did you ever find a solution?
Oct 01, 2009 | Office Equipment & Supplies
Message says "Scanner Failure" and "Unable to scan or copy"
Obviously its scanner error,the whole scanner assembly needs replacement.It could be the bulb or the scanner board, but upon replacing it needs both.
Sep 17, 2009 | HP Photosmart C5280 InkJet Printer
Printer and copier work fine- scanner says USB not connected.
I had this same problem and it is fixable, but not the way you would probably like, though you can still scan with the printer. You just have to open the Paint program and click from scanner or camera, and then choose your printer and click scan preview, and then scan, it works just fine but its a little time consuming.
Jun 01, 2009 | HP Photosmart C4280 All-in-One InkJet...
My printer works but my scanner doesn't
Do one thing, remove the software from control panel add/remove programs. Then reboot the machine. Put a CD again, connect your all in one and run the setup.
Apr 03, 2009 | Office Equipment & Supplies
Hp photosmart c6180 all in one printer will not scan or copy
The scanner bulbs ahve gone bad.U need to get it them replaced.Before that try resetting the printer using the # and the number 6 buttons,holding them down and then inserting the power cord at the back of the printer.
see if it works.
Mar 25, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP PhotoSmart C4440, All in one will not scan image to computer. I receive an error message stating: HP CUE - Scanning Flow Component has encountered a problem and needs to close. Details from error...
I did not find a "solution" to the HP CUE - Scanning Flow Component problem. However, I did find a work around the problem. I use my graphics editing program to Import/ Acquire/ From Twain and this will allow me to scan from the printer to my graphics program. I can save the image from there.
Better than not being able to scan to my pc at all ...
Sep 26, 2008 | Office Equipment & Supplies
HP Photosmart C4280 All-In-One Will Not Scan
hi
i had the exact same problem and i installed and un-installed
over and over again
and then it hit me !!!
why bother ??? , just download a 3rd party scanning software like "VueScan" or any other you find on google and it does the job !!
it's light, recognize the scanner (C4280) automatically and scan !!
cheers
Sep 22, 2008 | HP PhotoSmart C4280 Laser Printer
HP photosmart c7180 scanner failure
you can run a reset on the printer and clear the scanner failure yourself. You can find the instructions at: http://www.inkbank.com.au/webcontent21.htm
good luck...
L.C.
Apr 04, 2008 | HP Photosmart C7180 All-In-One InkJet...
HP PhotoSmart C4480 All-in-One Printer  InkJet Logo
475 people viewed this question
Seeker5211
Seeker5211
