eBayhttps://www.ebay.com > itm For Deep Carpet cleaner with serial # less than A13376 need to make it fit (cut out few plastic ribs). Condition. New. A brand-new, unused, unopened.
I had same problem. Remove all fluid from machine, I used a wet dry vac. As someone else said unscrew the 2 screws that hold the filter basket. Take out the filter basket and clean thoroughly. Find plastic hose that is now visible under basket and pull up and remove that (noticing where the slot is to put it back when finished) and pull the screen off top of hose and clean that as well. I then vacuumed out that hose with my wet dry vac. Reassembled everything and now works perfectly.
I had the same thing happen to mine. I looked at the hose in the water tank and the screen at the end if the hose was slimy and clogged. I took the screen off and cleaned it up, put everything back together and it works like new again. Only 2 screws and a screen.
Not to be negative but I fixed one Bissell, and it worked for a while then it broke again. My Daughter bought one and it broke on her after using it only 3 times.
buy the rug Doctor or some other brand . That is my advise. Otherwise you will have to keep fixing that one.
Dont fill water tank so full and change water more often. Home units are made for smaller jobs thats why rug doctors and others unit can be rented. Different systems altogether.
