Question about Shure Beta 52A Professional Microphone
Wire need wire diagram for cable connecter
    Scholar:
  • 113 Answers
Hi Pin 1 earth, Pin 2 hot (red), Pin 3 Cold (black). If its going to a jack plug, then can connect 1 and 3 together to earth and 2 goes to tip.
best of luck
Posted on Jul 22, 2009
Wiring diagram 1999 buick century. Starter engages when battery cables are bolted to battery.
-the wires are not correctly re-installed for the starter.
- u may need wiring diagram
Did you take pictures before you took it apart, or did you tag wires before unconnecting them.
Mar 12, 2015 | 1999 Buick Century
I need a diagram to install a new cellenoid
Should be fairly simple..you should have two large connections with nuts...on the solenoid, one comes from the battery cable the other to the starter cable ..then there should be a smaller wire coming from your keyed switch...the switch activates the solenoid and in turn makes the hard connection from battery to starter.. just connect the wires and you should be good to go..you may have one more wire it would be the ground wire..if you took one off..there should be a connection to the tractor body close by the solenoid ....good luck..
Oct 05, 2014 | Garden
I want to hook up a slim sub for my truck using this amp. how can I do that? Because this amp plays everything not just the bass
You will need to connect the low level input leads from the head unit to the amplifier (they are RCA cables). If there are no low level leads from the head unit, you will need to connect the wires from the speakers directly into the high level inputs using a wiring harness which should have been included with the amp. It should include a wiring diagram. You will need to use that diagram in conjunction with the truck's wiring diagram in order to know which wires to connect. They are color coded and once you have the vehicle wiring diagram (which can be downloaded by searching for it on google.com), it should be easy to determine which wires to connect.
Mar 04, 2011 | Audiovox AMP610 Car Audio Amplifier
Wiring diagram
My fault meant this as a solution post....
What do you need the diagram for? If your installing the radio, you do not need a diagram you need to go purchase the wiring harness for your make and model and year car. Match the colored wires together to the ones on the back of the head unit then connect them, then that harness plugs into your stock car harness that your stock radio unplugged from. You also probly need an antenna adapter cable that just connects to your stock antenna cable to add length and then plugs into your aftermarket radio. If you need a wiring diagram because you are trying to open you radio and fix it because it is broke or something...good luck to ya. Hope I helped... :)
Dec 15, 2009 | Kenwood KDC-MP208 Car CD/ MP3 Player
Bluetooth wiring diagram
you will need to search for a wiring diagram for your model of car radio
car kit blue - connect to ignition cable OR connects to switched 12v cable going to radio
car kit red - Direct to +terminal of battery OR to constant 12v cable going to radio
car kit black - connects to GROUND going to radio
car kit yellow - connects to mute function of radio if your radio supports it.
OR
connect blue and red together and directly to battery
and connect black to Body of vehicle
(not recommended as could result in draining of battery, even thought the kit is supposed to prevent this).
Jun 30, 2009 | Nokia Ck - 7w Bluetooth Wireless Hands -...
Solenoid wiring diagram, 2001 Nissan Maxima 3.0
There is a large battery cable that feeds the solenoid, usually the uppermost connection if the older type. The smaller cable feeds the smaller connector and is the starter power switch.
Oct 23, 2017 | 2001 Nissan Maxima
WIRING DIAGRAM
yo have wiring diagram :)
send your e-mail address to southener83@hotmail.com
Apr 24, 2008 | Altec Lansing VS2121 Computer Speakers
Shure Beta 52A Professional Microphone Logo
151 people viewed this question
Top Shure Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
