Question about Maytag Neptune MDE5500AY Electric Dryer
Moisture sensing strip coming off
Can the dryer operate safely without the moisture sensing strip, or should I replace it? I don't use that feature of my dryer.
  • 213 Answers
It can work on timed dry with out the strips. they are only in use during auto dry cycle
Posted on Nov 20, 2007
My Kenmore elite dryer mod 110 62932100 won't stay running.
Some dryers have a moisture sensing strip in the drum area of the dryer. If this sensor gets coated with an insulator, like silicon from the backing on carpets, it does not sense moisture. When this happens, the dryer times out and shuts down. This prevents the dryer from running even after the clothes are dry.
Dec 19, 2015 | Kenmore Dryers
Hotpoint ctd40 will start drying then cut off after 20 mins or so. i have cleaned filters, resovoirs and tested the thermostats which are fine. any suggestions?
Do you have moisture sense on this dryer? Also, do you use dryer sheets? If the question is yes to both, look for your moisture sensor strips inside the drum. They will be a couple of metal strips that may be straight or curved and they will be spaced about 1/2" apart. Get some rubbing alcohol and several cotton balls and wet one of the balls and rub the metal strips. If it comes back blue, keep cleaning with the alcohol and cotton balls until they come back still white. Some dryer sheets will leave a residue on the sensors and it makes the dryer think that the clothes are dry and they cannot sense the moisture. Hope this helps!
May 30, 2015 | Hotpoint Dryers
GE dryer dcvh680ej0ms runs 3 minutes and shuts off and resets time
On esimple thing to try is clean the dryer moisture sensing bars inside the dryer. Wet clothes rub against these bars and tell the control the clothes is still damp. IF no moisture is detected then she shuts down. So what goes wrong? Dryer sheets have a waxy buildup on them which tends to coat the bars. Moisture cannot penetrate the barrier and therefore the control thinks all is kosher and shuts down. Energy saver feature don't ya know. LOL Rocket scientists no longer have a space shuttle program so they engineering dryers now. LOL
Houston we have a problem.
Aug 03, 2012 | GE Dryers
Gas dyer not staying on, all the light are flashing
Does your model have sensor strips inside? Wash them with windex to remove any moisture barrier on them. They sense wetness and if they don't feel any wetness they make the control think them clothes is dry and it shuts down the dryer thinkin them clothes is dry.
Jul 09, 2012 | Frigidaire Dryers
Our NED7200TW intermitantly won't shut down when the clothes are dry. Every 4-6 loads, it just keeps drying. It stops upon opening the door and turning off switch. the first time this happened, I...
try looking at the moisture sensor strips. usually inside the under the door area. two strips that sense moisture as the clothes roll by. these may be broke, shorted or need replaced?
Jan 19, 2018 | Amana NED7200TW Electric Dryer
How can I check the control panel for my dryer, to make sure that is the problem?
Obviously it ain't drying the clothes. Maybe it ain't even running?
Or it could be working just for not too long. If it has auto sensing then the moisture sensing strips might be clogged with something that is preventing the dryer from sensing wetness.1753c2e.jpg That is easy, just windex them sensing strips. If they can't sense wetness then the control will shut down quickly and the clothes will be wet. Lets see what else the crystal ball has...I have some manuals HERE
Sep 19, 2010 | Whirlpool Dryers
Inconsistent sensing of condition of clothes
Clean those moisture sensors. Under the filer housing inside the drum is 2 metal strips. As wet clothes rub those a resistance is noted by the moisture sensing board. When no more changes in resistance are noted then the system shuts down and BOOM yer clothes is all peachy.
The junk from the dryer sheets wax over the strips and thus reduces the ability for on board intel to know fer sure if them dang clothes is dry.
May 13, 2010 | LG DLE5977 Electric Dryer
Not drying - one of two metal strips inside door is missing - would these bars sense the degree of drying ?
Yes those strips are moisture sensors which will sense moisture when the wet clothes hit them. They operate on a varying resistance and send the info to the main control board.
Jan 11, 2010 | Hoover Dryers
try timed dry cycle instead of the auto-sensing setting. In your drum if you have auto dry such as less dry normal dry and more dry, There is a sensor sometimes in the drum and sometimes in the exhaust right after the blower. If in the drum then your clothes brush by this and if moisture is sensed then it keeps on drying. With your rack the clothes can't touch the sensor so it tells your dial to turn and that items are dry which in fact are not. Try this and see how it does.
Feb 17, 2009 | Samsung 7.3 Cu. Ft. 9-Cycle Electric Dryer...
Need help
This is some basic info I could find on your dryer. I will need you Serial Number in order to determine the year it was produced. Please post back with comments and let me know.
Whirlpool Duet GEW9250P 7.0 Cu. Ft. Super Capacity 8 Cycle Front Load Electric Dryer With AccuDry Sensing System. Dry clothes in the time it takes to wash them. The dryers uses AccelerCare™ technology to work just as fast as the washer (Up to a 9 lb. load), giving you more time to enjoy all the good things you've worked hard to achieve.
AccuDry™ Sensing System - Monitor remaining moisture and automatically stop the cycle when the load is dry, with the AccuDry™ sensor. Reduce overdrying and save time and effort, by not having to return to the dryer to re-check progress.
Senseon™ Drying System - Moisture-sensing strips and temperature sensors inside the dryer drum monitor how fast the load is drying, how hot the air should be and when clothes are dry. The system automatically stops the cycle to help save time and prevent overdrying. Senseon™ technology safely dries clothes faster than it takes to wash them.
Wrinkle Shield™ Plus Feature (120 Minutes) - The Wrinkle Shield™ Plus option automatically tumbles the load without heat to help prevent wrinkles from forming.
Whirlpool brand offers an ergonomic solution for its front-load washers and dryers to help reduce bending, stooping, or arching. Based on your height and laundry room needs, optional 10 in. and 15.5 in. pedestals make loading, unloading, and filling the dispensers easier. The 15.5 in. pedestal doubles as a storage drawer with a convenient sliding shelf to support your laundry basket.
Item Features:
  • Super Capacity Plus - 7.0 Cu. Ft.
  • AccuDry™ Sensor
  • Senseon™ Drying System
  • 8 Automatic Cycles
  • Bulky Items Cycle
  • Adjustable End-of-Cycle Signal
  • Wrinkle Shield™ Plus Feature (120 Min.)
  • 5 Temperature Selections
  • Quiet Dry Plus Noise Reduction
  • Dry Rack
  • Reversible Side-Swing Door
  • Dryer Door Window
  • Reversible Side Swing Door
  • Electronic Controls
  • Front-Mounted Lint Screen
  • Interior Drum Light
  • 4-Way Venting
  • Porcelain SpillGuard™ Top
  • Optional Storage Pedestals Available
  • Stackable Installation with Matching Washer
  • Matches Duet® Washer
  • Warranty: 1 Year Parts & Labor
  • Capacity: 7.0 Cu. Ft.
  • Dimensions (HxWxD): 38 in. x 27 in. x 31 1/2 in; Depth with Door Open - 51.5"
  • Construction: Front Access, Reversible Side-Swing Door Style, Powder Coat Drum Material, Dry Rack, Extra Large Front Mount Lint Screen, Power Cord & Venting Accessories, Stackable
  • Controls: Electronic Controls
You can get an owner's manual replacement for your dryer at I believe there is a membership fee for the website, however. I hope this info helps you.
Nov 23, 2007 | Whirlpool GEW9250 Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
88 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
