Question about Dane-Elec DaneElec 4GB USB Drive Copper Hard Drive
DaneElec 4GB USB stick on IMac Mac Ox 5.4.6 changed 4GB to 400MB
My 2 pieces of DaneElec 4GB USB stick was fine at first on all the computers I used it on. (all my mac running MacOX), after arased the deta, making place for new, was unableto take more than 400 MB. I looked for downloadn of reformating for Dana Elec 4GB red, but all was for Windows, unrecognized by my MacOX. I also wrote email for the DanaElec Support website, but they did not answered my question. Anybody solved this problem before. Anybody has an idea how to change back for the original 4GB capacity?
  • 746 Answers
Yes Dear! I can help you to solve that matter. You should use USB format tool and after got that tool you can format it that you want and it will not only work properly while you will be able to use 4GB space again. I assured your problem will be solved.
Thanks
Posted on Jul 25, 2009
My computer doesn't recognize my dane-elec 8gb usb stick , although other usb devices do work.
1. Try a different USB port. If other ports recognize it, then the original port is fried. 2. Try a different computer. If the other computer does not recognize it, then your flash drive is damaged.
Good Luck!
Aug 19, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
Will not physically go into USB port, seems the small plastic with holes has moved forward inside the connector and stuck
turn off your computer before trying
get a pair of flat nose pliers or tweezers and place either side of the plastic strip stuck in the usb port gently pull on it until it has moved into its original spot other than that you will need to get a new usb port put in or if there are any other usb ports get a 4 or 5 port usb adapter and use that for your DaneElec 4 GB
hope this helps
Aug 05, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
How do you transfer files from the computer to usb?
Right click the file you want to copy and select "Copy". Open My Computer and double click your USB, then paste the file you copied
Mar 15, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
My 2gb usb thumb drive is "not recognized" I am using a Mac and looks like I may need a new driver. Where can I locate this??
With thumb drives, you usually do not need a new driver. Try this:
1. Open Finder
2. Applications 3. On the left column, you should see your thumb drive. Click on it.
4. Click on the "Erase" tab near the top
5. For "Format:" select "Mac OS Extended (Journaled)"
6. Click on the "Erase..." button
Jan 24, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
Dane Elec 4gb USB Not Readable
Try it in a different computer or even a different usb port on the computer that you are using. If a second computer gives you the same error, then the drive is either damaged or its filesystem is corrupted. In the first case there is not much you can do. In the second case you may be able to reformat it to make it work, but you would lose any data that was on it.
Mar 25, 2010 | Dane-Elec DaneElec 4GB USB Drive Copper...
How can i use an usb memory stick (4GB) on an iMac running Apple OS Snow Leopard? I would have to format one to use it on a Panasonic BlueRay Disk Player!
plug it into your computer and go to my computer then click on the usb memmory stick and drag stuff over to it like files etc. :D
Sep 13, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
DaneElec 4GB suddenly stops working?!
Hello, Likely the saulders on the circuit board are broken. If you are very skillfull and own a fine tipped sauldering device it's possible to repair it yourself although not highly advisable. If you'd prefer to have a pro look at it for you, just comment back with your region(country and city) and I will recommend an appropriate facility. Chris
Jun 04, 2009 | Dane-Elec DaneElec 4GB USB Drive Copper...
Don't know how to use it, can't find instructions for dane elec 4gb memory stick
just plug into any usb slot on your pc then go to ''my computer'' and double click into the removable drive. drag and drop or copy and paste
Mar 11, 2009 | Dane-Elec DaneElec 4GB USB Drive Copper...
Dane-Elec DaneElec 4GB USB Drive Copper Hard Drive Logo
521 people viewed this question
Top Dane-Elec Computers & Internet Experts
Piyal Perera
Piyal Perera
woodzowl307
Robert Karst
Robert Karst
Are you a Dane-Elec Computer and Internet Expert? Answer questions, earn points and help others
