Question about Sony Playstation 3 (PS3) Console
Won't work ps3 turns on then straight off again
  • 2 more comments
  • n_kent Jul 22, 2009
    turn it on green goes yellow then red and then flashes red
    thats what happens
  • ryanrfcok May 11, 2010
    what coulor is the LED's on your PS3 ?
  • pjwynn May 11, 2010
    Do you get any other light come on Does it go from green to amber to red Or Does it go from green to red Cheers
    Problem Solver:
  • 15 Answers
Sadly it the YLOD its the ps3 over heating it a similar problem to the xbox 360 with the 3 red lights
Its normally down to the CPU or GPU over heating
If you have a warranty then that's the way to go if its out of warranty then you can either call sony around £99.00 plus vat they will tend to send you a referb, worth calling them first as some times they will honor the warranty even if it out by a few months
Or you can send it to a local repair normally about £65.00 - £75.00 normally comes with a 4 - 6 month warrenty they will tend to recommend an extra fan installed as well as the fix
You can try the fix your self there is some information on you tube just look up PS3 YLOD but beware if you have no knowledge you can make it worse
Hope this is of some help
Posted on Jul 22, 2009
Ps3 won't work, screen says restore software
take out ur harddrive, turn ps3 on wit no hardrive den put it back in and turn on again,
if this dosent work hold power button and eject button on front of ps3, 1st u will hear 1 beep then 2beeps ,wen u hear 2 leave go,
it will say connect controller with usb, do that and u will get 6 options,
pick option 3,but if that dosnt work pick option 6 ,but option 6 will delete all ur saved data so be warned.
Nov 24, 2012 | Sony Playstation 3 (PS3) Console
My ps3 won't show on tv but it show that it's playing
Are you saying that it has sound but no video?
Plug only the video plug (yellow) to the TV. Turn on the backswitch. When the red light in front is on, put your finger on the on/off button in front AND KEEP IT THERE. You will hear some beeps; don't worry about that. Keep your finger on the button until the front power light goes red again. This resets the PS3 video settings. Turn the PS3 on and the TV should pick up the signal.
Hope this helps. Keep us posted.
Jul 07, 2011 | Sony Playstation 3 (PS3) Console
I push power and it shuts off right away... then i unplug power and the red light comes on ....still i press it and it goes off again
Hi russell,
The PS3 red light is a huge problem and it is caused by the GPU and the CPU overheating, all you need to do is stop the heat build up.
You have 2 ways of doing this:
You can send it in however bear in mind that for the fix you will have to wait for 4 weeks and also pay out $150 as well.
Or you can use a good PS3 Repair guide to fix the problem.
Make sure you check out these reviews of the top PS3 Repair guides first!
Cheers!
Mar 30, 2011 | Sony Playstation 3 (PS3) Console
My ps3 has stopped connecting to the internet, checked internet and it is working, how do I sort it?
I had the same problem. What you can try is go to the recovery menu. Turn the PS3 onto standy (red light on). Press and hold the power button. It will beep as soon as you hold it, keep pressing it until it beeps again and then once more 5 seconds later. The system will switch off. Press and hold the power button again, 1 beep straight away, then another 5 seconds later then 2 quick beeps, let go of the power button. It will now boot into the recovery menu. Select restore file system. It will restore and then reset. Hopefully this will solve it for you.
Jul 31, 2010 | Sony Playstation 3 (PS3) Console
I turn on my ps3 it turns off straight away and the red light flashes and its not overheated....????
1 - Turn on TV and set input to port being used.
2 - Make sure PS3 is connected via correct cable.
3 - Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
If that doesn't work then that means either the power supply is bad or the mainboard is bad.
May 31, 2010 | Sony Playstation 3 (PS3) Console
Code 80010006
software problem i thing not you
May 02, 2010 | Sony Playstation 3 (PS3) Console
Player won`t read
turn console onto standby and leave a min
then hold button in till it beeps 3 times and release
then do this again it will beep 3 times last one being double quick beep
a menu should appear
click on the one that says files this will restore your lens reader
Nov 23, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3 showing a yellow light
this means hadware failure if you still have warrenty send it to sony but if your not under warrenty and want to take matters into your own hands here are a couple of tricks.
again if your under warrenty send it back cause trying to fix yourself could cause void of warrenty
Check the hard drive first,
turn off ps3,....take out the hard drive the hard drive is on the left bottom side, pop the panel off with a small flat head screw driver of knife, then take out the single screw holding it and slide the hard drive to the right with the little handle. it looks like it should pull straight out but it doesnt you have to go straight to the right with it first to get it out of the connectors then pull straight out( when pulling straight out it should be completely free and just lide out)
then boot the ps3 with no hard drive and see if it trys to boot but says no hard drive found instead of the yellow light. if this happens then its the hard drive, you may have to get a new one. any laptop sata drive will work. but before you order a new one try turning ps3 off and putting same hard drive back in this seems to fix a few.
next try the fan test,
with the power switch on the back of the ps3 in the "off" position put your finger on the eject button and hold hit there while you turn the switch on the back to the "on" possition never letting go of the eject button and see if it boots then with a loud fan noise. if it doesnt then could be a number of problems with motherboard or fan or just over heating.
Sep 22, 2009 | Sony PlayStation® 3 (60 GB) Console
My ps3 wont start up when i switch it on it goes straight off aga
My ps3 wont start up when i switch it on it goes straight off again.
Sep 13, 2009 | Sony Playstation 3 (PS3) Console
Ps3 60g
This may or may not solve your problem. Turn the power off. Then, Press and hold the 1/0 button for more than 10 seconds. Then turn your PS3 off again. Turn it back on to see if it reset the problem.
Your PS3 Graphics engine processor could possibly be fried. Contact SONY Support to get an exchange. Go to www.playstation.com to setup service. Sony does not plan on releasing parts to repair shops, and I run one. I cannot accept PS3's consoles to repair until I can get a supply of parts. I hate to tell you this, but it is the straight up truth. Good luck
Nov 08, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
119 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
