Question about Crosley Celebrity CR73-3 3-Disc CD Player
CD's will not play, keeps rotating thru dics till eventually one starts. Sound keeps breaking up even on brand new cd . Remote is completely useless so never use it.
    President:
  • 1,124 Answers
It could be that the lazer pick up lens is dirty..
Try getting a cd player p/u lense cleaner..
OR it could be the pick is bad..
Rate well ;o)
Posted on Jul 22, 2009
ITS cd tray is revolving when we press insert button . tray moves inward and it do't select any cd .and tray comes out again. main problem is it do't select any cd
You have a slack loading belt under the tray.The loading action is not being completed because of it.
The Cd lifting mechanism requires more torque than the tray rotating action. If you put your ears close to the tray you will hear a belt slipping sound after the loading tray goes in . If you push the disc motor assembly with your hand from underneath the action sometimes get completed and the cd will start playing. Any way you cannot be doing this all the time, the belt needs changing. Its a set of two belts, one very small for the tray rotation and a thicker/bigger one for loading mechanism.
Mar 11, 2011 | Aiwa Audio Players & Recorders
Cd keeps jumping and then stops playing. Fine on different player
how long have you been using this player? The problem should be from the lens (laser).
The lens is weak and that's why it cannot read/load Cd's. The weak lens is also what's making it jump.
Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole lens completely to a brand new one.
By so doing your player would play all Cd's with no problem at all.
Good luck.
May 13, 2010 | Audio Players & Recorders
Every dvd we play starts freezing sometimes not
Try to clean the optical lens with CD Cleaner kit first. It's a CD with tiny soft brush on it
May 05, 2010 | LG LHT854 Theater System
Good day - I moved for my work and upon
First clean the laser head with a Qtip and alcohol. It gotta be perfectly clean, so wipe with fresh brand name qtip and make sure there is not a single dust particle on it. You gotta remove the cabinet with star screwdriver. Your beam might be tired. First try with the clean up! Unplugg before opening!
Oct 12, 2009 | Yamaha CDC-665 CD Player
Won't play DVD's but will play CDs
I suggests to try another dvd dics maybe it is not compatible to your player. try universal dvd dics...
Apr 16, 2009 | Televison & Video
DVD Movie
The reason I never completed my request was because I didn't realize right away that I do not even have a DVD drive. I only have a CD-rom. I know I sound pretty dumb, but I just took for granted that if I could burn CD's I could burn a DVD. Thanks for your help and consideration. Your program sounds great and I will keep it in mind for when I upgrade my PC. Thanks again!
Apr 06, 2008 | Televison & Video
Cd player reads disc error
maybe you need to change the optical eye now.
but first try to adjust the variable resistor/trimpot resistor.
try this options to your player.
(TIP)
if using a cd/vcd/dvd products, we only should play a cd/vcd/dvd dics without a bad scratches. the scratches are making the optical eye worn-out easily.
Jan 28, 2008 | Tascam CD-A500 CD Player
Cd not playing
look for any damage of your dics, maybe some of your dics are scratched or has a dirty part. hope I helped you.^.^
reply me if still it has the problem. so we could proceed at the next step.
Jan 18, 2008 | Wurlitzer Jukebox Princess 120-Disc CD...
No sound from CDJ-800 MK2
Are you getting error messages? Running in thru LINE? Is not on mute? The possiblity of both not playing would lead to process of elimination.
Keep me posted.
Oct 19, 2007 | Pioneer CDJ-800 Turntable
Crosley Celebrity CR73-3 3-Disc CD Player Logo
318 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Sam Palermo
Sam Palermo
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
