Question about Dryers
Frigidaire dryer feq221cas2 the startswitch will not stay on
Frigidaire feq221cas2 the startswitch will not stay on... the dryer will work if you hold the switch but it seems to get too hot... the second you let go the start switch it turns off
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 177 Answers
The switch is bad and need to be replaced. Holding the switch in the on position may cause it to burn, thus causing a fire so please do not hold it in manually.
Posted on Jul 24, 2009
My frigidaire front dryer heavy duty light stay on all the time
I appreciate your inquiry, Jnavarro073!
From the information you have provided the heavy duty light stays on all the time on your Frigidaire dryer. Could you provide me with the model number, please? With that information I will able to provide you better troubleshooting. You should be able to locate the serial tag (which lists your model number) on the door frame of your dryer. I look forward to assisting you. -Matt
Mar 08, 2015 | Frigidaire Dryers
Why wont my dryer stay running?
Good Morning Friend,
I understand that your Frigidaire dryer, model# FEQ1442ES, will not stay running. Please check to make sure the door is staying closed. If the door is opening in mid-cycle, then the dryer will stop running. Also, make sure the plug is in the socket tightly. Your dryer could be shaking the plug loose, which could possibly be causing it to stop running. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire FEQ1442ES Electric Dryer
Frigidaire electric dryer will not stay on for
Reach inside and turn the drum by hand. It should be very eay to turn. If it is not easy to turn then something needs to be replaced such as glides or drum bearing.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 06, 2013 | Frigidaire GLEQ2152ES Electric Dryer
Where is the resset buton on frigidaire electric dryer machine?
  1. Press and hold the "Control Lock" button for five seconds to lock the dryer. Release the button when the dryer beeps, indicating that the dryer is in locked position.
  2. Press and hold the "Control Lock" button for five seconds to release the lock.
  3. Press and hold the "Options" and "Select" buttons at the same time on Frigidaire dryer models that do not have a "Control Lock" button. Hold the buttons for 10 seconds until "LOC" is displayed.
  4. Press and hold the "Options" and "Select" buttons simultaneously and hold for 10 seconds to release the door lock.
  5. please comment on these by telling how helpful.
Dec 20, 2010 | Frigidaire Electric Dryer
On/off switch stops working
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 22, 2010 | Frigidaire Electric Dryer
Frigidair Crown Model #FDB23RGS1, Serial #XD14406315 - Fire on dryer does not stay lit. Appreciate your suggestions on how to fix the problem. Thanks
Have a technician come out and check the burner valve. Usually when the valve fails or is starting to fail, it won't hold a pilot.
Dec 13, 2009 | Frigidaire FGQ332ES Gas Dryer
The timer on my dryer isn't working properly
HI. the timer motor is damaged at this point. The Auto sector is dead. This is not a serviceable part, and you will need to replace the entire timer mechanism to correct this issue.
Oct 02, 2009 | Frigidaire Dryers
Dryer will not run
dryer starts sometimes if you hold in button. frigidaire gallery series model # GLEQ942CSO. serial # XD350164472. flat panel control board.
Mar 31, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Dryers Logo
141 people viewed this question
Top Dryers Experts
