Question about HP Compaq ProLiant ML110 G4 Server
No Screen on Notebook Compaq nC8000
Hi There,
I have used my laptop this morning and all was well, had to shut down in a hurry so pressed and held the off switch, re booted tonight and the computer is turning on firing up etc but the screen is totally blank, currenlty have it plugged into my old Home PC moniter in order to get online!
Any help is appreciated
  • 25 Answers
Hi Tori1206,
Usually Laptops use the F3 key as toggle for switching from laptop monitor another external monitor. So you might try depressing the F3 key to switch back to the laptop monitor...
Posted on Nov 25, 2007
My screen id dull, and hard to read, what can i do to make it brighter.
My laptop has some keys down on the right side showing lights on it and some laptops has them up the top of the keyboard i think
if you can see them press FN and the light up or down key to brighten the screen
If you cant find the keys check out the manual for your laptop if you have it
Or download from here
Nov 02, 2010 | HP Compaq nc8000 Notebook
My compaq nc8000 will try to boot up (only shows window xp, then goes to a blue screen with a lot of dots in it), but first shows zeros all across the screen not allowing you to do anything at all.
Hi, sounds like what is known as the blue screen of death. You can try reseting your operating system to an earlier time, before the problem began, by pressing the ESC or Del key during bootup, this will give you the option to boot into safe mode, from where you can attempt the reset. Or you can insert the CD that came with your compaq and perform a system restore. Both of these options will not remove any saved data.
Oct 11, 2010 | Compaq NC8000 Notebook
How do i restore my hp nc8000 laptop back to factory settings?
try press f12 and hold down on restart of computer you should have options
Aug 31, 2009 | Compaq NC8000 Notebook
Laptop shuts off
There are many factors which might be causing this problem...Maybe the laptop battery is not charging properly of else there's a failure in your O/S or even a faulty motherboard.
Jun 12, 2009 | HP Compaq nc8000 Notebook
White vertical line on my hp compaq nc8000 monitor
Hi there welcome on!
Try another screen and tell me if you still have the line !
Apr 04, 2009 | Compaq NC8000 Notebook
Red and Blue vertical lines top to bottom on LCD Screen
yes it looks like its going bad..must be pixel burnout or will have to contact HP for repair/replacement
Nov 23, 2008 | HP Compaq nc8000 Notebook
Changing ram on a compaq nc8000
YOu can change or upgrade the ram by either of the two sites below,
Hope my info solves your problem...
Thanx for using fixya.
Oct 03, 2008 | Compaq Computers & Internet
Unfortunately, sounds like the LCD backlight or backlight power board is bad. If there is any warranty, lucky you. Otherwise you need replacement parts. The output voltage on the powerboard needs to be checked to determine what needs to be replaced. Backlight Approx $20, powerboard Approx $65. This is the cost for parts alone if you are into electronics, otherwise a repair shop would end up charging you $200 - $300. There is a slight possibility that it is only a loose connection (cold solder joint or loose cable), but the laptop would still need to be opened, Lots of luck
Sep 16, 2008 | HP Pavilion dv6000z Notebook
AC Power and Battery Problem.....
Sounds like the battery or possibly the charging circits themselves are the problem. Can you try turning on the laptop with just the power cord in and no battery?
Aug 20, 2008 | Compaq NC8000 Notebook
Startup problems
check your keyboard connection (unplug and plug again). If not works try another of same type.
Dec 24, 2007 | HP Compaq Presario V2000 Notebook
HP Compaq ProLiant ML110 G4 Server Logo
110 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
