Saws Logo
. . Posted on Feb 05, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I change disks in my Makita PA - GF 30? Thank you
Pieter Vleeshouwers
Level 3:
  • Makita Master 2,029 Answers
  • Posted on Apr 18, 2017
Pieter Vleeshouwers
Makita Master
Level 3:
Answers
2029
Questions
0
Helped
4113839
Points
7389
Https://www.matbase.com/material-categories/composites/polymer-matrix-composites-pmc/reinforced-polymers/material-properties-of-polamide-6-30-percent-glass-fiber-reinforced-pa-6-gf30.html
PA GF30 is the base material of the housing set of the machine not the model number made a google search for " makita saw " on pictures the chance is that you find your model .
1 Related Answer
ideaal
Pieter Vleeshouwers
  • 2029 Answers
  • Posted on Feb 05, 2017
SOURCE: How do I change disk/blade in my Makita PA6 - GF 30.
Thats a material code of Polyamide many products are based on this PA6-GF30 code. like to see here for example
Polyamide PA6 GF30 Jacob moeren metrisch WKK Nederland
Search on the pictures in Google for the right saw model
Feb 05, 2017 • Makita Saws
JE POSSEDE UNE PIECE PORTANT LA REF.PP GF 30 YS61 13 K060 AA 1 305 239 147 ...
Je viens d'acheter une ponceuse d'occasion Bosch PP GF 30 et je desire avoir le manuel d'utilisation.
merci
3answers
Can anybody tell me the correct type and weight of oil a 2004 volvo xc 90 uses also # for replacment oil filter
Oil filter is provided by year,make, model of your vehicle at the parts store. ---
Oil and fluids Oil quality
Engine oil must meet the minimum ILSAC specification GF-2, including ACEA A1, API SJ, SJ/CF and SJ/Energy Conserving.
Your Volvo has been certified to standards using ILSAC oil specification GF-2 5W-30. Volvo recommends use of oil with a quality rating equal to or higher than ILSAC GF-2. Equivalent and better oils include ACEA A1, API SJ, SJ/CF, and SJ/Energy conserving. Lower quality oils may not offer the same fuel economy, engine performance, or engine protection.
Volvo Cars recommends Castrol. Depending on your driving habits, premium or synthetic oils may provide superior fuel economy and engine protection. Consult your Volvo retailer for recommendations on premium or synthetic oils. Oil additives must not be used. NOTE: Synthetic oil is not used when the oil is changed at the normal maintenance is carried out. This oil is only used at customer request, at additional charge. Please consult your Volvo retailer. Operation in hot climates.
When temperatures exceed 86° F (30° C) in your area, Volvo recommends, for the protection of your engine, that you use a heavier weight oil, such as SAE 10W-30. See the viscosity chart below. pg129a.jpg Oil viscosity (stable ambient temperatures)
Operation in temperate climates
Incorrect viscosity oil can shorten engine life. Under normal use when temperatures do not exceed 86° F (30° C), SAE 5W-30 will provide good fuel economy and engine protection. See the viscosity chart above. Extreme engine operation
Synthetic oils meeting SAE 10W-30 and complying with oil quality requirements are recommended for driving in areas of sustained temperature extremes (hot or cold), when towing a trailer over long distances, and for prolonged driving in mountainous areas. Changing oil and oil filter
Oil and oil filter changes should be made at 7,500 mile (12,000 km) intervals. Volvo does not recommend the use of oil additives.
Synthetic oil is not used when the oil is changed at the normal maintenance intervals except at ower request and at additional charge. Please consult your Volvo retailer.
8helpful
2answers
Delco no.90 566 821 ,suplier 4660103 mc,gm 0500x9595741 I need a code for this cd-player, because I losted and it*s from vauxhall vectra
I need a code for this cd-player, because I losted and it*s from vauxhall vectra b delco no.90 493 281 ,suplier 4 660 103 mc, GM 90 493 281 cdr 500 >PA 6 - GF 15< Thanks. mail [email protected]
5helpful
Need to know what the lights mean on a makita dc24sa charger
• When the battery cartridge is inserted, the charging light color will change from green to red and charging will begin.
The charging light will remain lit steadily during charging.
• One red charging light indicates charged condition in 0 – 80% and two red ones indicates 80 – 100%.
• With finish of charge, the charging lights will change from two red ones to two green ones.
• The charging time is as follows:
Battery B9017A, BH1220, BH1420, BH9020A: approx. 20 minutes.
Battery B2417, BH1233, BH1433, BH2420, BH9033A: approx. 30 minutes.
Battery B2430, BH2433: approx. 60 minutes.
Top Makita Saws Experts
Sean Wright
Sean Wright
john h
Are you a Makita Saw Expert? Answer questions, earn points and help others
