Question about Hunter 30200 \ 30010 (Set) Air Purifier
Air purifier HUNTER 30200
I hope this is not to late. This is an old post. But I have this same air cleaner. It does prove difficult at first to open and it feels like you are going to break it.
On the sides about two to three inches down is a large indentation. Slide your fingers in there and gently but firmly pull the face plate of the air cleaner off. The air cleaner is as big as the front of the air cleaner. It will slide right out. I hope this helps.
Posted on Mar 02, 2008
Hunter hepatech 40882 uvc air purifier won't turn after cleaned filters
Hello, this is Ava with Think Crucial.
Filter life counters should be reset each time the filter has change. If your air purifier has a reset button, press and hold the reset button until the lights go out. You may also unplug your unit from the power for 30 seconds before plugging it back on if your unit doesn't have a reset button.
You can purchase a wide variety of high quality Hunter replacement parts for your Hunter Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for readers, use code: FIXYA10
I hope this was helpful.
Ava B.
Think Crucial Customer Care
Oct 24, 2016 | Hunter Air Purifiers
Hunter Air Purifier making screaming noise
Most likely the problem is a bad bearing in the fan motor.
May 31, 2012 | Hunter Fan Company 30251 Air Purifier
Can I get an owners manual for Hunter 30525 air purifier?
Yes, manuals are available from Hunter Air Technical Support. Call: 888-830-1326
Be sure to have the correct Model Number handy, when calling. As some models have been discontinued, but are still supported by Hunter Air.
Hope this helped you.
Apr 21, 2011 | Hunter HEPAtech Air Purifier and Ionizer -...
What is the ioner button for?
ioner button produces an electric charge that helps dirt become attracted to the filter and also cleans the air
Apr 09, 2010 | Hunter 30200 \ 30010 (Set) Air Purifier
Cannot find manuel, need to reset after replacing filters.
How to reset Hunter quietflo air filter, won't start up.
Jul 10, 2009 | Hunter QuietFlo 225 Air Purifier
Lights still flashing after i replaced filter
You have to press the reset button on some models. The unit does not have any way of knowing you reset the filter -- you have to tell it.
Mar 22, 2009 | Hunter (30067) Air Purifier
Wont run after I cleaned it
On the model 30200 there is a safety interlock switch actuated by a plastic tab (about 4" down from the top of the front filter cover) on the right side. Assuming that all you did was take off the front cover and clean or replace the filter(s) and the unit was working previously, this should be your answer. If in taking off the cover the switch actuation tab was broken off, you could (carefully) wedge a tab into the slot where the switch resides. This defeats the safety aspect of certifying that the unit isn't running when you remove the cover. The safe work-around is to unplug the unit before you open it for service.
Feb 09, 2008 | Hunter 30200 \ 30010 (Set) Air Purifier
Hunter 730 carbon pre-filter replacement orange light
Filter lights on your Air Purifier One of the best things about your IQAir Air Purifier is that it has warning lights to tell you when to change the prefilter, gas or hepa filters. Of course how long they last depends on your pattern of usage. For the initial 80% of the filter life the control panel will display a green light next to the corresponding filter on the outline of the unit. When the orange light goes on it does not mean that the filter needs to be replaced immediately but that there is 20% of useful life left. IQAir gives you plenty of time and the machine will tell you how many hours you have left. Once the number of hours gets to within a few hours remaining the orange light will then change to red. It is at this time you should change the filter. If you forget to change it and there are no hours left the hours will go into the negative displaying how many hours you have gone over and the red light will change to a flashing red light.
Just in case you have lost the manual like one of our customers, this is how you reset the filter lights:
1. Press the menu button ( 7 times) until you get to where the display says new filter.
2. Press the enter button and hold it down for 3 seconds and a number 1 will be flashing after the words new filter on the display. This flashing number is so you can enter which filter you have changed. Filter number 1 is the pre-filter, filter number 2 is the V-5 gas filter, and filter number 3 is the Hepa filter.
3. You change the number for the filter by pressing the up arrow button.
4. Once you reach the correct filter number you press the enter button and the control panel will display a question mark after the words new filter on the display. Below this it will say, E = Yes M = Cancel. If you wish to cancel the entry so it does not reset a new filter life, simply press the Menu button.
5. If you want it to reset the filter life for the changed filter, simply press the Enter button. Once this is done, the filter light will change back to the green light, which will show the filter has been changed. If you go to the remaining filter life on the control panel for the filter number you just changed, you will now see the remaining life of the filter in hours has been reset.
  • When most people think of Oreck, an air purifier is usually not the first thing
  • IQAir Dental Series Air Purifier
  • UV air purifiers are very effective at neutralizing airborne pathogens
  • HEPA Air Purifiers
  • Ozone Air Purification
  • Ionic air purifiers come in three different forms
  • Dehumidifiers - Ebac Orion
  • Furnace Filters, Electronic, Electrostatic Air Filters - Comparisons, Ratings,
  • Nov 26, 2007 | Hunter 30216 3-SPEED FLOOR MODEL Air...
    Hunter 30200 \ 30010 (Set) Air Purifier Logo
    350 people viewed this question
    Top Hunter Air Purifiers Experts
    Gerry Harvey
    Gerry Harvey
    Are you a Hunter Air Purifier Expert? Answer questions, earn points and help others
