Question about SkyScan 86709 Atomic Wall Clock
My problem is with Model 88303. Can someone help with that?. It is about 5 yrs old and with a good battery stops every so often for a few days and then starts up and resets itself again. What gives?
Why does my Gucci watch quit running every few days?
You can start by fitting a new battery & monitor it &see what happens good luck
Aug 20, 2014 | Watches
My laptop was one year old last december. my battery stopped charging the same week it became one year and the guarantee expired. having no exta time, i took the laptop to the store 5 days after...
I would strongly suggest the good old battery 'hard reset'...
1.) Turn off laptop
2.) Unplug it from power supply
3.) Hold down the power button for a minute
4.) Plug it back into the power supply
5.) Power it on and wait to see if the battery icon is showing up and charging
This has resolved a few of these ghost battery issues on some of my clients laptops! If that fails, please provide the exact model number of the Gateway laptop and which operating system you're using and we'll see if we can't find another fix.
Hope this helps,
Joe
Apr 17, 2011 | Gateway Computers & Internet
Replaced thermostat heat good for a few days and now nothing
Thermostats can often be defective--especially cheap ones--1st --remove cap--check fluid level---2nd--if level near top -is ok--then run engine about 5-7 min. with cap off--rev engine once every minute (this removes air in system)--IF this doesn't help--return thermostat & get a higher quality one & repeat above procedure. Also, you should have radiator & heater core flushed if car is over 5 yrs. old--sometimes they can have blockage--(if it hasn't been done --fluid should be changed after 5 yrs. age also 50-50 mixture or premixed antifreeze--never use water unless only for short time--example: checking for leaks.
Feb 26, 2011 | 1996 Dodge Avenger
Engine stops when I engage attachment,or travel clutch. I know it is electical but can not find the cause. Can someone Help? Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed...
Have a Poulan 27147 model 13.5 38"
Start the mower and release the clutch or brake whichever you call it and the mower will stop. Have replaced the switch and soleniod and it still stalls out. Any solution to this? Been looking for a manual for this model - only 10 yrs old - but no luck.
Jun 23, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Hello All - I'm hoping someone here can give me a few ideas. My 92 toyota celica st has sit for about 5 days - for the last 3 days the temp outside has been in the single digits. Went to go start today and...
You can try this.
Turn on the key and listen for the fuel pump to prime.
It will sound like a gentle hum. when it stops, turn the key off. wait a few seconds and do it again. Do this three or four times, but don't try to start it. after the third or fourth time you turn it off, try to start it. It may not be priming the fuel injectors fast enough.
Dec 13, 2009 | 1992 Toyota Celica
Car won't start HELP PLEASE
Hello...
I would start, since it is cold outside by checking to make sure the battery is in good shape. If it is not, it will run but when the cold comes it will eventually not turn over. Note: Turning on the lights to see if they are bright is not a good check for the batteries abilty to crank the car. If you have a Checker or Autozone or other auto parts store see if they can test your battery for you.
With the sudden stop starting I would also suspect possibly the fuel pump or the pump relay.
Good Luck...
Mike
I have 3 compressors, all of them refuse to stop compressing until i manually shut them down,husky 26 gallon upright 5 yrs old, porter cable pancake 2 yrs old. and a master elite? came from home depot as...
the regulator/switches are either rusty, clogged, or need to be replaced. if you have some machanical aptitude and common sense this should be easy, if not have a pro or someone some knowledge of this type of thing handle it for you. in the future drain your compressor DAILY to avoid this problem
Nov 13, 2009 | Porter Cable Air Tools & Compressors
Setting time/date on old Seiko
With our 10 year old grandson's help, my husband was able to figure it out. Took a while, but he is now wearing his watch again!
Thanks for the follow-up.
Feb 08, 2009 | Seiko Watches
Buzzing sound, freezer nor fridge cooling
sounds like a compressor issue, perhaps the good news would be if its just under 5 yrs, youll have a 5 yr warr onthe compressor assy.( you should anyway) ck your manual for warr info
Nov 20, 2008 | Frigidaire FRT21H8 Top Freezer...
SkyScan 86709 Atomic Wall Clock Logo
312 people viewed this question
Top SkyScan Home Experts
Jerry Greenberg
Jerry Greenberg
Rick Goldsmith
Rick Goldsmith
Level 1 Expert
Are you a SkyScan Home Expert? Answer questions, earn points and help others
