Question about Canon Pixma MP500 All-In-One InkJet Printer
Won't scan My Pixma MP500 is all of a sudden refusing to scan. I tried turning it off and on again. The printing and copying features work fine, but when I try to get it to scan, it stops on the final step (pressing Start, either color or black, does nothing). Ideas?
    President:
  • 1,335 Answers
The scanning feature is much more sensitive to connection signal strength than the printing function. Make sure the USB connection is firmly in place on both the computer and the MP500. If this doesn't fix the problem I would try a different 6 foot length USB cable.
Posted on Jul 22, 2009
I've got a Canon Pixma MP 500. Printing from my computer = faded print. Copying = blank page. Auto head align fails. Alarm light goes on. Have tried stop/reset button. How can I fix this?
It sounds like the print head on your printer is either clogged or not working.
You get faint print from your computer because the computer will use your color inks to get gray. When you copy, it only tries to use black and the black isn't printing at all.
Check your user's manual and it should show you how to clean the print head. Otherwise replace the print heads and you should be fine.
Thanks,
Pat
Aug 16, 2010 | Canon Pixma MP500 All-In-One InkJet...
All of a sudden my MP500 gives an error code
If the carriage will come out of the right corner, you need to look inside and see if there's a paper scrap or anything blocking the purge assembly. The purge is the unit that cleans the printhead, and that error says it's not moving properly. If nothing is stuck in there, you will need to have the purge assembly replaced.
Dec 28, 2009 | Canon Pixma MP500 All-In-One InkJet...
Nothing happens when I press the scan button
When you press scan, the unit must be connected to your computer and the computer needs scanning software running, if you want to make a copy you press copy and it will scan and print, in order to scan it needs to know where and how to scan and where to store the image.
Sep 14, 2009 | Canon Pixma MP500 All-In-One InkJet...
Suddenly stopped scanning and now won't copy or print b/c keeps saying it's still scanning. Canon mp830. Scanning Wizard starts but just dies in the middle. Any button I'm not hitting or solution you can...
Any lightning strikes locally?
You can try to reset back to factory by removing cartridges and head.Power off unit ,then unplug for 45 minutes.repower and install all.
Do a nozzle check and see what happens.
Aug 01, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Scanner won't work
If you are using a wireless connection, your scanner will not work.  I was told the printer does not have the capability to scan wirelessly....prints wirelessly, wont scan
May 11, 2009 | Canon Pixma MP500 All-In-One InkJet...
Scan Not Working
Me too, copy and works fine. When the printer starts up I can see that the scanner moves, the green light is there - all i can see is that maybe it is vista or that i didn't run the set up cd completely. But I put the instillation CD in again and went to http://www.canon.com.au/vista/ and downloaded their driver - now it works fine
Apr 29, 2008 | Canon Pixma MP500 All-In-One InkJet...
Won't scan
Do you have the scanner driver loaded? Try uninstalling your drivers unplug the printer. Then re-install the printer software then plug it back in!!
Sep 02, 2007 | Canon Pixma MP500 All-In-One InkJet...
Canon Pixma MP460 problem...cannot scan
i was told that the printer needs to be directly connected to the imac (not airport) for the scanner to work.
i have the same issue w/ the airport extreme.
May 12, 2007 | Canon Pixma MP500 All-In-One InkJet...
Can't print from the 'print' button on screen, will copy and scan from printer, will run test from computer
try uninstalling the update as long as it is not one necessary to new programs. Find the uninstall for it by doind a search in the run menu, and the uninstall file should come up. Follow prompts. Now try printing again. If this fails, you may have to uninstall printer drivers ie go to remove programs, unilnstall printer and all related files. Now reinstall using your original printer canon disk for your operating system. Try printing again.
Apr 16, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Canon Pixma MP500 All-In-One InkJet Printer Logo
272 people viewed this question
old marine
old marine
