Washing Machines
Problem for Washing Machines
Generic problem for all Washing Machines
Water problem
By lenny boy on Nov 20, 2007
for several months we were not able to use the cold water .. no cold water fill
Same Problem
May 26, 2009
-   I had to turn off the water for plumbing work in the kitchen. Ever since the washing machine does not draw cold water. Both wash and rinse cycles are using hot water only.-   Guest
Feb 04, 2008
-   Yes the wonderful LG cold/cold cycle is putting out hot/cold-   Racene
Feb 04, 2008
-   Same as above cold/cold is hot/cold-   Guest
Jan 02, 2008
-   No cold water enters the wash basin. When I select the cold/cold option the water is the same temp. as the warm/cold option.It is as if the cold/cold button doesn't register with the machine.-   MrsBobo
Nov 25, 2007
-   We just moved and after hook-up the cold water doesn't come into washer. Changed hoses,cleaned the screen. Still no water. It's seems to be blocked. Worked fine before the move.
Thank you.-   kjpainter
Best Solution
posted on Nov 20, 2007
Helpful)
Cerfer39
Rank: Guru
Rating: 87%, 1170 votes
HI Lenny Boy,
Your Solenoid Valve is not working. Where the Water lines connect to the washer is your Valve. REplace that parts and you will have it fixed
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Washing Machines
Questions and Unsolved Problems for Washing Machines
Answer
Are there any new washing machines made that still have direct drive. That means that the agitator... (More)
Answer
Whirlpool Cabrio WTW6300 worth the $$?
Answer
after drying too much steam clothes are red hot
Answer
My Maytag Neptune keeps interlocking and won't run. If I set it to 3rd rinse I can get it to start... (More)
Answer
when you press start the front door locks,does not fill with water and will not unlock had to take... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machines Experts
Top Washer & Dryer Repairmen
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
