Question about Efficient Networks SpeedStream 5200 Modem
Speedstream 5200 Ethernet/USB ADSL Modem SETUP button missing
I have a speedstream 5200 Ethernet/USB ADSL Modem, Part# 060-E242-A13, Mac 000B23670B13, Firmware Part # 004-E242-A0W, Configuration Part # 003-6100-G09. Recently, when I go to lower my Firewall Level to Low so I can upload files to my website, the SETUP button is missing and I have to reboot the 5200 in order for it to appear. The modem/firewall appears to be operating correctly otherwise. I have tested the firewall to see if any ports are open and all ports are in stealth mode. ICMP is disabled so my computers cannot be pinged. Everything seems ok except the SETUP button is missing until I reboot. Any idea what is causing this and what I might be able to do to fix it? Is there a new firmware upgrade available that I need to install? I’ve had this 5200 since about 2004, but can’t remember for sure exactly when I got it, other than it was probably 2004 or later. Thank you in advance for any assistance you might be able to give.
vijay
  • 27 Answers
SOURCE: Speedstream 3060 modem
for this you may visit the website which will be printed on the modem. or search the following web site www.modemdrivers.com
Posted on Oct 05, 2006
  • 8 Answers
SOURCE: speedstream 5200
here is the pdf download link for this modem
http://www2.windstream.net/downloads/links/SpeedStream211.pdf
should be of some use
Posted on Oct 19, 2007
SOURCE: Speedstream 4200 setup
I have just set up 4200 with dsl - you may find that you need to reset modem before you can configure. I was told that you need either a grey or yellow cable from your laptop to the modem. I use 10.0.0.138 to access modem. The 4200 I have was from a bigpond a/c - originally configured accordingly.
Regards,
Richard
Posted on Nov 16, 2007
map9966
  • 2351 Answers
SOURCE: I have no driver file for speedstream 5200
You can try here.
http://members.driverguide.com/driver/detail.php?driverid=128940
Than manual.
Good Luck!
Mike
Posted on Apr 21, 2008
SOURCE: SPEEDSTREAM 5200
some modems have 192.168.16.1 as default adr
reset modem with a pen in a little hole on the back
wait for led green/red blinking ... it's done
Posted on Apr 24, 2008
I have a Speedstreams 5200 E242 modem. Installation stuck after modem connection. Is the 4.2.2.122 driver Windows 7 compatible? Where can I download the good driver for Win 7?
If your router is connected via the Ethernet port no drivers are necessary.
If you don't have a good reason to use the USB port, please use the Ethernet since it's much faster.
Please let me know.
regards
Jan 25, 2011 | Efficient Networks SpeedStream 5200 Modem
Does the speedstream 5200 offer wireless capability?
No it do not ahev wireless feature. details fo this devices are:-
Manufacturer: Efficient Networks Product MPN MPN 33A-5200-701 Key Features Router Functionalities dtrquestion.gif Firewall • DHCP Server Connectivity Wired Interfaces LAN Interfaces 10/100 Base-T WAN Interfaces dtrquestion.gif ATM Additional Interfaces 1 x USB Standards and Protocols LAN Standards IEEE 802.3 CSMA/CD or Ethernet • IEEE 802.3u 100 Mbps (Fast Ethernet) Protocols dtrquestion.gif ATM • DHCP • IP • PPPoA • PPPoE • TCP Routing Protocols RIP Version 1 • RIP Version 2 • Static Routing Remote Management Protocol dtrquestion.gif HTTP • Telnet • SNMP 1 Firewall / VPN Firewall Features Stateful Packet Inspection (SPI) • DoS Prevention • NAT Authentication PAP (UPAP) • CHAP Modem DSL Standards ADSL Lite (G.Lite ITU G.992.2) • ADSL Full Rate (G.DMT ITU G.992.1) Other Features LED Indicators Power • WAN • Activity • DSL Additional Features Auto Crossover (MDI/MDI-X) Warranty Warranty 1 Year Miscellaneous Release Date 2003
May 01, 2010 | Efficient Networks SpeedStream 5200 Modem
No activity on my new speedstream 4200
Ethernet and DSL lights are indicating you have ADSL available on your line, and that you have computers connected to the router.
What has probably happened is that Optus did not set up the new router with your username and password. Go to thw following website for details on how to setup the modem.
http://help.optuszoo.com.au/help/dsl/connected/windows/optus_modems/speedstream_4200
Manual Modem Settings The Optus DSL Broadband self-installation CD configures all the necessary settings for your DSL Broadband service. You do not need to manually configure your modem if you have run the self-installation CD. While the following information is provided for your reference, using the self-installation CD is the recommended method for configuring your modem.
The Siemens SpeedStream 4200 ADSL modem can use either USB or Ethernet to connect to your computer.
  • If you are connecting via USB you will need to run the self-installation CD to install the USB driver before you connect your modem. The Siemens SpeedStream 4200 ADSL modem supplied by Optus has been customised for the Optus DSL Broadband service. Only the USB driver supplied on the self-installation CD will work with the Optus service. If you do not have the self-installation CD, you can download the latest drivers from the Siemens website.
  • If you are connecting via Ethernet it is possible to manually configure your modem without the self-installation CD. Only a web browser is required.
After connecting your modem there are two key steps to manually configure your modem for the Optus DSL Broadband service:
  • PC settings - Configure your computer's Ethernet network interface.
  • Configure Your Modem - Set the password in your modem's configuration pages.
top
PC Settings Step by step instructions are provided for each of the supported Windows operating systems:
  • Windows 98/Me
  • Windows 2000
  • Windows XP
  • Windows Vista
top
Configure Your Modem To configure your modem settings you must now access the configuration manager using your web browser. This is done by entering the IP address in the address bar of the browser window as follows:
Note: If you are updating the password in your modem, please complete steps 1 to 3 only.
Step 1 of 5
  • Enter http://10.1.1.1 (Default IP address of the Optus Supplied Siemens SpeedStream 4200) to access the modem Configuration software. You may wish to add this page to your Favorites for easy access later.
  • The following modem System Summary screen will appear.
ss4200_home_disconnected.gif Step 2 of 5
  • Click on the word Setup in the green menu of options on the left side of the web page. An expanded set of options will be displayed.
  • Click PPP in the list of options that appeared below the word Setup.
  • The ISP Password page will appear:
  • Replace the default username (john_citizen@optusnet.com.au) with the username provided for you by Optus DSL Broadband.
  • Replace the default password with the password provided by Optus DSL Broadband in the Password field.
  • Note: You will find your Optus DSL Broadband username and password on the letter you received with your self-installation kit.
  • Save these details by clicking the Save Settings button.
Step 3 of 5
  • The next screen will ask you to disconnect and reconnect to the Optus DSL Broadband service.
  • Click the link to return to the System Summary page.
  • Click the Disconnect button to disconnect the modem from the Optus DSL Broadband service. The text on the button will change to Connect.
  • Click Connect to reconnect the modem to the Optus DSL Broadband service.
Step 4 of 5
  • Click the word Mode in the green menu of options on the left side of the web page.
  • Confirm that Optus Bridge is the selected operation mode.
  • If Optus Bridge is not selected click the radio button next to Optus Bridge to select it.
  • Click the Apply button.
  • Click the Reboot button to restart the modem using your saved settings.
  • After about a minute the modem will return to an operational state and connect to the Optus DSL Broadband service.
ss4200_reboot_3.gif Once the modem has rebooted and the ADSL connection has been successfully established the DSL LED indicator will light steady green.
Your modem is now connected to the Optus DSL Broadband service.
Jul 25, 2009 | Siemens SpeedStream 4200 (13A4200001)...
Can you tell me what the difference is between the modem part for ethernet/usb adsl modems, 060-E240-061 AND 060-E242-A01. I would appreciate and info or direction to a specific web site for this info....
when your pc conect with ethernet port also say that LAN port and oter port is USB port
which one conect with ethernet/LAN port is
called ethernet Modem and which conect with
USB port called usb Modem.
Jul 06, 2009 | Computers & Internet
I installed a Dlink Telephone adaptor between my speedstream 5260 my PC. I think I need to change the MAC address on the speedstream. How do I do that?
Connect one of your computer to the LAN port of the speedstream, access the configuration page of the speedstream (example 192.168.1.254) then under advance tab there a MAC filter there that you change the MAC address.
Mar 15, 2009 | Siemens SpeedStream 5260 ADSL LAN Modem...
Speedstream 5200 modem
Open the following link --
speedstream 5200
Download the manual from the link and review page 7 for ethernet connection.
Notice particularly the back of the device. There are four connection points to plug things in the one on the left with DSL is where cable with the phone connectors connects the phone jack to the speedstream 5200. On the right the round connector with the pin is where the power goes. Next to the power connector to the left is a USB connector. In between usb connector and the DSL port is an ethernet connector. One way to avoid the need for the USB software os to use the ethernet connector bu connecting an ethenet cable (wider connector that fits snugly in both ports one on the Speadstream 5200 and the other probably present on your computer.
USB driver including VISTA (if you prefer)
USB driver link
Dec 11, 2007 | Efficient Networks SpeedStream 5200 Modem
Efficient Networks SpeedStream 5200 Modem Logo
379 people viewed this question
Top Efficient Networks Computers & Internet Experts
Vijay Damaraju
Vijay Damaraju
Level 1 Expert
Michael Galve
Michael Galve
Jax Planet
Jax Planet
Are you an Efficient Networks Computer and Internet Expert? Answer questions, earn points and help others
