How to clean inside of screen?
Your tv has two screens on it. The outter screen and the inner screen. The outter screen has a frame around it held on by clips. You can remove this outter screen by gently prying it from the tv. There is a small gape between the outter screen and the tv casing. When prying the outter screen be carefull not to dsanage the tv case or the outter screen frame. Take note of the location of each clips because you will need thses to put the outter screen back on. Clean with a good gentle screen cleaner, (Do Not Use Windex). Philips screen cleaning gel for plasma & LCD works very good. Install the outter screen back on the tv by making sure the clips line up and use light pressure to snap it back in place. Do Not Hit Outter Screen To Force Clips Into Place.. I do this on my tv about once every 6 months or so.
