Question about Brother IntelliFAX 4100 Laser Fax
Everytime a fax comes in it has horizontal lines on it
The copier and printer work fine, with no lines. It is only when a fax comes through that it has vertical lines on half the page.
    Sniper:
  • 66 Answers
Hi
have you checked to see if it is the same sender ?
they may have correction fluid (liquid paper) on their scan glass
Posted on Jul 29, 2009
Printing problem comes after 10 page or 50 pages after ,(cyan,magenta,yellow) color verticals 1and half inch line comes in print .
after printing 10* or 50 pages* at a time then you should off your printer for 15 minutes then restart it again.
*problems comes because your printer goes very hot
Jun 08, 2012 | HP LaserJet CP1215 Color Printer
Receivng a fax and printing pages has vertical
Its ether the toner cartridge or the fuser. send one page to the printer and open the cover when the page is under the cartridge. Pull the cartridge out and look at the page. If you can see the line its the cartridge if not its the fuser. I think its the cartridge. Thank you, Steven 805-520-3003
Jul 07, 2010 | HP LaserJet M3027 MFP Printer
My printer is not printing all the horizontal lines
First try to copy and if copy works fine, means the hardware is fine and issue with the driver.
Do right-click on printer icon and select delete.
Once deleted, run the installation disc and click on add a device, follow onscreen instructions to complete the installation. Open printers and faxes window and then do right click on printer icon and select properties, click on print test page.
Check if it prints fine, if yes try to print from other application. I hope it will work.
May 26, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
I get vertical lines on scans and copies when
Check out this page on our web site at:
http://www.ccl-la.com/dirty_scanner.htm This page shows you what to do to get rid of the lines on scans and copies.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 12, 2010 | Brother MFC-9440CN Laser Printer
Xerox WorkCentre 4150, 3 vertical white lines in all feeder scans
the problem is in the scanner, open it up and see if you can find any smudges, and clean any obstruction, any ink, liquid eraser residuals, can cause this part to appear as lines on your copied faxed image.
dont concentrate on the printer this is a scanner problem
Jul 28, 2009 | Xerox WorkCentre 4150/X Laser Printer
Vertical line on page when scanning/faxing
Clean the scanner glass. You probably have some dirt or whiteout on it. Open up the top feeder and look at the narrow glass and you'll probably find it.
Mar 17, 2009 | Samsung CLX 3160fn All-In-One Printer
My fax Machine has lines going each page that prints out
Get a can of air, open the unit and blow it out.
Also, clean the glass.
That should help solve the problem
Jan 08, 2009 | Brother MFC 4800 All-In-One Laser Printer
Dell 1815 dn prints lines in faxes going out
Dont think its your printer, try faxing to someone else and see if it happens there too.
Dec 11, 2008 | Dell 1815dn All-In-One Laser Printer
Two vertical lines appear on faxed out pages
HP actually provides a service that lets you test your fax machine:
Testing Your HP Fax Machine
See if this helps. Good luck.
Oct 07, 2008 | HP Officejet 5610 All-In-One InkJet...
Vertical line
that means your scanner is dirty or pick up the cover and see if your glass is dirty . also it could be your fuser assembly is bad
Sep 24, 2008 | Canon imageCLASS D880 All-In-One Laser...
Brother IntelliFAX 4100 Laser Fax Logo
94 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
