SOURCE: Trying to put on mower deck belt for cub cadet
Visit this web site http://www.partstree.com/parts/
you can pull up your Cub
SOURCE: Cub Cadet 2166 series. Mower will not engage.
Unfortunately, the circuit is a little complicated - it involves the "PTO switch" (the switch you pull on to engage the mower), a "reverse switch" that senses if you've put the mower in reverse, and a relay operated by the reverse switch. The reverse switch is there to disengage the blades if you try to reverse while mowing. A failure in any of those items, or the connectors and wiring between them, will prevent the blades from engaging. Unless you want to "shotgun it" and replace parts one-by-one on a guess (which many repairmen to do save time, but at your expense) you need to use an ohmmeter or test light to trace and isolate where the failure is.
