Question about Logitech Dual Action for Pc (963292-0403:) Game Pad
I have the rumble pad 2 and need to know how to move the camera
I have programed all the other buttons but need to know haw to get the camera funtion to work for the right analog stick
  • 118 Answers
Right stick x-axis>axis properties>map x-axis to>mouse x axis. do the same for y axis. if you download the latest profiler. it has a tutorial.
ftp://ftp.logitech.com/pub/techsupport/joystick/lgs502.exe
older version has to be uninstalled first you will not loss your profile setting by uninstalling the older version.
Posted on Jul 22, 2009
My volume and channel not moving
I presume that systems used to work OK and you are using the remote. Try the bottons on the TV itself. If they function OK than your problem is the remote. If no funtions work, replace batteries. If only volume and channel are failing than the remote button pads may be dirty. Repair of the remote is dicey but the risk is low. You may need to replace remote.
Nov 30, 2014 | Televison & Video
I need to know how to program it is there a manuall or somthing my game pad
Don't bother looking for a manual or insturction becuase i dont think they exist anymore. heres all you should need to know.
to program autofire
1. Hold autofire
2. Hold the button you want to autofire
to unprogram autofire use the same steps.
to "program" buttons
keep in mind any button can be programed to be a macro but i recommend using the E1 and E2 buttons. One button can be programed to perform at most 12 button keys
1. Hold the program button (til it lights up)
2. press the button you wish to program (wait for beep)
3. press one buton or create a sequence of buttons ( you must hear a beep for each button you want programed)
4. hold program again (til the lights off)
I havnt found any kind of reset to program you either have to program the button to itself or program over the old macros. I dont think it matters how fast or slow you program the keys i think it automatically times how fast the keys are pressed. you can even turbo your macrod buttons. i mostly use these for autoleveling and w-item in ff7. good luck and happy gaming.
Mar 21, 2011 | InterAct Accessories InterAct StormChaser...
We have a convention microwave oven. Model Jmc 243 owp01. Only 2 monts old. The control panel buttons are not lite and do not funtion however the light comes on when the door is opened so the power is...
Possible that the door switch must be checked as this safety switch must latch the power to the main board to set the program and timer. However if the pads are not working then the customer pad, the flexible strip or the main controller board can be faulty that is not making the program controller active.
Mar 13, 2011 | Jenn-Air Microwave Ovens
I need software & manual for GGE909 rumble pad
Hi.
GGE909 rumble pad software (xp/vista/win7/win8/mac) can be found at driverupdate us
It will take 2 mins from you to install...
I hope I have helped you...
enjoy
Mar 25, 2010 | Game Elements GGE900 (51691)
I have a NEC Dterm80 I need to program a button on the phone to be my handset button so I may be able to use my handset. I dont what to have to call a DeltaCom tech in to program.
First and foremost we need to know what system you have. Then we can proceed with how to program the button.
NEC Elite 48, 192, IPK 1
First pick the button you want to program. Lets say button 13 in this example. Next check to see if that button is programmed by pressing Feature and that key. If that key says Vacant then it is available for use.
Next you will need to hit "Feature and 4" on that station to find the port #. Port # is Tel 10 for example. That means port 10 is where your extension resides.
Now type in "Feature, #, 0 *, 8974". The phone should say Program Mode. Now look at the Line Keys. These are the keys right above the # pad. Count from left to right 4 keys. Hit Line Key 4 and then type 12 on the dial pad.
Now that we are in key programming we need to enter the port of your phone. Make sure the blinking cursor is on the far left. If not press * to move to the left. Now enter 10 (port 10 or Tel 10) on the dial pad. The cursor should be right near the L. If not then press # to move to that position on the right. Remember * will bring you back to the left and # to the right.
This is where you are to enter the key #. In our example it is key 13. Dial 13 on the dial pad. Next we are going to change the key to a headset key by pressing "Recall, Line key 3". It should say H Set on the right. Now that you have the proper key set you need to hit transfer to write the programming. Remember to try and find a key that is not programmed, this will ensure that you don't undo any programming that is already in place.
Any other system other than the NEC 48, 192 or IPK 1 will not work.
Nov 17, 2009 | NEC Dterm DTP 16D-1 Corded Phone
My touch pad remote is not programed
Hi, drop down panel door. enter installer code. you need to know what zone it was on before, because I recommend you try to delete it first. so next delete then sensor remote button til you get to right zone, then "done" then use add button sensor remote button then if its the small remotes 2 botton press the 2 bottons. for botton press top 2.sensor group 01
Jan 03, 2009 | GE Security Simon 3 Wireless Home Security...
No game connection
What i would suggest for this problem is for you to use add remove programs. Remove the firmware or software for your rumble pad. Then use your favorite search engine and look for a a registry repair program and download it ( this is just incase that during your install it might of changed the registry that it would not reconize your rumble pad) once you have run this program then install the rumble pad according to what the manufacture has printed. Follow each step exactly as they printed. This is critical because each add on to a computer requires a specific order for the install to be complete and for the registry to enable it. After you are done installing it. Go to your system settings and into device manager. There you will find a list of devices avaliable on your computer. look for your product usually listed under USB. Once you find it click on it and go through the menu to see if this hardware has been enabled and there is no problems. If there is a problem you will see "!" next to the problem area.
Sep 23, 2007 | Logitech Rumblepad 2 Vibration Feedback...
"Locked Door" flashes after interrupting self clean
Robert, see if you can get it back home by using the test funtion. Kill the power to the oven. Turn it back on and on the control press and hold the cooking time and delay start pads together. While hold these keys, press the number 8 pad. The words test should appear in the display. Now press and hold the self clean pad and it should cycle the cam through the whole process. Here is what you should see. 1 test (unit is in unlocked position 0 test (moving toward latched pos. 2 test (latched position 0 test (moving toward unlocked pos. 1 test (unit is in unlocked pos. Press cancel to exit the test. See if this gets you going again, let me know, Catriver
Aug 24, 2007 | GE JBP60 Electric Kitchen Range
Logitech Dual Action for Pc (963292-0403:) Game Pad Logo
493 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Lyle Siemens
Lyle Siemens
Rob boss
Level 1 Expert
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
