Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
I have a Ryobi RBC30SESA Strimmer/Bursh cutter, it is very hard to start, it needs to be primed many times and then it does not seem to run at full speed, I suspect the mixture is wrong but it appears to need a special single keyway tool to adjust this, where can I get such a tool if this is what is needed.
  • Travis
    Travis May 11, 2010
    Please take a photo of the adjustment keyway socket, might be easier
    for users to help find the tool for those of use who don't own this
    model.
    Use any of the free image hosts to upload it to the internet.
    Scholar:
  • 71 Answers
It's set at factory specs. Try putting some carb cleaner in it. sounds like a gummed up jet.
Posted on Jul 23, 2009
Can you help
Sounds like the cable in the upper shaft is broken. Start it without the attachments installed and see if the cable is turning.
Sep 01, 2014 | Garden
Ryobi line strimmer hedge cutter attachment won't cut even though the blades are moving can you give any idea what he problem might be?
grass,string or vines can get wound around the motors shaft, you will need to take off the spinning head to remove debris from motors shaft
Jul 25, 2014 | Ryobi Garden
Starting up Ryobi Petrol Strimmer
full choke on , push petrol bubble 5 times then pull starter cord., with luck it will kick in to life after a 20/30 secs put on half choke , run again for 30 secs the no ckoke.
The main problem with Ryobi products is that they flood very very easly. So the more time you try and pump petrol into the carb the more it will flood . If that happenes then choke off and switch off and then just pull starter cord for about 30 secs then switch on and it could start if not prime it again as above good luck
Dec 24, 2011 | Ryobi Garden
I want to check if a makita rbc 230 brush wood cutter runs on petrol (neat) or two stroke mixture
I think the model your speaking of is the RBC30. It is a 2 stroke mixture. The 430 models are 4 stroke and do not require mixing oil and fuel. They are made by Ryobi for Makita.
Here is the RBC 30
RBC30SESA
  • Powerful 30cc 2-Stroke Petrol Engine
  • Easy-Start Carburettor
  • Expand-It™ Attachments Compatible
  • 18"/46cm Cutting Path Width
  • 2 Year Domestic Warranty
Info on the 430
RYRBC430SES
  • New 4 Stroke Design
  • Light in Weight 7.3kg
  • Safe Anti-kick Feature
  • Reduced Noise Levels, Lower Emissions
  • 2 Year Warranty
This is pretty much the entire line up of their brush cutters:
http://www.mowdirect.co.uk/acatalog/MowDIRECT_RYOBI_BRUSHCUTTERS___PETROL_STRIMMERS_311.html
There is not a 230 model.
Thanks for choosing FixYa.
Kelly
Sep 06, 2010 | Garden
Replace broken pull cord on RBC30SESA trimmer
The reason why ryobi tools are cheap is that when they go wrong and they all go wrong they should be chucked away as some times they can cost more to fix than buy new.
Depending on where you live you can contact roybi andthey have a very good service deppartment
Jul 23, 2010 | Ryobi 15" Electric Factory Reconditioned...
Cant start ryobi 890r brushcutter
My Ryobi 890r brush cutter will start and then die
May 16, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
BAD STARTER
it might have a easy start that wound make it seem like its sliping.change spark plug and gap at 030.see if it helps if not rebuild carb.
good luck
Jul 20, 2009 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Ryobi RLT30CES
I also tried this.
  1. Clean the carb wire gauze air filter behind the roto-choke knob. (undo the nut/washers & long bolt)
  2. Deteremine if fuel is being fed to cylinder - Fully depress & prime the bulb about 7 times, turn to full choke. Pull start cord about 7 times. Remove spark plug see/smell fuel fumes/vapour present in cylinder
  3. Determine if compression is weak - remove plug, put finger over plug port, pull start cord. Should be evident of resistance/pressure build up when cord is pulled.
  4. Of course brand new plug!!! as above (I would try this first)
Hope this helps
please rate my comments - Thanks
Aky1967
Jun 24, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
1,089 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
