The drier won't heat up and it flashes up a number (I'll check tonight again what the number is). it washes fine but won't dry. It is a Zanussi Jetsystem Turbodry 1200.
Have you fixed the problem yet? And if yes, how??
I have the same washing machine with the same problem. So I hope you can help me!
Best regards,
Nourah van Leeuwen
Posted on Mar 07, 2010
Have many people had a problem with the ZDE47100W tumble drier heating element.
I would contact zanussi on this problem they would know more about this than anyone .
Jan 07, 2018 | Zanussi FC1200W Front Load Washer
Clean light "green" flashes 7
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry or high temp wash-heated dry-high temp wash-heated dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 29, 2011 | Dishwashers
Dishwasher won't run, clean light flashing
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 06, 2011 | Maytag Dishwasher
I can't get the control panel to reset. The wash cycle light comes on but it just beeps and the dishwasher won't start. I press the start button and it stops beeping for a minute but it still...
II might need the actual model number. However, you can go to page 9 on this manual and check if the flashing options can fix the problem. I am assuming you have already tried to turn the power off and back on.
The ohter thing to try is the reset sequence. Within 6-7 secs press High Temp/ Heat Dry/ High Temp/ Heat Dry/ High Temp/ Heat Dry. All lights should light up, press Start button to exit.
Jun 24, 2011 | GE Nautilus 24" Built-in Dishwasher
The "clean" light is flashing
Hi
Daniel
Jun 18, 2011 | Whirlpool Dishwashers
Zanussi condenser drier: tank full light on even though empty
its either going to be fluff in the float which you can get at by taken the side panel off .or its fluff in the valve behind the water tank
Jan 11, 2009 | Zanussi TC7114W Electric Dryer
Zanussi dishwasher
hi there sounds like a possible dry joint on the pcb repair and try first
Nov 26, 2007 | Zanussi ZT485 Built-in Dishwasher
Maytag Neptune W/D (Stacked) Drying Irregularly
Mj, 90% of the time long dry times are caused by a pinched or clogged vent. Other things that could be causing this are: cycling thermostat trips too soon, if your dryer is a gas model, weak gas valve coils, drive motor centrifugal switch not allowing voltage to the gas valve or heating element. Check the harness to the motor to make sure it is on tight. Catriver...post back.
Sep 25, 2006 | Maytag Neptune MLE2000A Front Load Stacked...
Washing Machines Logo
323 people viewed this question
Top Washing Machines Experts
