Question about Tools & Hardware - Others
Sandpaper sliding off
I have a Craftsman 4'' belt sander, model #315.11781 which I recieved
without a manual. I finally slided the sandpaper in by loosening the spring on the side and retighten the spring, but when I start the sander, the sandpaper keeps on sliding to the side (in or out). is there a right
tension to the spring?
Thank-you
  • 867 Answers
There isnt enough tension on the belt, hence the side to side movement. keep tightening the spring until it stops
Posted on Jul 22, 2009
How do you put sandpaper on a Craftsman 1/4 sheet sander?
If you have the sander that is in the picture (and I surely do hope that you do), I can help you.
Your sanding felt pad is square, and two of the sides, opposite each other, have a wire spring clip on them.
You lift the clip and rotate it and then you will have a opening under each of the spring clips to insert an edge of the sandpaper.
Cut the sandpaper to 3/4ths of an inch longer than the pad on both sides that are to slide inside the spring clips.
Insert one edge of the paper under one side, then snap the clip down in place.
Then, curl the edge of the other side of the paper with your fingers to fit under the other edge, and then snap that one down on the paper. Good to go.
God bless your efforts.
Nov 05, 2015 | Craftsman 1/4 Sheet Palm Sander
Towel caught in front roller
Well, it sounds like you have a belt sander. I would start by sacrificing the towel and the belt. Even if you tried all day and were able to save them they would probably look like they got caught in a sander. Get a utility knife and change the blade, you will want a brand new sharp blade for this. Start by cutting as much of the exposed towel off as you can. Remember, at this point the only thing you might be able to save is the sander. Cutting off the belt will relieve the tension. When you cut the belt give yourself enough belt on ether side to get a good grip. You might need to pull the belt back and forth as you remove small pieces of the towel. A good pair of pliers might help grip the towel fragments. When you finally do remove all the towel and the belt, take some time to look around the drum for fibers that might be stuck in the bearings and pull them out. You may need needle knows pliers for this. Keep the towel shreds for sating rags to finish the project you're working on so it will not be a total waist.
Good Luck
Ray
Apr 28, 2014 | Makita Tools & Hardware - Others
The sandpaper keeps sliding off the sander everytime I turn it on. Even when I turn the dial it to tighten it or move it over it keeps on sliding off.
You need to turn the dial slowly. If the belt starts to come off turn the knob in the other direction,slowly until the belt is centered. Doing it slow is the trick.
Jun 04, 2011 | Black & Decker 3 x 21 In. Dragster Belt...
How do you replace he belt on a 7447 Sander
To change belt:
1) Put front roller on floor and push down until roller locks back.
2) Put on new sand paper.
3) Loosen tracking screw until front roller is released.
4) With sander running, use tracking screw to center belt.
Oct 10, 2010 | Black & Decker BR300 3''x18'' Belt Sander
My Model # 362 Belt sander keeps breaking belts after just a few minutes of continued use. Why?
This is usually indicative of someone pushing down on the sander too hard while sanding. The motor in this sander is strong enough to pull the belt around even with too much pressure on the sander. This causes excessive heat to build in the sanding belt and sander shoe which causes the belt to break down prematurly. It's also very hard on the sander's bearings and motor. Use an appropriate sandpaper grit that will do the job without excessive pressure on the worksurface. This will make your sanding belts and sander work longer and cooler.
Sep 13, 2010 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Need a manual for a Craftsman belt & circular sander
I found a PDF file on Sears.com website for the original manual for my belt / circular sander.
Oct 21, 2009 | Tools & Hardware - Others
Installing belt on sander
Remove table assembly.
Remove pointer and then slide cover up and out from dust reflector.
Release belt tension by pushing tension lever toward idler drums.
Note: there may be an arrow on the inside of the belt.
The arrow should point in the direction of belt travel to ensure that the splice in the belt will not come apart.
Slide new belt over the drive and idler drums; center belt on drums.
Push tension lever towards drive drum to tension belt.
Hope this helps.
Oct 04, 2009 | Tools & Hardware - Others
Tools & Hardware - Others Logo
598 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
