Question about LG LRFC25750 Refrigerator French Door
Demo mode of GE refridge
Just got a new GE french door freezer on the bottom fridge that is locked in demo mode and can't get it unlocked. Any ideas??
  • jhhoppe May 11, 2010
    When you say demo mode, could explain what features you have access to.
  • 11 Answers
SOURCE: controls not working in GE Bottom w/french doors.
I have the exact same problem with mine.  I was away for 3 months, left it running. Came back and no display.  Unplugged it & restarted it and it worked for a little while and went out again.
         Did you ever get an answer?             I'm wondering about corrosion on the door switch from lack of use, as the display is only supposed to be on when a door is open.  Yours may have been a loose connector from moving it???
Posted on Oct 19, 2007
  • 27 Answers
SOURCE: Digital display is blank in GE Profile fridge
Hi. Its either a bad motherboard or control board. I would check the control board for any obvious signs of damage to the board first. I've seen the control board go blank on the GE side by side and it turned out to be the motherboard. The motherboard is located behind a cover on the back of your refrigerator cabinet. You should have a new motherboard on hand at all times because they fail alot. Be sure to put a surge protector on your refrigerator. Good Luck, Mack
Posted on Feb 02, 2008
stradeteox
  • 88 Answers
SOURCE: freezer working fine but fridge isn't
Either the damper that the air flows up through is closed or the return air flow vents are blocked with clear ice.
Do you feel the air come out all the way at the top of the duct assembly when the freezer door is opened (but it then stops when the door is closed)?
If so, then it sounds like your return air flow vents are clogged. These are located to the left and right of the duct assembly in the rear/bottom of the refrigerator section. Sometimes you may have to slowly pour hot water into these vents to get the clear ice to thaw. The water should go down into the freezer section behind the evaporator and then out the drain in the back.
If you do not get the air to flow out the top of the duct assembly then the damper is staying shut. This could be either a bad damper in the duct assembly or the main board my not be sending voltage to the damper. Hope this helps.
Posted on Jan 08, 2009
tborn6
  • 700 Answers
SOURCE: GE Profile 25.1 cu. ft. fridge is too large for door entrance
yes you can, or just removed the bottom drawer, open the upper doors and slide the refrigeraro thru the doorway by just swinging it thru. a mover friend of mine showed me that trick at it work great.
Posted on Jan 24, 2009
SOURCE: Bottom freezer door/drawer won't close all the way on one side.
Remove all the food from the freezer and then the drawer from the cabinet. Now using a silicone based lubricant, lube the tracks up real well. Be sure to clean the tracks first if gunked up. Make sure nothing small fell out of the basket over time and is laying on the floor in the rear of the freezer section. Once done, you should be fine.
Eric Campion
Posted on Feb 21, 2009
My samsung control on the freezer is displaying OF OFseems ice maker is off I pushed the power freeze by accident and can't get back to regular display
0F 0F on a Samsung refrigerator display indicates that your unit is in DEMO Mode. In DEMO mode, the lights work, but the refrigerator/freezer, fans, etc. will not operate (this mode is for display/retail purposes in appliance stores). Unfortunately, Samsung does not include any info re: DEMO mode in their user manuals.
To exit DEMO mode and return to operating mode, you will need to push 2 display buttons simultaneously for ~ 3 seconds (you'll hear a small chime, then the display window will display the freezer/fridge temps and will then be out of the 0F 0F DEMO mode). The 2 display buttons that you have to press simultaneously will depend on the model of Samsung refrigerator that you have.
I have a Samsung RF18HFENBSR model (french door, bottom freezer, display at top center of fridge compartment). For this model, you press the Power Freeze & Freezer buttons at the same time to enter/exit DEMO mode).
You might try googling Samsung XXXXXXXXXX Demo Mode, where XXXXXXXXX is your model number, and you may find the display button combo for your model. If not, then you can probably get the combination from Samsung support to return your unit to normal operating mode. Your appliance store may also have that information.
Sep 10, 2017 | Samsung Refrigerators
Take PFE29PS out of demo mode
Hold the lock and precise fill buttons for several seconds and a prompt will appear to disable it.
Sep 17, 2014 | GE PFE29PSDSS 29 cu. ft. French Door...
The bottom freezer works but the refrigerator will not get cold. model# MFF2557HES
Sounds like airflow fan needs to be replaced. Most fridges use a small fan that blows air from the freezer to the refridge. If that fan fails you get working freezer and non cool fridge.
May 06, 2011 | Maytag MFF2557HES Stainless Steel French...
Brand new won't get cold
Ours did the same thing and we returned it for an exact same model. Happy to report that the second one works just fine. Don't waste any more time on this defective one!
Jun 15, 2009 | Samsung RF265AA Bottom Freezer French Door...
Cannot get the fridge to start cooling
If the panel temperature reads 0 F 0 F it is in the "DEMO" mode. This is normal if you purchase a floor model. To bring it back to normal mode press ENERGY SAVER & ADJUST FREEZER together for 3 to 5 seconds until it beeps. Then unplug the referidgerator for at least 30 seconds. Then plug it bck in. That will reset the stupid computer and get it back to normal operation.
Did you think this was helpful? Yes No
Feb 08, 2009 | General Electric GFSS6KKXSS Stainless...
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Controls not working in GE Bottom w/french doors.
Aug 31, 2007 | GE PFS22SBSSS Stainless Steel French Door...
LG LRFC25750 Refrigerator French Door Logo
313 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
