Question about Microwave Ovens
G.E. Spacesaver Microwave - Keypad Won't Work
The key pad won't work. I did some research here and cleaned it, and the clock time at least shows now, but nothing else works. Please advise!
  • debdebdeb Nov 25, 2007
    i don't think i could unplug it, as it appears the entire unit would have to be taken out to do that and that is beyond my scope, but thanks.
    also, it only happens intermittently. i am sure that is some kind of clue. and before it will work the numbers 8888 appear on the clock. it won't work for a long time, and then all of a sudden, it will work, but then won't if you try it again right away.
  • klartey Jan 15, 2009
    Westinghouse microwave keypad does not work after cleaning it. I have unplugged it for a day and it still wont work. the only thing that works is the start button but after you push it twice, the child lock comes one. anybody knows what is going on.
My keypad does not work. It keeps tellng me to press start. My clock works and the vent fan button as well as the turntable works as well as the clock. When I unplugged it from the wall, itworked for 2 seconds. Theres a little battery signal on my panel that looks like its charging up.
Posted on Oct 15, 2009
  • Microwave Ovens Master
  • 9,098 Answers
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
You may have a problem with the keypad or the control unit (circuit board / smart board).
We repair these on a regular basis. Details and *critical* safety, disassembly, and troubleshooting info is at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Please write back with more details if you need further help.
Posted on Nov 22, 2007
How do I fix the key pad of a Kenmore microwave model 401.80084700?
I don't know of anyway to repair the keypad. Usually replacement (of the keypad/control console) is the only option. But you might want to remove the ribbon cable that connects the keypad to the control board behind it, clean it with a degreaser (like Fantastic or 409), dry it, and re-insert it, and then try again. (Remember to unplug the microwave oven first before you try that!)
Jul 07, 2014 | Kenmore Microwave Ovens
Microwave key pad won't work
That is a failed membrane keypad.
It is part number 3518522640B and you can order it from the Pros here.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
If you would like to have us do this repair for you, we do that for $39.95 plus parts.
Aug 22, 2012 | Magic Chef Microwave Ovens
Microwave won't set clock
It is most likely the keypad control board has been damaged, first! unplug the microwave oven for 5 minutes, if this works the micopressor will reset, if it fails the control board will need to be replaced, a costly venture.
Apr 14, 2012 | Danby DMW1153 Microwave Oven
The solutions to my microwave prolem (keypad reading commands but keys won't work)didn't help. Do you have a manual I could download?
Try:
1) Unplugging power and plugging back in
or
2) Press Cancel twice while door open (works on my Whirlpool).
Dec 23, 2011 | Microwave Ovens
When power went off and then came back on, screen on micro wave continually shows demo and I cannot set time
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes and try again.
If it still won't work, then you may have a bad membrane keypad / DP circuit.
If your model is NN-P295SF, the service is here.
Parts can be ordered from Encompass here.
Aug 19, 2011 | Panasonic NN-P295SF Microwave Oven
Keypad number buttons not working on ge spacesaver microwave - auto program buttoms work?
Very angry. Fairly new, little-used Spacesaver Microwave [3][Clock][Surface Light] buttons now do not work. We never even press [3], just [1] and [2] to warm sandwiches.
Unplugged for an hour. Still not working. Everything else works. We never use anything else. Bad solder joint in circuit board or keypad?
Thank you.
Aug 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Numbers 4,7,8,9,0 and Beverage on pad do not work. Others do work, do I have to replace the oven? (Spacesaver JVM1440WH04) Over stove oven installed in Feb 2007, in use 4 months each year. This problem...
No you can have the keypad replaced. It may be something as simple as a dis-lodged keypad ribbon connection where it mates to the control panel recepticle. If you look here: http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=JVM1440 there are several model numbers it seems you did not provide all of the numbers but the keypad is the same. The key panel here is $75.00 http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=JVM1440 Then you add a service call or shop charge your looking at well over a $100.00 repair. Your call on how to proceed. Good luck.
Jan 12, 2010 | GE JVM1440 Microwave Oven
The keypad does not work. The display screen says "Press -----k". I'm assuming it's telling me to press clock to set time. But none of the keys work when I press any. Earlier only the Start/Pause key...
try powering down for 30 seconds. if that doesn't work the keypad is shorted or open. do not spray cleaner directly onto key pad when cleaning. it will short it out. rather spray cleaner onto a rag then wipe.
Jul 02, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Oven
I report from owner manual.
F3 means : Short circuit on key panel (your touch pad).
You get F3 error if a shorted key panel is detected for more than 60 seconds.
Solution: . Replace key panel (touch pad).
Try first unpluggign power cord for five minutes.
If you think that the problem may had been caused by water inside the keypad you can try using an hairdryer on the keypad, taking care not to melt the keypad plastic.
If that does not work, then replace the keypad.
You can buy replacements here. or Order GE Microwave Ovens Parts Here
Mar 08, 2009 | GE JVM1630 Microwave Oven
Microwave Ovens Logo
1,889 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
