Trying to set up wireless network (for printing) and don't know default admin password for AR-168D. computer technician is presently here in home office assisting.
  • 813 Answers
Try the passwords as 0000 or 00000000 or 12345.
Posted on Jul 22, 2009
Just installed roku. How do I find password for Home_B698
You will need to login to your wireless router on your computer to get, or set, your network password for "Home_B698". A typical default router IP address is 192.168.0.1, but there can be any number of possibilities depending on router type, and network configuration, and who set it up... Some routers will put their default IP Address, and password on a sticker, located somewhere on the router. If this is the case, type the default IP Address into a browser on your computer, and hit enter, or return. A web page should appear asking for login information... User name, and password. Again this information varies... Typically the default user name is "Admin" or "admin" you can also try leaving this field blank, and just entering the password found on the router. In some cases the password is actually "admin" while leaving the user name blank.
If your successful at loging-in, you need to look at your wireless settings, under one of the sub-tabs you should find a password field indicating your network password. This is what should allow you to login to your network with your Roku device.
Nov 15, 2014 | Roku Streaming Stick
Network password
The default user is admin and the default password is also admin. After you have access, go to security and change the password to your choice. The wireless password is not set at all, and you should be sure to choose an encryption and password for that.
Dec 14, 2011 | Cisco Valet Wireless Hotspot (M10)
Home network-wan-configure-network key
onnect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then click on WAN settings set it as your internet service provider settings enable DHCP Then click on wireless and enable it. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Oct 15, 2011 | Computers & Internet
Idid the steps and say its connected but nothing to be trust I don,t want anybody get my internet I don,t know is th router get the password
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Feb 07, 2011 | Linksys Wireless-G Broadband Router
How do I lock my Dell TruMobile 2300 wireless router to keep the neighbors from getting access to my wireless internet connection
press win key + r
under run type cmd
on the command prompt type ipconfig
not down your defaut gateway.
type it in your web browser, and then enter the correct user name and password for the router.(i u dont know the user name leave it blank or try admin for both user name and password or its combination o call dell for it)
Create a unique password on your router : Once you have logged into your router, the first thing you should do to secure your network is to change the default password* of the router to something more secure.
This will prevent others from accessing the router and you can easily maintain the security settings that you want. You can change the password from the Administration settings on your router’s settings page. The default values are generally admin / password.
Change your Network’s SSID name:
The SSID (or Wireless Network Name) of your Wireless Router is usually pre-defined as "default" or is set as the brand name of the router (e.g., linksys). Although this will not make your network inherently* more secure, changing the SSID name of your network is a good idea as it will make it more obvious for others to know which network they are connecting to.
This setting is usually under the basic wireless settings in your router’s settings page. Once this is set, you will always be sure that you are connecting to the correct Wireless network even if there are multiple wireless networks in your area. Don’t use your name, home address or other personal information in the SSID name.
This is sufficient to secure your router from other to use it.
Aug 11, 2010 | Dell TrueMobile 2300 Wireless Router...
I have switched from cable to AT and T for internet service. I want to use theLinksys I had been using with cable to go wireless. but I don't know how to do it. Also. I don.t know the password.
Reset your router to manufacturer's settings by pressing with a small pin the hole found at the rear of the router. It is labeled "reset".
When the router is reset to default setting, connect the router to a computer and visit http://192.168.1.1 to configure it. By default, username = admin and password = <blank> or no password. If no password don't work, try the password "admin". So username = admin and password = admin.
You you reach the configuration field, you need to enter the configuration settings provided by your ISP (AT&T) to connect to their internet services. Most likely, you will be using a dynamic IP address (DHCP Enabled) for home users or a static IP for business users. But these information you can get from AT&T.
When all is set, try connecting to the internet and try if your wireless router is broadcasting wifi.
Jun 11, 2010 | Linksys Wireless-G Broadband Router
What is my WEP key?
open a browser - clear the address bar - type in
192-168.1.1 - then in the password - forget the username unless u set it - in the password type in 'admin' - just admin that's it -
the go to security - - hunt around and you will see your wep numbers - there will be 4 of them most likely - pick one -
Gary
May 08, 2010 | Actiontec GT704WG Wireless Router...
Don't know the username to "http://192.168.0.1" router Level One.
If you have never changed this from default then the user name will be "admin" & the password will be "password" or "admin. If you google the default password for Your router model then that shoud find it if this does not work. Don't forget to rate me if this works for you.
Jul 06, 2009 | Levelone CP Technologies LevelOne FBR-4000...
Linksys router G - buddy forgot password I am at my brother-in-laws home for the week and they don't know the username and password for the linksys but they do have custom settings. How can I just reset...
Are you looking for the wireless password or the password of the router?
If you want the password of the router, then try the default password of the router. If the default password doesn't work then you will need to reset the router and reconfigure the router.
If you are looking for the wireless network password, then you will need to open the set up page of the router. Is there any computer connected to the router ? If not then you will need to connect the computer to the router. Or any other computer which is able to go online using the router. Check the IP address on that computer. open the set up page of the router. Set up page of the router is the page where you will find all the settings of the router. under the wireless section you will find the wireless network password
Click here for more information about the routers and wireless network.
Jul 01, 2009 | Linksys Wireless-G WRT54GS Router...
Changing router settings from 802.11G to mixed w/802.11B
Switching the wireless mode is easy, and, if you choose "mixed," the other computers in your home can continue to use the G mode unaffected. How you adjust the mode depends on the brand of router. Since Linksys is the most common, here is how it works on a Linksys router:
1) Open your web browser (IE, Mozilla, etc.)
2) Type the web address 192.168.1.1 (default for Linksys routers).
3) You should be asked for a username and password. The default for Linksys is username "admin" and password "admin" OR username "admin" and password [blank].
4) You should then see the Linksys setup screen. The tabs across the top include Setup, Wireless, Security, etc. Click on Wireless.
5) Pull down the menu next to "Wireless Network Mode" (which shold be set to "G -Only" and choose "Mixed." Then click "Save Settings."
This should allow your B-capacle Palm to use the network without a password while still allowing your encryption-capable computers to use the G mode.
I hope this helps - please let me know if I can be of any further assistance.
H2H
Dec 14, 2008 | Linksys (WMP54GS) 802.11g/b Wireless...
k24674
jasbo
jasbo
