Question about Nokia 1600 Cellular Phone
PHONE MEMORY INFECTED
MY NOKIA 3500 HANDSET CAN'T SAVE ANY GPRS SETTING.IT ALWAYS SHOWS MESSAGE THAT MEMORY FULL.
When I save a new gprs setting, it shows a msg as memory full.......or 'no more than 70 sets allowed.
Welcome to FixYa!
To be able to save the new GPRS settings, you need to free some space. GPRS settings occupies a significant amount of space and can only be saved in PHONE MEMORY.
Free some memory space by deleting text messages, pictures and mp3's in your phone memory or transfer it to your memory card.
Thank you for using FixYa. Have a great day. Jas247.
May 19, 2011 | Cell Phones
I CANT OPEN MMS
Make sure that your mobile GPRS settings are active, if not activate it.
For Globe subscribers:
For a list of compatible MMS & GPRS handsets, send NOKIA, ERICSSON or SAMSUNG (depending on your handset model) to 2365.
Note: Regular text messaging charges will apply.
To get your phone's settings, text GO (handset model) to 2951. Example, GO N3650. (For a list of compatible handsets, do as instructed above)
Note: For Nokia 6220, 6600, and 6820, text GO (handset model),, 1234 and send to 2951. Make sure to type in the two commas before the 1234 PIN.
· Enter 1234 when asked for PIN to save settings.
· Send an MMS message for only P5.00 to activate the service.
(or)
just request your service provider for GPRS settings , so that they will send you the settings to be saved, now you can activate and use the Net ans also the MMS service.
Thanks for rating
good luck
Feb 08, 2011 | LG GT540 Cell Phone
Have NOKIA 5300. I have airtel prepaid connection with GPRS activated. I connect my PC with mobile & surff net. But when I want to save web settings (GPRS) , it shows a message "Only 70 sets...
Instead of trying to set your new web settings-whilst in this screen go to 'show web settings'then view all your settings on your system.
If you already have your full 70 settings then delete some in order to save your chosen settings.
Check first if any are duplicated then delete those first.
Then view remaining strings/web settings and decide which settings you do not require.
...............................................BEFORE YOU DELETE ANY....................copy these strings onto a piece of paper in case you need to re-install any afterwards if GPRS plays up and you need to revert back again.
Steve B
Feb 02, 2011 | Nokia 5300 Grey Cellular Phone
Nokia 6300 cannot receive configuraton settings only 70 sets can be saved find a solution
Hi sohail_srk20,
Each time you change the SIM card onto the phone, GPRS settings are automatically saved in the phone memory. Your phone can save only 70 sets of GPRS settings and the 70 empty lots are used now. So now when you change the SIM, you automatically receive settings, and they cant be saved because the GPRS settings memory is full. Hence you get the message.
Follow the steps below to remove the settings:
1) Go to MENU > SETTINGS > CONFIGURATION > DEFAULT CONFIGURATION SETTINGS.
2) You'll see the list of GPRS settings saved on your phone in this page.
3) Select each of the settings you want to remove by selecting OPTIONS > DELETE.
Next time you change back to another SIM card, the settings are saved in the empty lots you just created. Once they become full, the same message shows up again.
If this information was helpful, please rate it.
Thank you for using fixya,
Arun Zac
Dec 05, 2010 | Computers & Internet
Whenever I get a GPRS settings from SMART and GLOBE network, my phone always pop the same phrase "70 sets allowed setting discarded now". How can I get rid of this problem?
Hi firstladyjum,
I'm assuming you are using a Nokia mobile phone.
Arun Zac
Nov 27, 2010 | Computers & Internet
Unable to save gprs settings in nokia 5300 mobile phone, where configuration settings are empty. it shows "only 70 sets allowed settings discarded".\r\nwhen i want to create personal configuration it shows...
Unable to save gprs settings in nokia 5300 mobile phone, where configuration settings are empty. it shows "only 70 sets allowed settings discarded".\r\nwhen i want to create personal configuration it shows "can not add new account, memory full". please help me immediately.........
Sep 22, 2010 | Orange PCMICROSTORE Brand Nokia 5300...
How to open Globe gprs to Nokia 6303
  • For a complete listing of compatible MMS & GPRS phone handsets — send Nokia, Ericsson or Samsung (your handset model) to 2365.
  • To get your phone’s settings, text GO (handset model) to 2951. Example, GO N3650. (For a list of compatible handsets, refer to #1) Note: For Nokia 6220, 6600, and 6820, text GO < handset model >,1234 and send to 2951. Make sure to type in the two commas before the 1234 PIN. Regular text messaging charges will apply.
  • Enter 1234 when asked for PIN to save settings.
  • Send an MMS message for only Php 5.00 to activate the service
GPRS SETTINGS
1. Go to Menu > Choose Settings > Connectivity
2. Go to Data Accounts
3. Create New Account. GPRS/ PS Data
Account Name: MyGlobe GPRS
APN: www.globe.com.ph
4. Save Account
5. Go to Internet Settings
6. Create New Profile
Connect Using: MyGlobe GPRS
7. Save Profile
8. Select the profile MyGlobe WAP in Internet Profile
9. Click Right Soft Key to Choose More and Select Settings
Internet Mode: HTTP
Use Proxy: Yes
Proxy Address: 203.177.042.214
Port Number: 8080
10. Save Settings and repeat Step 9 but this time choose Advance Settings
11. Change Homepage
Title: MyGlobe
Address: http://www.globe.com.ph/globe.asp
12. Save Changes
MyGlobe Internet Settings
3. Create New Account. GPRS / PS Data
Account Name: MyGlobe INTERNET
APN: internet.globe.com.ph
4. Save Account
MyGlobe MMS Settings
1. Go to Menu>Choose Settings>Connectivity
Account Name: MyGlobe MMS
APN: mms.globe.com.ph
4. Save Account
Connect Using: MyGlobe MMS
7. Save Profile
8. Select the profile MyGlobe MMS in Internet Profile
Internet Mode: HTTP
Use Proxy: Yes
Port Number: 8080
10. Save Settings
11. Click Right Soft Key to Choose More and Select Advance Settings
12. Change Homepage. Enter the following parameters and save the settings
Address: http://192.40.100.22:10021/mmsc
13. Go to Messaging>Settings> Picture Message
14. Edit Message Server : http://192.40.100.22:100.21/mmsc
15. From Message Settings, make your Internet Profile: MyGlobe MMS
MyGlobe Stream Settings
3. Create New Account. GPRS/PS Data
Account Name: MyGlobe Stream
APN: real.globe.com.ph
4. Save Account
5. Go to Streaming Settings
6. Make MyGlobe Stream your default APN.
Connect Using: MyGlobe Stream
Jun 26, 2010 | Nokia 6303 Cell Phone
Setting discarded
Dear sir
please i wanted to configure gprs on my nokia 5200 but i cant whenever i enter in to configuration setting the phone will show not enogh memory
ineed your help
Jun 30, 2009 | Nokia 5200 Cellular Phone
Cannot configure gprs[memory full]
when i try to set gprs it show that memory is full in nokia 6300
Dec 29, 2008 | Cell Phones
Nokia 1600 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
