Question about Packeteer PACKETSHAPER 1550-UP TO 512K (ps1550-l512k-csp)
Hi. i have a linksys wrt54g v7.0 and i have a roommate who downloads huge amount of data using bit-torrent, but he says he doesn't. how can i stop him from downloading huge data if i have to by only using the router interface? i dont want to access his pc, but want to stop the huge amount of data which is being downloaded every month and is costing me a lot of money :(
  • 94 Answers
use filter setting of your modem and block site like bit torrent also install networks and check download data and show repport tour friend about download amont link for networks http://www.softperfect.com/products/networx/manual/
Posted on Jul 22, 2009
My router seems to randomly slow down at different intervals throughout the day. Is there any way to tweak it to improve performance?
It depends on what is causing it. The speed you get from your isp varies depending partly on how much the other customers are using their internet, so at peak times your speed will almost certainly slow down. Most isp's also traffic manage and shape, which means they'll restrict your bandwidth, once you've reached their limit, and sometimes what you may use that bandwidth on. ie torrents
Your wireless channel may have a lot of interference, if so changing the channel may do the trick, and whilst you're there make sure it's set to use 802.11g and not just 802.11b, 802.11 is just the name for the wireless protocol. Also make sure your security is as tight as possible to make sure that no one is using your connection without your knowledge. WPA/WPA2 is the better encryption, don't use WEP unless you have to, and use a good network key ie. one thats hard to figure out, a good sign is that it's hard to remember, just don't forget it.
If you're trying to use torrents and you think your isp may be restricting you then try enabling encryption in your torrent software settings. Also the speed of your torrents will vary wildly by their very nature.
Traffic management you can't do much about other than observe the limits or change isp's, but if you do then check out their traffic management and fair use policy first, find one that suits you.
It could also be a problem with the network, for instance you could be suffering from an intermittent low SNR (signal to noise ratio), That would cause dropped packets which would then have to be resent therefore taking longer to download the data. Or it could be an overloaded UBR (universal broadband router) which is the device they use to distribute their service, it's like a huge version of the routers we use. You would need to get your isp to fix those kinds of problems.
So you're almost certainly going to need to phone your isp's tech support dept and get them to go through some diagnostics with you to isolate the cause of the problem. Unless changing your routers settings helps.
Feb 10, 2011 | Linksys Wireless-G WRT54G Router
DIR-628 Wireless Error
- Logon to the configuration page of the router by opening a browser and type in 192.168.0.1
- username "admin" and leave the password "blank"
- Go to Advanced tab and select Advanced Network at your left side
- Look for WAN Port Speed and select 100Mbps and click on Save Settings at the top.
- Good Luck!!!
Mar 09, 2009 | D-Link AirPlus DI-524 Wireless Router
My linksys router wrt54gp2 is having to be continually "reset". Any suggestions?
It sounds to me like your old router is starting to fail. If you have a computer running Peer-to-Peer sharing software like Limeware, or Bit-Torrents, they may cause it to freeze. If nothing like that is running, try another router to see if the new one fixes the issue.
Jan 05, 2009 | Linksys Wireless-G WRT54G Router
Help with Static IP address configuration
no need to set static IP addresses for the PC, i have been using UTorrent client with a laptop and used the laptop on different network, just set your torrent port to be dynamic, or let the torrent client find an open port everytime you use it (it is always under network settings / preferences).
if you have other questions just let me know, i'd be more willing to help out.
-voodoomox
Jul 30, 2008 | Linksys Computers & Internet
Need driver for Linksys MRT54G Ver.2
Go On Google And Search Linksys Wireless-G MRT54G Ver.2
Driver And That Should Do The Trick
Jul 09, 2008 | Linksys Wireless-G WRT54G Router
Help with my router
You did not have this problem before because port forwarding was set on the previous router settings, or you were using a modem ( no firewall) .
Here are instruction for port forwarding
Here are more instuctions
One last thing, if your computer is powerful enough (1gb memory would be good), use Azureus, is much better.
Jun 08, 2008 | Linksys Wireless-G Broadband Router
Linksys router wrt54g
try using a blank username and admin as password.
Feb 16, 2008 | Linksys Wireless-G WRT54G Router
Dowloading
how are you pluged into the router? wireless or eathernet? wireless conections are not fast enough for these down loads. plug directly in to the router for down or uploading
Dec 29, 2007 | Linksys Wireless-G WRT54G Router
Packeteer PACKETSHAPER 1550-UP TO 512K (ps1550-l512k-csp) Logo
1,358 people viewed this question
Top Packeteer Computers & Internet Experts
David Payne
David Payne
Are you a Packeteer Computer and Internet Expert? Answer questions, earn points and help others
