Question about M-Audio Delta 1010 Sound Card
Popping and clicking in delta 1010 playback
I have 2 x delta 1010 cards running on a pc - core 2 cpu and neo p965 mobo, 4 gig of RAM, XP SP3, i get popping and clicking on recorded playback @ 96kHz / 24 bit even though im only using 6% of the CPU and regardless of buffer size, sync set to internal, using the delta asio driver and control panel ( I think it's the SP3 version), it's driving me crazy, CPU, disk and RAM are only idling, I can't figure why I should get this issue
  • christianrya Jul 23, 2009
    Hi thanks for your reply, however the 96kHz refers to the audio recording sampling rate of the hardware rather than an audio frequency / pitch. Much appreciate the time you took to reply though.
  • 198 Answers
Frequency response: 20Hz-22kHz, +/-0.3dB popping and clicking in delta 1010 playback - spacer.gif dynamic range (A-weighted): 109dB (A/D), 117dB (D/A) spacer.gif signal-to-noise ratio (A-weighted): -109 dB (A/D), -117dB (D/A)
I found these on the site, seems you have the khz way too high.
All good.
Here's the link to your site.
Posted on Jul 22, 2009
  • Mixplyxit Tigerbait Jul 23, 2009
    When that thing happened to me, I had to turn the recording volume to 50%, actually all my levels had to be at 50% for a clear sound. Master volume, MIDI...all of them.
    Some things are just weird finicky.
In call of duty ghost do i need to buy 1 whole 8 gig of memory
You need to have 6 gigs of free dynamic ram.(Not including that used by the operating system and any other applications you have.
The way that memory is organised in a computer these days is usually in pairs or DRAM (dynamic random access memory) sticks which are matched. This allows the CPU to withdraw data from both memory sticks in the same clock cycle (DDR double data rate) which improves the over all speed of the processing.
So legal combinations over 4 gigs which will use the dual channel feature on your motherboard will probably be.
2 x 4 gigs sticks = 8 Gig DRAM
2 x 8 gig sticks = 16 Gig DRAM
Below is the minimum specification requirement.
Note: MINIMUM Faster CPU better graphics card and More ram is better.
CPU: Intel Core 2 Duo E8200 2.66 GHZ / AMD Phenom X3 8750 2.4 GHZ or better CPU Speed: Info RAM: 6 GB OS: Windows 7 64-Bit / Windows 8 64-Bit Video Card: NVIDIA GeForce GTS 450 / ATI Radeon HD 5870 or better Sound Card: Yes Free Disk Space: 40 GB
Feb 24, 2015 | Activision Call of Duty: Ghosts Full...
What is the best upgrade cpu for a compaq presario sr5110nx 32 bit vista O.S... ATHLON 64 (single core) without having to go to 64 bit, and/or new drivers ?
The 400W PSU is going to limit your CPU selection to dual-core at best, although you might be able to get away with a higher-end dual-core CPU if your RAM is not ECC and not dual-channel, and you're not running anything serious in terms of a graphics or sound card or a SCSI array.
Given your current setup I'd really look for a 1.6Ghz dual-core Athlon which has a decent amount of KB in its Level 1 and Level 2 cache, but 3MB for its Level 3 cache.
Anything beyond that ballpark of a CPU upgrade is certainly well within the bounds of diminishing returns, and you should look at getting a new PSU, motherboard, and probably RAM (I'm guessing you're using DDR2 RAM currently).
May 24, 2014 | Compaq Presario SR1050NX (DW257A) PC...
Hi i have a imedia desktop, the mobo is a msi 7168 ,( socket 939) the origional cpu is a amd athlon 3200 single core ! now i have replaced this with a dual core athlon 4400+ now the memory has 4 dimm...
First time I heard that But Maybe your board needs a bios update which I personally wouldn't do unless you really know what your doing. I would buy better ram and more of it and just use the two slots that work.
Jan 24, 2011 | AMD (90613) PC Desktop
Can I Play gta IV/4 on my pc? Specs Ar As Follow: DELL PRECISION 650 With: 2X Seprate Intel Xenon CPU's @ 2.40Ghz Each (4.80Ghz Tot) 1.50GB RAM (Memory) 80GB IDE Primary, 40Gb IDE Seccondary, 40GB...
it will run, but get more ram, your best ram is 2 gig ram to run the game, and all so do a game test on he video card to see if it will lag, there a GTA IV demo out there i belive so try that b4 buing a new ram
Jun 15, 2010 | Dell PRECISION 650
Minimum System Requirements
  • OS: Windows Vista - Service Pack 1 / XP - Service Pack 3
  • Processor: Intel Core 2 Duo 1.8Ghz, AMD Athlon X2 64 2.4Ghz
  • Memory: 1.5GB, 16GB Free Hard Drive Space
  • Video Card: 256MB NVIDIA 7900 / 256MB ATI X1900
Recommended System Requirements
  • Processor: Intel Core 2 Quad 2.4Ghz, AMD Phenom X3 2.1Ghz
  • Memory: 2 GB (Windows XP) 2.5 GB (Windows Vista)
  • 18 GB Free Hard Drive Space
  • Video Card: 512MB NVIDIA 8600 / 512MB ATI 3870
Source :- IGN PC
this is what it says on the box...so if you dont have these specs..forgett it!!
Jun 15, 2010 | Rockstar Games Grand Theft Auto™ IV for...
To upgrade to a newer and better CPU processors enabling me to play more quality games Min requirement CPU type and speed Intel 2 duo or equivalent What types and models and specs please. Have at...
You should get a quad core processor, with a minimum of 3 to 4 gigs of ram, and an asus SLI or crossfire Motherboard. This and a nice 1 terrabite drive can be done for under $500.00, unfoutunatelly, thats just the way they make it. I PLAY cod4, and I run a dual core with 2 gigs of ram and a $300.00 asus MB, with twin 7900 video cards in sli. and it just about runs it, the new games are processor and ram intense, let alone video cards. I would suggest a single card if cost is a factor, you can always add a second or even a third card later. But the you don't want to be the slowest guy playing, especially if you like first person multiplayer shooters
Jun 12, 2010 | Compaq Computers & Internet
It says board can take 4 gig of memory but back slots 2 big
If your MoBo supports 4 Gigs, Vista 32 bit will only utilize approximately 3.48GB, and XP 32 bit will only use 2GB, so unless you are running Vista 64 bit (which will use up to 8GB, if your MoBo will?), the OS isn't going to see but 2 to 3+ depending on which version of windows you're running,
As for the slots being too big, you are probably attempting to install the wrong RAM for your MoBo. Compare the RAM in question with what the MoBo manufacturer says is compatible.
Good luck, and I hope I helped you.
Apr 10, 2008 | Computers & Internet
Video card
This may sound weird, but remove ram to make it 2 gigs and try it again, some mobo's have issues with 4 gigs. 3 gigs usually works too.
Apr 03, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Clicks
try to change the clock sync in the sound card to independent
Mar 26, 2008 | M-Audio Delta 1010 Sound Card
Prob with my p965 neo
You could need a bios update, go to the link below and to the bottom for live update, but caution; read the small print. http://global.msi.com.tw/index.php?func=downloaddetail&type=bios&maincat_no=1&prod_no=265
Sep 26, 2007 | MSI P965Neo-F (7235010P965NEOF)...
Open Questions:
M-Audio Delta 1010 Sound Card Logo
426 people viewed this question
Top M-Audio Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
John Bolton
Jim Goldsmith
Jim Goldsmith
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
