Question about Avalon Medana Gold-Tone Open Face Railroad Pocket Watch with Chain, # 4022
How do I open a medana pocket watch?
Children's clip on model.
I found this watch in the couch yesterday and it's not working. I don't know if it needs a battery or if it is a wind up watch that has been stripped. I can't find any seams in the case and don't know how to open up the watch to take a look inside.
Is it normally a wind up watch or does it need a battery?
  • 2,334 Answers
First -let's check out what type of watch you have. If you push the crown in and it turns freely back and forth with no resistance at all - this is battery driven watch.
If you do the same and feel and hear some clicking and resistance- this is mechanical (spring driven) watch.
Next - the case: Usually all pocket watches have snap-on casebacks. Take an eyeglass and examine the case. Even if you think there is no any grooves or gaps- try to pry it using watchmakers caseback opener (about $5 on ebay).
In case if there are no chance to open caseback - that means you have one of the cases assemblad watch glass fitted last and that means you have to take glass out first and then only to get to the movement.
As you will not be able to get the glass out without braking it, the only solution will be to visit your nearest watchmakers shop and ask for help.
Rate, please.
Posted on Jul 22, 2009
How do I change my ravel watch battery
use a thin pocket knife blade to gently pry the rear snap on cover off.
Oct 07, 2014 | Ravel Clip On Doctors Nurses Unisex...
How to set the time for ALBA V602
Try Googling (Avalon)(V602)(manual) without parens.
Jun 02, 2012 | Avalon Alba Medana Unisex World Traveler 2...
How do I set the time on an old Regina pocket watch. I can wind it and it runs well. The piece to wind the watch does not pull in or out to set the hands.
If you can wind your pocket watch using the crown, but you cannot see any way of setting the watch, you probably have a "lever-set" movement, though it's possible you might also have a "pin-set" movement. Do you see a little button you can push in, either at 1-2:00 or 10-11:00 on the watch case? If you, you have a pin set watch. Push and hold that little button in while you twist the winding crown, and that will let you set the time. End of problem.
Setting the time on a lever-set watch is a bit more complicated and will require taking off the front bezel of your pocket watch--the metal ring that holds the watch crystal in place. Pocket watch cases of this time are usually made in 3 pieces: the bezel, the main case body, and the back. The procedure used to remove your bezel depends on the type of watch case you have.
Take a close look at the front of your pocket watch. Do you see any hinges at the bottom (that is, below 6:00 and where the bezel meets the main case body)? I suspect that you won't, as double-hinged cases are usually associated with an older style of pocket watch, but it's worth checking. If you do see little hinges for the FRONT (it's more likely that the back will be hinged), then look for a little lip on the bezel that's used to pry open the front. Pull on that to open the case.
If you don't see hinges, which is what I expect, your front bezel unscrews. You can try to do this with your bare hands, but it's a lot easier if you have a bit of "gripping" rubber so your hands don't slip so badly. I have a small rectangle of shelf non-slip stuff that works perfectly for this. Turn the bezel counterclockwise. It may resist a little bit at first due to accumulated dirt, but then it should easily screw off.
Once you have the bezel away from the face, look closely at about 2:00 on the watch dial. Just at the edge of the dial, you should see a little lever or button. GENTLY pull this away from the watch face until it stops. Now, when you turn the winding crown, you should be able to set the time. Once the time is set, gently push the lever back to its prior position. Now, you should be able to wind the watch without changing the time.
Be very careful when screwing the bezel back onto the watch body. These parts typically have very fine threads, and it's easy to cross-thread the pieces. Don't force the two pieces together; once the threads catch properly, the front bezel will screw on easily without resistance.
An older style of pocket watch required the use of a little key to set the time from the back of the pocket watch movement. However, these watches were also wound by the same key, so the fact that you're able to wind this watch with a crown suggests to me that your watch doesn't use this system.
May 27, 2011 | Watches
I have a Majestron quartz pocket watch. How do I replace the battery?
  • Flip over your pocket watch. Remove the back of your watch. The back of watches are either screwed on by four small Phillips head screws (unscrew them) or the watch has a press inserted back (slide a thin knife blade under the edge of the back of the watch and pry it off).
  • Remove the circular watch battery out of the back of the watch.
  • Take the battery to any department store or watch store and purchase a new replacement battery.
  • Insert the new battery into the back of the watch.
  • Screw on or push on the back of the watch. Set the watch to the correct time.
  • Aug 23, 2010 | Watches
    Sweep second hand sticking on colibri pocket watch. How can I correct. I just had battery replaced.
    mcdevito75 here, This is a very common problem easily fixed, when the battery was change the repair prerson could have interfered with the seconds hand bending it ever so slightly so it hits the other hands or it became loose, return to the person who changed the battery, they"ll take the back off and fix that seconds hand. Remember this may be no ones fault so I don"t know about any extra charges for service on your watch. This is just my info to you.
    Jul 02, 2010 | Colibri Swiss CSQ Pocket Watch
    How do you open the back of an antique Elgin pocket watch
    You might be able to pop it open with a pocket knife ... don't stab yourself though.
    Mar 08, 2010 | Elgin Circa 1904 Watch
    How do i remove face of interchangeable watch?
    This is called BEZEL you want to lift off. Take watch case opener (or just a pocket knife), insert the blade between case and bezel, then carefully pry up bit by bit, going all around the case. Make sure you are pressing blade in while prying up the bezel. This will not let knife to slip and scratch the watch. Rate me, plz.
    Feb 12, 2010 | Avalon Medana Goldtone with...
    How find serial number on ~1910 hamilton pocket watch?
    The serial number is usually engraved on the movement. If you open the back of the watch, you should be able to see it.
    I looked at the Hamilton pocket watch site (in might be helpful if you visit the site, simply type "hamiltonpocketwatches.com" into your search engine and your will be able to examine photos of a number of movements).
    The position and size of the number varies but it shouldn't take to long to find. One of the pictures I found impossible to see the number but the rest I found, although sometimes you had to look quite carefully.
    Jan 29, 2010 | Sterling J3E Hamilton Antique Pocket Watch
    Dont know how to open the case of my jules jirgensen pocket watch
    Its like a clasp just use a knife an open it at back case you can groove where you placed the knife tip.
    Hope it may helps:
    Jun 21, 2009 | Jules Jurgensen 7381 Pocket Watch
    How do i open this old pocket watch?
    You just use a knife or if you have a swiss knife its better.The cover of your pocket watch its like a clip look at the side of pocket watch there is a marker its like pinch mark put the blade of the knife push it then twist to open .When open already try to watch out not touch it the coil (bronze color) its very sensitive,when touch its easly to break causing to malfuntion.When battery is already change going to close look the gasket for properly place.
    Hope it may help you
    Regards;
    VOTIT
    DON'T FORGET TO RATE;
    Jan 23, 2009 | Watches
    Avalon Medana Gold-Tone Open Face Railroad Pocket Watch with Chain, # 4022 Logo
    572 people viewed this question
    Top Avalon Watches Experts
    Ngoro
    Ngoro
    TStevens
    Are you an Avalon Watch Expert? Answer questions, earn points and help others
