Question about Printronix P5205B Matrix Printer
Printronix p5205B The printer starts out fine and on long runs it gets light on left hand side of document then it goes blank in that area and comes back to full print and looks good. we have switched hammer sets with another bank and that has not taken care of the problem.
    Scholar:
  • 111 Answers
Check to make sure that your ribbon is not folding on the left. Have seen many printers with that ribbon guide off a little causing that issue.
If this is not the case you can try adjusting your platen. If that doesn't work, Shuttle are know to go out. They have coils behind the frets which lose resistance over time. If this is the case the shuttle will need to be replaced.
If you have any questions or need parts or printers please contact me we are an ASR for Printronix. We also offer free technical support.
Thanks,
Rory Cardenas
Midrange Repair and Parts
3821 W. 127th Place
Alsip IL 60803
708-597-4222 x240
rcardenas@mrp.to
AOL IM: RORYMRP
Posted on Jul 29, 2009
Is there a driver of printronix p5000 for win7?thanks.
This printer has already been added to a legacy product line, meaning its kinda old. Currently there are no driver for Windows seven, but quite often another driver will work. http://www.printronix.com/WorkArea/DownloadAsset.aspx?id=5804
Jul 27, 2011 | Printronix P5205B Matrix Printer
My copies have a thin blank streak about 1 inch in on the left side. the streak is about 1/4 inch wide and goes down the whole sheet of paper
Start a print or copy, and just as the trailing edge of paper is entering the machine; quickly open it to stop print and take out the cartridge and look at the drum and the paper underneath. If the issue is there at that point then it would point to the cartridge. If not then it is in the fuser area.
Clean the loose toner up with a dry lint free cloth.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 20, 2011 | Brother DCP 1000 All-In-One Laser Printer
Not comming online
Hi there remove the previous driver & reinstall it again & try.
Feb 01, 2011 | Printronix P5205B Matrix Printer
I LOST MY CD DRIVER FOR PRINTRONIX P5205B WHERE CAN I DOWNLOAD
I tried some of the online drivers. They were not good for use with vista. The P7000 driver seems to work for my P5205b...except that .pdf files print up and down instead of sideways!
Oct 13, 2010 | Printronix P5205B Matrix Printer
A have printronix p5005 printer but printout not clear
Remove the black cover over the shuttle and look for a phase number hand written in blue marker on the right side of shuttle. Press the up and down arrows at the same time to unlock the control panel. Press left arrow to go to diagnostics. Down arrow and right arrow until phasing. Set phasing number same as what was written on shuttle assy.If it is making noise then the shuttle is bad.
Sep 13, 2010 | Printronix Line Matrix P5005B Printer
When I click "Print" paper feeds through the printer, but nothing prints
try to reload your catridge on the carrier or cartridge holder..
and clean your printer tab circuit and also the cartridge tab circuit and run maintenance page on it..
go to your printer panel and select maintenance ..browse clean printhead..and print maintenance page..to clean the cartridge..
May 18, 2009 | HP Office Equipment & Supplies
Whenever I try to print out a word document only half of it ever comes out ( the left hand side ) but the right hand side is completely blank. Is this likely to indicate a printer problem or the way the...
Try to change text orientation form portrait to landscape.If the black is on the same side of the text problem is on the document, if black is on the same side of the paper problem is on the printer.
Sep 25, 2008 | Office Equipment & Supplies
WHAT DOES A L1 MEAN
The L1 is indicating a scanner lock.
1. Turn machine off.
2. Make sure the scanner lock is unlocked. This is a clear plastic knob. (it is located on the left hand side of the machine under the document glass in the copy exit area - check your manual for a picture.)
3. Turn machine back on, watch scanner to see if it moves.
4. Try a copy.
5. If you still get an L1 then it might need service because the scanning bar is jammed.
This also is a fix if you are getting blank copies.
Hope that helps...
Jun 23, 2008 | Ricoh 3310LE Copier
WILL NOT COPY
Dear, after changing the cartridge, printer print a test print. OKAY. Take that test print and put it on the scanner (printed area should on the side of mirror) then press "scan" button on your printer "bottom left". When the light stop fluctuating. Keep out the paper from the scanner. After this Printer will work properly
Sep 09, 2007 | HP PSC 1315 All-In-One InkJet Printer
Prints four blank pages between each printed document...
this is your data cable problem change datacable
and change setting to your computer cmos setup
go cmos setup find parralal port mode option select EPP+ECP
First you change your datacable if problem can't solve so change
cmos setup option
Aug 15, 2007 | Printronix Line Matrix P5210 Printer
Printronix P5205B Matrix Printer Logo
219 people viewed this question
Top Printronix Office Equipment & Supplies Experts
Cliff
Nick
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
