Question about Canon CLC 1150 Color Copier
Error codes E020/04E0
I am getting the same code, but my fuser isn't getting hot at all. Will the problem cause the machine to stop functioning and the fuser to shut down???
  • Canon Master
  • 1,294 Answers
Check the thermidtors & thermofuse and clean it.
Posted on Aug 01, 2009
  • 22 Answers
Replace black starter/ or replace Drum if over 40,000 prints. Error code E020/04E0is for Black starter overtoning
Posted on Aug 12, 2009
Canon code E000001-0002
E000001-0002 refers to the fuser assy either getting to hot or not hot enough. Fuser error codes cannot be reset by power cycling the machine even though that is what the display tells you to do. In order to reset the fuser error code you must enter the service mode & reset the code. To enter the service mode:
press"Additional Functions" button (looks like a picture of a head with a star inside)
press the #2 and #8 at the same time (simultaneously)
press "additional functions" again
The display should show a choice of
copier,feeder,sorter,fax,or board service modes
Select copier
select clear
select ERR
press OK
Turn power off & back on.
****IMPORTANT****
After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils at 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair.
Oct 21, 2015 | Canon Office Equipment & Supplies
I am getting error code E000001-0002 in my IMAGE COPPIER 3545.... how to solve it
Select copier
select clear
select ERR
press OK
****IMPORTANT****
Dec 20, 2014 | Canon CANNON IR 3530 COPIER FOR 220 VOLTS...
We have an SC548 code on our Ricoh3500
"Fuser not installed error code". Did you have a paper jam in the machine? If so open the right door and make sure that the fuser unit is correctly set. You have two tabs on the end next to them are levers lift them, then pull on the tabs "C1" fuser unit(unit that gets hot) pull on them then the unit will come away from the machine slide it back into the machine making sure not to slam it. Close the machine.
To reset the error code go into service mode "clear 107 stop hold the stop down for 5 seconds" select copy SP then 5810# execute then restart machine. Hope this helps.
Nov 10, 2013 | Ricoh Aficio SP C811DN-DL Printer
My canon C3170i shows error E000001-0010
Product : imageRUNNER 5070 / 5570 / 6570 Title : Fuser noise and intermittent E001 code Error
The upper fuser roller section makes a noise and intermittently error code E001 occurs Workaround : In this case, the UFR Shutter inside the upper fuser roller was installed reversed (180 degrees out of postion). Installing the UFR Shutter in the proper orientation corrected the problem. Note: the UFR shutter installed in the reversed position will cause a noise and block the Main Thermistor when the shutter should block the Sub Thermistor. In turn, the shutter will block the Sub Thermistor when the shutter should block the Main thermistor. This will cause improper temperature for the Upper Fuser roller and cause the error code. suggested to go in service mode and reset the error, and see if it will solve the problem. If the problem presist, a code will appear and that will be the one we should work on. So we did clear the error, and the machine is functioning.
Entering service mode: press Additional Function > press 2 & 8 at the same time > press Additional Function again Clearing the Error: press Copier > press Functions > press clear > press Err > press Ok. Restarting the Machine:Power off then On.
Oct 12, 2011 | Canon Office Equipment & Supplies
Error Code C0520 is shown when the machine is started. No sign of further function. Minolta Cspro 3000 model
open the front door to your left small access cover remove cover press the trouble reset if the code comes back replace the fuser unit try below web site for parts for the fuser (the hot part) continue to reset can cause a fire
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
May 19, 2011 | Minolta Di3010 Copier
Ir6000 error code e246-0002
Select copier
select clear
select ERR
press OK
****IMPORTANT****
After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils @ 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair.
Jan 11, 2011 | Canon Office Equipment & Supplies
My copier minolta cs/pro ep 2010 does not function. when you switch it on it displays a spaner symbol and error code 05
This is a C05 error code. This means you have a fuser error. The fuser is the section that gets hot right where the paper exits the machine. Most common failure in the fuser unit is the thermal fuse. The repair requires removal and some dis-assembly of the fuser unit to replace the fuse. Also have to use a special reset procedure to clear the C05 code from the machine after repairs are made. Do you have access to a local repair shop that can repair this for you?
Mar 20, 2010 | Minolta EP4000/5000 CS/PRO Copier
Error code 010-397 dell printer 5100. Have change fuser and restart printer keeps coming up as error message
) The fuser gets very Hot!! Let cool for 10 minutes after turning off the power and unplugging the copier!
2) Pull the two blue locking tabs forward and remove the fuser unit. Reinsert and push back on the tabs to lock back into place. Sometimes just reinserting the fuser will allow the catch on the locking tab to function correctly and push the trigger on the sensing unit. Turn the copier back on and pray the error code doesn't reappear..
3) Mine reappeared. Evidently the catch on the fuser unit was still not pushing the trigger forward, causing the copier to surmise that no fuser unit was installed.
CBR Tech Solutions or http://www.cbrtechsolutions.com
Oct 14, 2009 | Dell 5100cn Laser Printer
Error E000
the machine model or brand is not mentioned,
but if it is canon this code relates to heater [fuser} proplem
Dec 21, 2007 | Office Equipment & Supplies
Error message on screen E000001-0002
E000001-0002 refers to the fuser assy either getting to hot or not hot enough. Fuser error codes cannot be reset by power cycling the machine even though that is what the display tells you to do. In order to reset the fuser error code you must enter the service mode & reset the code. To enter the service mode: press"Additional Functions" button (looks like a picture of a head with a star inside) press the #2 and #8 at the same time (simultaneousley) press "additional functions" again The display should show a choice of copier,feeder,sorter,fax,or board service modes Select copier select clear select ERR press OK Turn power off & back on. ****IMPORTANT**** After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils @ 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair. Good Luck!! I can be reached @ bspier@carlsonsupplies.com if you have any questions.
Sep 21, 2007 | Canon imageRUNNER 2200
Canon CLC 1150 Color Copier Logo
369 people viewed this question
old marine
old marine
