Question about Insignia 600W Bridgeable Amplifier with 12" Subwoofer
Does not turn off and drains the battery
The amp does not turn off. The amp is always on even when the car is off and it drains the car battery.
  • Marlon Jul 22, 2009
    it is hooked to the stereo and when the stereo turns off so should the amp but it does not
    i have another amp hooked up the same exact way and it works just fine.
    Problem Solver:
  • 4 Answers
Check your remote wire, AKA "REM".
If you other amplifier turns off properly when the stereo turns off. Try to find where that amp's REMote wire goes. (It will be a verry thin cable (compared to your 12v rail for power).
If all else fails, you can always connect your REMote wire to a 12v source (ANY 12v source that turns off with the vehicle) Such as a cigarette lighter socket, or any other 12v source that turns on and off with the car.
Tx,
JeremyM
Posted on Jul 29, 2009
    Top Expert:
  • Insignia Master
  • 76,070 Answers
Do u have the amp hooked to a switched terminal of the igntion switch?
Posted on Jul 22, 2009
How do i turn off the clock light on a 1999 Pontiac Grand Am? My clock light wont turn off, and its draining my battery extremely fast.
The LED light would only use a tiny amount of power to stay lit, much less than any small bulb in the car. You might have a poor battery, or you might have a drain on the battery from something else staying on. Any parts store could test your battery for free. That's where I would start, making sure the battery can hold a full charge.
Is the clock light in a radio display? Maybe an amplifier or something connected with the radio is staying on? If the clock is a separate fixture (and I don't even know if they still put such things on cars lately- a separate clock, I mean), then the clock could be unplugged. I don't think there would be a way to turn the light off.
If you have a known good battery and it is still draining fast, there are YouTube videos and explanations on how to hunt down an unintended draw. Mechanics may refer to it as a "parasitic drain"
but it is really an unintended drain. Your car's computers, and security systems, and radio and clock memory will always require a very small amount of battery power when the car is shut off, but that amount is measured in milli-amps, very small fractions of 1 amp of power. usually less than 100 milliamps which is 0.100 amps, or 0.1 amp- see, much less than one single amp. A small bulb like under the dash may be rated at around 2 amps or up to 5 amps for typically larger bulbs. A small bulb might actually drain the battery over several hours. Headlights , you are talking lots of amps, I'm not certain but say around 20 amps. So you see, your clock light would have to have a bad short in the wiring to actually drain a good battery. The light itself would not. This is just me talking off the top of my head, I'm not an expert on electronics or electrical circuits, but I think the information is accurate.
Oct 07, 2016 | 1999 Pontiac Grand Am
Battery constantly being drained. How do I find the source?
Start with the simple things. Auto parts stores can test your alternator for bad diodes, which if failing can cause this. Next, disconnect battery neg and hook up amp meter, then remove one fuse at a time to find which one changes the reading, then figure out what that fuse powers and check for something like a glove box door loose and not turning off the light. I have even seen a relay sticking on, or one being replaced by the wrong type such that the pins were wrong and the coil was always on. You can find this by feeling the top of each relay with everything turned off. If one is warm or hot you have found the problem.
Apr 21, 2016 | 1995 Oldsmobile 88
Battery keeps drainging
Try disconnecting the alternator leads overnight but make sure they are kept away from the body, the big cable is always HOT. See if that does it overnight. If its OK then the alts duff. If not then get a small tester / amp meter set up and connect it between the neg post and the neg lead. This will give you some idea of the drain in amps. With the car locked as normal remove and replace the fuses to lights,door locks etc until the ammeter suddenly reads zero. Then you have an idea of which item is draining it. Door locks are an old favourite after the alternator. Alternators can back drain a batt even if they show a charge when running. Get a pal with electrical knowledge to help.
Nov 01, 2015 | Cars & Trucks
Replaced alt/ battery 2005 PT cruiser is good but i loose the charge and battery is dead by morning ...even after running my car !
Connect an ammeter and set to the 2 amp scale and check out the current drain with the ignition key removed. Remove a fuse one by one until the current drain goes down. That is the fuse that is connected to the power line that is responsible for the drain. Check all of the accessories, etc on that line for the draw.
In meantime till you resolve the issue just disconnect the negative battery terminal till next time you want to use the car so the battery does not drain.
Sep 15, 2015 | 2005 Chrysler PT Cruiser
Why does battery drain ?
there are several reasons...not enough cells in a weak battery(not enough cold cranking amps in battery to turn the car over). Check your alternator as well. Does the temperature drop? Sounds like you need a new battery(also when you turn off your car- TURN OFF EVERYTHING...sometimes a radio, or something not turned off(even a trunk light, interior light, security system(various things)- can zap the juice from your battery overnight or within hrs.-leaving not enough to start the car the next day....Hope that helps....Xx, Jasmine
Aug 15, 2014 | 1995 Lincoln Town Car
2004 Dodge Durango. When it set over night there is not enough charge in the battery to turn over the engine. The battery is one and half years old.
Maybe the alternator is not charging the battery up well. To test, put a voltmeter on the battery, engine running. If voltmeter is less than 13.5 volts, suspect a weak alternator-have it tested.
If charging system and alternator is good-charging between 13.5 volts and 14.5 volts, have the battery tested. Even though not old, it may have a dead cell. A parts store can load test it and see.
If battery and alternator are both good, you may have an unintended drain on the battery. You can check this by, first charging up the battery, then leave the negative terminal off the battery overnight. If it starts good next day, there may be a drain, something like a glove box light, an under hood light, a radio amp left on.
Post back if you want help with finding an unintended drain.
Sep 30, 2013 | 2004 Dodge Durango
My daughters 2003 Toyota Echo is eating batteries. I bought a new battery from AutoZone about a week ago and it is already dead. The altenator was checked and checked good. She told me the car is also...
You may have a "parasitic battery drain". (Hint: google "finding parasitic battery drains") Basically, there is something "on" that is draining the life of the battery even while the key is off. Common sources are courtesy lights under the hood and in the trunk; even in the sun visors. Also, anything that is hooked into the cigaretter lighter (or "power port") circuit. These items could be aftermarket car alarms, inverters for operating portable electronics, phone chargers etc. If you eliminate all these and still have the battery draining down, you may have a low amperage short somewhere. To find the circuit responsible, you will have to connect an ammeter in series with the battery negative cable. Say for example that it still shows a .1 amp drain--even with everything turned off. Start pulling fuses one at a time until the amp drain reads zero. The problem will be on the circuit of the last fuse you pulled. From there, you'll have to try and disconnect each item on that circuit until you find the culprit. It sounds tedious and it is.
Jan 26, 2011 | 2003 Toyota ECHO
My car is hard starting even if the had a good ignition switch and it's battery always drain even if my alternator is working good. the terminals of the battery were properly attached also.. what can i do...
get your battery checked, it would be a good idea to get the car checked for power drains that occur even when the car is turned off ie; sound system.
Dec 04, 2010 | 1995 Toyota Corolla
Charging system not working,we have replaced the alternator,the starter the fan sensor,the heat sensor replaced the battery several times car will not stay charged been told it was the electric module that...
No such thing. If you have a new battery, and the alternator's testing fine then there's obviously something draining the battery.
You'll need a multimeter for this. First off, once started, test the battery voltage at idle. Then increase RPM to about 2000. The idle reading could be as low as 10 Volt(since you just put a massive drain on the battery but should pick up with RPM to aboout 13 Volt at least. It could even go up to 14 Volt.
If that is fine, shut down. Disconnect the neg pole on the battery. Switch your multimetre to Amps(You may have to move one of the meter wires to a current measuring connection on the meter.) Connect the leads between the neg of the battery and the cable that came off it. A reading any larger than 0.5 amps (500mA) could mean trouble. First thing I always check for is trunk and glove compartment lights. They may not be turning off with the lid closed. Next is aftermarket amplifiers. If incorrectly installed it does not shut down and drains the battery in no time at all.
Jul 09, 2010 | 1993 Volkswagen Fox
I have a 1992 Nissan pickup with a brand new battery & a tested good starter. What could be draining my battery?
The way I track down battery drains is by disonnecting the negative battery cable and connecting a 12volt test light between the negative cable end and the negative post. If there isn't a drain then the tiny test light should be off. [with all the doors shut, lights off, and ignition key out] If the light is bright or glows even a tiny bit then you have a drain. A more sophisticated version of this test is to use a digital multimeter in place of the test light. Anything over about 50 miliamperes [.050 amps] of drain is too much, Your Nissan will probably have 20 or less miliamperes of drain if all is well. If you do have a drain then start with the simple things. Make sure the dome light and all other small lights are going off when the door is shut. If they are then I start pulling fuses one by one until I find the one that turns out the little light or reduces the miliampere reading to normal and then see what that fuse powers. Always be carefull when working around batteries and wear eye protection. It's rare but I have seen an alternator with bad diodes cause a similar drain. Disconnecting the alternator leads in this case should also cause the light to go out if it is the cause. Aftermarket radios, CD players, and auto starts can also be a source of drains.
Jun 10, 2010 | 1992 Nissan Pickup
Open Questions:
Insignia 600W Bridgeable Amplifier with 12" Subwoofer Logo
318 people viewed this question
Top Insignia Car Audio & Video Experts
Mark Skinner
Carlos Quintanilla
Level 1 Expert
Are you an Insignia Car Audio and Video Expert? Answer questions, earn points and help others
